Question about Independent Inc. Remote Blower - CFMR1400 Kitchen Hood
Independent CFM 1200C in hood fan
Need to buy
Medium Fan Speed not working
Switch is probably faulty, or wire / connection to switch. If switch and wiring test ok trace wire from that button back to wherever it goes and look there for fault.
May 12, 2014 | Faber TEND30SS300 Decorative Collection...
Range hood turns on sometimes only
Check the switch first. Then check for loose connections in the vicinity. Make sure the power line and neutral are not cutting out to the appliance. It could be a bad fan motor as well.
Sep 16, 2013 | ProAire Elite Compass Series 36" Island...
Need fan knob for independent mlss52ss kitchen hood
how do I order switch and knob. This is broken and canit turn off fan
Nov 05, 2012 | Independent (MLSS52SS) Kitchen Hood
We have 10 hp Motor with centrifugal fan fitted with 5 TR Cooling compressor? We want to know the cfm of air?.
You need to either get the specifications from the fan manufacturer, or take air readings with a manometer or flow hood
Apr 27, 2010 | Cfm Klimaire KSWG009H113 Split System Air...
When it is windy outside the flap on my exhaust fan flaps open and shut. Is there a problem in the way the fan was installed?
Not likely, Just a condition of the location of the vent and the wind direction.Putting a secondary larger hood over the outside exposure will sometimes help alleviate this.
Eric
Oct 13, 2009 | Broan-NuTone Nutone QTRN080 Quiet Test 80...
I have a dayton kitchen exhaust blower mod no. 4hz65, 1/25 hp, 1550 rpm, 115 volts, 1.5 amps, 8 inches. it does not seem to do the job, do i need a stronger one?
Remember air will only move as fast as the size of the exhaust pipe in relationship to the fans ability to push. Make sure yours is the proper size for the fans volume.
Jul 07, 2009 | Dayton Exhaust Blower to vent your grow...
New range hood whistles on high
Please call Diana Vincent at 775-358-0263... or Jeff Bilyeu at the same number...
THEY WILL HAVE AN ANSWER!!!!
Thank you,
Lauren Kilmer
Dec 12, 2008 | Independent Inc. Laramie Wall Model - LARA...
Is the Gaggenau VL051-707 compatible with any other fans?
Not really due to the wiring you will have to rewire the unit see the power in and control power to the ventlator comes from the countertop unit.. unless you rewire it. See the black molex plug under ventlator that is the connection
Feb 21, 2008 | Gaggenau VL051707 Hob Ventilator: AS...
Broan fan cat h 500 housing 115v 60 c 1.5a lr 31619
Customer Service: 800-558-1711
Technical Support: 800-637-1453
Oct 13, 2007 | Broan-NuTone Best By Broan BER02IS 48"...
Kitchen Ranges Logo
66 people viewed this question
Top Independent Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you an Independent Kitchen Range Expert? Answer questions, earn points and help others
