Question about Xerox Phaser 6100/BD Laser Printer
I have a black line mark on paper
Also have messed
My fd100 wont print but thinks it is. also some times it freezes
if you could check the paper that you are using. make sure thermal. also scratch the paper, if a black mark appears this is the side that goes down in the paper holder, if you don't see a black line you don't have thermal paper. also make sure it is credit card machine and not adding machine paper. if you have another roll try that one. if persist. make sure the paper is hitting the thermal reader. there is no ink
Jul 17, 2014 | FirstData First Data FD100 Thermal Paper...
Panasonic dp3010 copier stripes on paper
Not exactly sure what you are asking but if the problem is that you are getting fine lines down the paper (the copy is ok though) then take a real close look atr the glass platen (the plate glass in which the paper goes on. Assuming you are using the ADF (Automatic Document Feeder) area. This area is usually about an inch wide by 8.5" long. Look for either "White out" or black ink on the glass (it can be as small as a dot) clean this mark off with glass cleaner and you problem will be solved. Sometimes it helps to orientate your copy with the line on it to the machine to locate the mark causing the issue.
Good Luck!
Mar 01, 2012 | Office Equipment & Supplies
I'M GETTING A THICK BLACK LINE DOWN THE MIDDLE OF MY. PHOTO AND UPLOAD. TRIED RE CALIBRATING WITH WHITE PAPER. DIDN'T WORK HELP
What printer do you have? Is the black line appearing on the paper when you print or when you fax/copy something?
If it is the latter, then there will be a mark on the optics glass that needs to be cleaned. Usually people using whiteout when wet causes this.
You will need to lift the cover where the paper goes through and check the glass
May 20, 2011 | Office Equipment & Supplies
Artia 6100 machine showing err out of paper.
hi,
ur machines paper sensing sensor have some problem. did u used the paper with black mark on the side.
remove the paper cover . u can see a black square sensor near the side of thermal printer. clean the sensor with an ear bud. do not use any solutions. then check again.
remember use good quality paper. if the black mark on the side of the paper is not perfect this problem can occur (black mark on the paper is for page count and paper sensing)
ok
Dec 23, 2010 | RTO Quinton Cardiology Atria 6100 Ecg...
Black marks on the printing
You could have a build up of ink on your rollers, and as the paper is pushed through it is leaving marks. It could also be causing your ghosting effect or double lines. By having your printer cleaned by a certified technician it should reslove your issue.
Jun 09, 2010 | Epson Stylus Photo 1290 InkJet Printer
My Sharp copier make a black line right in the middle of the paper.Haw can i fix it?
check first where the source of that black line, print it one page, remove the fuser and copier/developer and trace if mark line is noticeable.
Apr 16, 2010 | Sharp AR-5316 Advanced Digital Imager...
Printing mess
remove all the toner cartridges and then u need to clean the dirt collected in the printer.you can blow air with a blower machine.then shake the cartridges up side down for few minutes and then insert 1 by 1.it will work. the problem is either the dirt/dust collected in the printer or the cartridges are got over and needs refilling or replacement.
Nov 30, 2008 | HP Color LaserJet 2600n Printer
Black line down right side of paper
On the ADF check the twink mark on glass scanning mirror
Oct 15, 2007 | HP LaserJet 3055 All-In-One Printer
Xerox Phaser 6100/BD Laser Printer Logo
14 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
