HD TV LG 29MN33 and Sapphire Radeon HD 7970 resolution problems
Hi guys ! I just bought the HD TV LG 29MN33 monitor 2in1 and I just cannot get the correct res on this, it says 1366x768 is the recommended one even though it's not the highest res available ( the highest is 1920x1080. if I switch to the higher one, or the highest one desktop display is correct in scale, icons are correct in scale but everything is absolutely blurry and i kid you not, my head starts to hurt in 3min of workin like that. this monitor doesn't have a diver with it, it's lug and play sistem since and i'm connecting it via HDMI cable with my Sapphire Radeon HD 7970 DD, and I know that this card is capable of much higher res then 1920, but i'd be happy if I get it to work on this one. any suggestions on this would be greatly appreciated :) all best and thank you for you help
5 Suggested Answers
SOURCE: Connecting an LCD TV to a computer to use as TV and Comp. Monitor.
Im no expert on the subject, but I use my L37 for a monitor, and use just the vga adapter. It works good as a monitor, and both dvds and my hdtv wonder tuner card look great through the vga connection. They do make adapters for dvi to hdmi. Although, hdmi also carries sound, but you wont get that out of your dvi output from your card. So you might not have sound when using that connection, as your tv may not look to the headphone type jack used for sound imput from your computer when you select the hdmi source on it. If you have speakers already connected to your computer you may not care. Also if you have a 720 p Vizio, 1366x768 is the highest resolution you are going to get out of it anyway, if I'm not mistaken. I'm Not sure why you would need 2 connectios to the same monitor either. I posted 1 link below because they had several dvi to hdmi adapters. Hope that helps.
http://www.bizrate.com/computercables_adapters/products__keyword--hdmi+dvi+d+dual+link.html
Posted on Aug 01, 2008
stonephoenix
  • 563 Answers
SOURCE: 1080p bush 42 inch tv only displaying 1366x768
1080p refers to the resolution you get when watching television. When you're using the TV as a computer monitor a different resolution scale applies. In other words, television resolution and computer resolution are measured differently.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need further assistance so that I can help you further.
Posted on Jul 11, 2009
SOURCE: Bush iD HDMI 37inch tv hdmi problem
There should be a Zoom button on your remote control (Around the Teletext area, the word "WIDE" is below it) Select 'Zoom 1' and the TV Will display true 1920x1080 for your PC...
This is not a problem of any sort... for some reason the TV is defult to 'Zoom 2'
Peice of Cake.
Posted on Nov 07, 2009
SOURCE: I AM FROM INDIA I RECENTLY
Hi gurmeet,
What I suspected from your description of problem is that there is some kind of compatibility issue or content protection when you plug in an additional HDMI to DVI converter.
I am also using an Airtel HD connection, though however, I wouldn't need any kind of converter because I am directly connecting HDMI cable to my LCD and it works like a wonder. I set up my box output resolution to 1080i and there is no display resolution mismatch. Not even at other resolutions.
Airtel is using 1920x1080 resolution in signal transmission, so the possibility of 1079 from there end is ruled out, otherwise, the same problem would have been observed when direct HDMI cable is being used. I hope you understand my point.
Now you might also ask why you weren't able to see this problem when you connect the monitor to your PC graphics card. I would like to tell you that graphic cards are very versatile and does have the capability of 1:1 pixel mapping, so there you wouldn't see any such problem.
read this link for more http://www.hdtvsupply.com/hdtodvico.html , where a person is able to match resolution using a similar converter.
I believe the converter you use isn't able to do 1:1 pixel mapping and is actually downgrading the resolution which your monitor is not able to support.
You can try out other resolution type from the STB and if you still see similar problems, then you may need to get an alternative converter.
Follow these steps to change the STB resolution type;
Enter the Menu from STB remote -> scroll to 'My Settings' -> Enter 'System Setup' -> 'HD Setup'. Here you change to a lower resolution and press ok from remote.
Posted on Sep 24, 2010
Graphic Card
If your pc is going to have and intel cpu i suggest you the ZOTAC one... IF it has an amd cpu then buy the ati radeon hd 7970.Thanks for using fixya
May 30, 2013 | Computers & Internet
Online chat
If you have an AMD processor, I would keep with the same manufacturer (ATI Radeon) Otherwise, choose the one you can afford. And remember that you will need to check your power requirements after you have decided on the rest of the system. And if you want the system to remain stable you should look for a 80+ Gold rated PSU.
How can I get Full Screen On my monitor? Iam using (1) Monitor, Samsung bx2450. (2) Mother Board,ASROCK Z68 EXTREME4 LGA 1155. (3) Graphics Card, SAPPHIRE RADEON HD 6790 1GB GDDR5. (4) Processors, INTEL...
Quite a system you have. If you're running WIN10, right click on open space and choose Display settings. Change the Resolution until the desktop fills the screen.
Oct 26, 2017 | Samsung BX2450 LCD Monitor
Problem with drivers sapphire radeon hd 2600 pro
For this card you will utilize the ATI Catalyst Suite:
To obtain this siftware, visit the ATI website by click here http://game.amd.com/us-en/drivers_catalyst.aspx
Select the Full Catalyst Software Suite by clicking on your Operating System.
After you have downloaded the software, foloow the instrctions to install.
Apr 27, 2010 | Sapphire RADEON™ HD 2600 Pro, Graphic Card
Want to konw that will new graphic cards work on my pc??
I suggest that you need to buy the SAPPHIRE Radeon HD 5770 1GB graphics card. It is compatible to your ASUS motherboard. It will display and work faster.
Dec 23, 2009 | Computers & Internet
Ati radeon grafix card 9550/x1050 monitor signal out of range
Try to check the screen resolution and the screen refresh rate. Try to set it first to 60hz for the screen refresh rate and try to set the screen resolution to 1024 x 768.
Aug 31, 2009 | ATI RADEON HD 2400 PRO Graphic Card
How do i use my tv as my pc monitor. so i can watch movies from my computer ?
The problem may be the resolution. Your TV will run 1920x1080. You might try changing the resolution to that and then try connecting to TV again.
Oct 26, 2008 | Philips 34PW8502 34" TV
Graphics Card Compatability
Yes, it should work ok.. Your motherboard supports 1 x AGP8X, and since this card is 8x AGP, and includes a power adapter cable, it should be fine. Just make sure you have an adequate power supply (400watt+)...
Apr 11, 2008 | Sapphire RADEON X1950Pro 512MB Graphic...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
