Question about Xante Ilumina Digital Color Press Printer
Magenta spots on sheet - Xante Ilumina Digital Color Press Printer
KONICA MINOLTA BIZHUB C250 Printed only magenta
Does the demo page do the same? Mite have image control board failure. And electrical storms on a good surge protector not a Ace hardware 19.99 special, of course nothing against Ace Hardware :). Could also be a High Voltage board failure. Meter count page OK print out.
Apr 19, 2015 | Konica Minolta bizhub C250 All-In-One...
Spots
whit spots or magenta spots? try different toner
Mar 24, 2014 | Xante Ilumina® 502 Laser Printer
Magenta toner spots pages
Step 1:
Print out about 10 blank (all white) sheets and see if the spots clean off.
Step 2:
Check to see if the toner is Dell type brand, if not try installing Dell brand and run 10 blank copies then run color test print using menu key.
Press menu, press arrow down key till 'print reports' is displayed, Press 'check key' then press down key till 'color test print' Press check key to print color copy.
Apr 10, 2013 | Dell 3010cn Laser Printer
HP 2550 L ...When I try printing in color...........I get red/magenta spots on the printout........why is this happening ?
Are the spots in a uniform pattern? Try the Magenta toner cartridge first, the try replacing the imaging unit.
Jun 26, 2011 | HP LaserJet 2550L Printer
I have a HP color laserjet 4650dn that when you print a document, there are pink spots all throughout the document. Is this due to replacing the fuser or transfer bar? There are no warning indications on...
It depends on the true color of the spots. If what you describe as pink are actually Magenta colored spots then I would suspect the Magenta toner/drum cartridge. It is definately not the fuser. The transfer bar or actually transfer belt unit in this case is doubtful to be the cause. A defect in the tranfer belt unit does not normally show up as 1 color. It is usally multiple colors. I would open the front cover and at least visually inspect the Magenta toner cartridge. If you have a spare unit, even an old one to swap it out with even better. Look at the color of the Magenta toner and compare it to the spots you are seeing. If they are similar then in my opinion the problem is in the Magenta drum unit.
Apr 21, 2010 | HP Color LaserJet 4650DTN Printer
D7260 not printing some colors
1.Try placing sheet of Magenta print on copy board, and run many copies .  Run head clean after about each 50 sheets.
Apr 24, 2009 | HP Photosmart D7260 Printer
Im running 12"X18" sheets from the manual feed tray..
You should print the "Repeating Defects Page" Using the printer's front panel menu keys perform the following steps:
  1. With Information highlighted, press the OK button.
  2. Scroll to Troubleshooting by pressing the Scroll Up or Scroll Down button.
  3. Press the OK button.
  4. Scroll to Print Quality Probelms by pressing the Scroll Up or Scroll Down button.
  5. Press the OK button.
  6. Scroll to Repeating Defects Page by pressing the Scroll Up or Scroll Down button.
  7. Press the OK button to print the Repeating Defects Page.
Most likely you have a defect on your magenta imaging unit. Switch the Magenta and Cyan imaging units and try the test print....if you have blue spots 3 3/4 then it is the imaging unit (drum). If not you may need to change the belt cleaner assy.
If it isn't the imaging unit then it will be a problem with the fuser rollers, so replace the fusing assembly.
Jan 15, 2009 | Xerox Phaser 7750DN Laser Printer
Hp 4650n
There is not clean cartrige button.
If you want you can try to remove the cartridge and clean it with a paper towel, and see if that helps get you to 300 more sheets, if not I would replace it.
Angela
Aug 12, 2008 | HP LaserJet 4650 Color Printer
Magenta printing as yellow
Well, first off, are the alignment, and nozzle check sheets looking good? If not, then work on that. If so, then we have a problem. Try creating a test sheet in Word. Make red, yellow blue & black text and see if anything else prints wrong. Get back to me!
Jun 19, 2007 | Canon PIXMA IP5200 InkJet Photo Printer
16 people viewed this question
Top Xante Office Equipment & Supplies Experts
Ottoniel
Dudeman321
CheckitRight
CheckitRight
Are you a Xante Office Equipment and Supply Expert? Answer questions, earn points and help others
