Question about Plumbing
Undercounter r/o water filter vacuum
Following a change of carbon filters there is a vacuum creating a sucking sound at the back side of the r/o faucet base. when the weep hole is covered the sound is heard at the point where the flexible r/o line connects to the plumbing of sink drain. what I source of the vacuum?
    Habit-Forming:
  • 155 Answers
Water flowing past a hole (or connection) in a pipe will cause a vacuum at that connection. Is there water flowing anywhere else in the system?
Posted on Jun 18, 2014
arealplumber
  • 33 Answers
SOURCE: Loss of pressure in kitchen faucet - Price Pfister
Your problem is a simple one.
  1. Turn off water to faucet.
  2. Place a towel(s) in the base of the sink(s) to prevent any parts from going down drain.
  3. Remove the handle to the faucet. (single handle only)
  4. If not a single handle then remove spout from faucet.
  5. If a single handle remove cap carefully and any loose parts.
  6. Gently turn spout side to side while lifting to remove.
  7. You will see a hole with a very small valve where the water comes out to the spout on the base of the faucet.
  1. Remove this valve (which is a backflow preventer) and replace.
  2. Reassemble and test.
Problem solved.
Posted on Dec 05, 2008
arealplumber
  • 33 Answers
SOURCE: low pressure and flow on hot water side of single handle faucet
It could be one of two problems, one simple, one serious.
  • Easy fix
  1. Turn off hot water angle stop under sink to faucet.
  2. Remove supply line from hot angle stop.
  3. Place end of supply line in a small bucket to catch some water.
  4. Turn on cold water for a couple of seconds and backflush debris from faucet.
  5. Reconnect supply line.
  6. Turn on angle stop and test
  • Complex fix
If you have steel pipes you may be experiencing reduced flow due to corrosion in your pipes. Reduced hot water pressure in the kitchen faucet is usually the first sign since this is the faucet that is most used in the home.
Repiping is a job for a professional. Another symptom you may need a repipe is orange colored or rusty water.
  • 14 Answers
SOURCE: Kitchen Faucet 6310 020 White - HOT WATER SIDE NOT WORKING
The faucet cartridge is more then likely blocked and the faucet will have to be disassembled in order to unblock it.
While it is disassembled you should slowly turn on the water lines to make sure the water ways in the faucet are clear. And thoroughly check the cartridge for damage. Replace if necessary.
Replacement Cartridges can be purchased at most plumbing supply houses or Big Box Stores such as Lowes or the like.
Posted on Dec 27, 2008
SOURCE: water pooling at base of delta waterfall faucet spout
I have the same problem. The part that is needed is found with a simple Google search for "Delta Waterfall RP22934 O-Rings"
Simply Slide the collar up at the base of the spout where it swivels.
Gently open the now exposed split plastic retainer so that the tabs near the bottom are pulled from their holes.
Lift the spout off the base to expose the o-rings.
Replace with the new o-rings and apply o-ring grease.
Re-assemble and enjoy a dry sink area.
Posted on May 23, 2009
  • 58 Answers
SOURCE: Freezeless yard hydrant constantly drains is there any adjustment
Bear with me. The hole is not a weep hole, but a drain. When you shut the valve off, the water in the pipe should drain out this hole so the pipe doesn't freeze. When you lift the handle the rod in the center of the pipe raises a hard rubber bulb that lets the water flow and covers the drain hole so it doesn't run water all the time. To service the valve shut the water off, take the handle pivot bolt out. Loosen the packing nut in the center over the pipe, screw it out, lift the guts, - handle, rod and nut, out of the pipe, now you can see the rubber bulb. Screw it off and go to a good plumbing shop or plumbing supply. Replace the bulb and put it back together. The nut in the center tightens a packing to keep water from leaking around the rod. Too tight and it is too stiff. Too loose and it will leak. Also, where the center rod meets the handle there is an adjustment that allows you to lengthen the rod a little so the bulb is pushed down a little more. Maybe this is all you need. Anyway, you just got the whole load of hay. You can also screw the top part off the pipe and you don't have to disassemble the head. Put gravel around the bottom so when the pipe drains the water can get out. Don't leave a hose connected when it needs to drain.
Posted on Jun 09, 2009
How I clean exhaust filter
Here is what the owners manual of your unit lists to clean the exhaust filter.
Cleaning the exhaust filter
Open and remove the filter grill. (Fig. 4)
Remove the filter and shake out debris. (Fig. 5)
Rinse the filter in water if necessary. Let it dry before placing it
back into cleaner. (Fig. 6)
Replace filter grill.
Apr 03, 2016 | Eureka Rally 2 Canister Vacuum with...
Electrolux el 7020 Canister Vacuum shuts of continuously do i need to Change the Carbon Brushes
How old? If fairly new you should not need brushes, bad brushes would probably not allow the vacuum to run at all. Last time you changed filter? Sounds like the cover to the filter is not closing well enough. There's also possibility you have a clog in the wand or hose.
Mar 05, 2015 | Electrolux EL7020 Bagged Canister Vacuum
Where is the motor on the dc18
Hi there, it's Jack at Dyson.
If your DC18 is making an unusual sound along with a change in pickup performance, it's likely you have a blockage somewhere. Our online Support guide should help you locate and clear this:
http://www.dyson.co.uk/support/dc18/dc18-all-floors/my-machine-is-not-working/machine-not-sucking-picking-up-as-well-as-usual/how-to-wash-filters/wand-suction
If your vacuum's filter hasn't been washed recently it's also a good idea to do this. DC18 has one washable filter engineered to last the lifetime of the machine in normal use. This should be washed at least once every 3-6 months using cold water without detergent as shown in the video below. Make sure the filter is completely dry before replacing it - this could take at least 12 hours:
Please note, the post-filter is engineered to last the lifetime of the vacuum without maintenance, and should not be washed as this could cause damage.
Following these steps should resolve the issue, but if you would like some further help from our experts, please give us a call on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Aug 10, 2014 | Dyson Dc-18 "slim" Upright Model...
Try purging air from filter, read instructions to find purge valve, if none try running water and air should purge naturally
Mar 24, 2014 | Plumbing
R/o faucet weep hole has a vacuum issue
Try installing a check valve, or back-flow preventer. Also try getting all the air out of filters, they may have a purge valve or small screw to remove air from system.
Mar 24, 2014 | Vizio P50HDTV10A 50 in. Plasma HDTV
How do i change the filter in the amana my ice taste bab do i need to cut the water supply off to change the filter
Water filter is located in the upper right hand corner of the fresh food side.
Follow these steps:
  • These eight inch long filters are housed in their own compartment. The base of the compartment can be released by pushing in on the release clip found at the end of the housing unit. Allow the base of the housing compartment to hang down while you remove and replace your filter.
  • Twist the spent filter to the left (counter-clockwise) and gently pull on it to remove it. There is an automatic water shut off to keep leaks and spills to a minimum.
  • Remove the new filter from its packaging. Remove the plastic wrap, and peel off the aluminum topping. Insert the new filter into the housing unit. Twist the filter to the right (clockwise) until it clicks into place. Replace the base of the filter housing by cliping it back in place.
  • Condition the filter by dispensing several glasses of water through your refrigerator. This ensures that all fine carbon particles have been removed.
  • Check the filter and the inside of the refrigerator for leaks. If you find a leak, remove and install the filter again.
Sep 14, 2011 | Amana ASD 2624 Side by Side Refrigerator
Wate Filter Light stays on after filter has been changed.
  • After changing your water filter you have to reset the light for it to go off as it does not reset right away.
  1. Just press and hold the "FIGHT" and "LOCK" buttons until the water filter light flashes. Now the light will be off.
  2. Don't forget to run a couple gallons of water through the new filter to remove any carbon out of the incoming water after installing a new water filter. This is not poisonous by any mean but it can leave a bitter taste in your mouth until the carbon wears off.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Jul 20, 2011 | Maytag MSD2756G Side by Side Refrigerator
Vacuum gets hot loses suction and turns off
you have replaced all three filters?
if its turning and sucking with all new filters you have a glog somewhere
Apr 23, 2009 | Filter Queen Majestic Canister Vacuum
Too much carbon in water
Sounds like a bad batch of filters. Stop using them and return them to Brita for analysis and replacement
Feb 16, 2009 | Brita 35516 Pitcher
Plumbing Logo
32 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
