Question about Makita Drills
Where would i find a manual for my hp1630 makita drill? I would particularly like to now how to open it in order to grease it
Hp 1630
  • 313 Answers
SOURCE: makita 1420 - 14.4v 1.3Ah cordless drill
try toolpartsdirect.com & go to makita & type in model #
Posted on Jun 09, 2008
SOURCE: Makita drill 6349D
dont think its http://www.toolbarn.com/product/makita/6349DWDE/
Posted on Oct 05, 2008
radar001
  • 1051 Answers
SOURCE: removing chuck from Makita 64C1 drill
secure the short end of an allen wrench in the chuck, making sure it is as tight as possoble. Useing a wood or hard rubber mallet strick the long end of the allen wrench so it turns counter-clockwise. This should loosen the chuck from the spindle enough that you can unscrew it by hand.
Posted on Feb 19, 2010
  • 5 Answers
SOURCE: how to change drill chuck for makita hp 2040
if its a reversible drill there will be a screw in the bottom of the chuck, open the jaws as far as they will go and you should see a screw head, it is a left hand thread so put the drill in low speed selector this will stop chuck turning as easily, then turn screw clockwise as your looking at the chuck, when its out put an allen key in and tighten up the chuck hit with hammer now in a anti clockwise direction it should unscrew. repeat in the reverse procedure to fit new chuck....
Posted on Jul 31, 2010
SOURCE: Broken Makita Drill 6408k chuck
If the chuck itself slips, you can tear down the outer layers (yes it is a bit brutal)
of the chuck until you reach the inner metal core. You can then try several things;
1 loosen it with a pipe wrench, provided you can get a grip on the axle of the chuck to counter the torque
2 Weld an allen key to the metal core of the chuck and use a firm rapid blow by a hammer to rotate it counterclockwise
3 Dismantle the final shaft with the chuck core, and set it in a vise with aluminium plates to protect it, while you turn the chuck with a wrench or pliers.
4.If there is no senter lock screw inside the bottom of the chuck it may be fitted with a thread locking compound. It will loosen easilier if heated with a heat gun or moderate gas heat.Only supply just enough heat to loosen it, or the hardening of the steel may be compromised.
Posted on Dec 02, 2010
How to replace chuck bearing for makita hp1630 hammer drill.
is this the bearing that is gone ..its on the armature
ifit is you have to take the casing apart
Jun 29, 2016 | Makita Drills
My Makita drill stops spinning mid drill and starts again whilst stopped it makes a horrible grinding noise. Can anyone tell me what is causing this? And how do I fix it?
as with any power tool there are gears attached and when things are used they wear . the stopping might be a dirty connection . and being under the load when it stops puts much more stress on the moving parts .you could open it and grease it goos , cleaning the contacts at the same time but sooner or later it will go again ,and possibly never restart .
Aug 14, 2015 | Makita Drills
What grease do you use for a makita demolition hammer
MAKITA HAMMER DRILL GREASE 30G (181490-7) or for the older HM models Hammer grease Makita P-08361
Nov 05, 2012 | Makita Hammering
Hi, I bought a Makita 24V Hammer drill HP1630 for our Mechanic. He informs me it has failed and stopped working. Is there a familiar fault with these that can easily be fixed?
The Makita has many faults - some are easy to fix - some not. But instead of typing a large list - it would be better if you gave us some indications of what it is doing and what it won't do.
Does the battery chage? Any light indications on the charger? Does it not work in both the hammer drill and drill settings? Things like that will allow us to help you better.
Sorry, but there is no easy fix to something if we don't have the right information
Jun 20, 2011 | Garden
Ow to rewind the armature of makita electric drill model hp 1620.
unless you have specialized machinery you cannot rewind the armature. If it is open or shorted it would need to be replaced.
Jun 14, 2011 | Makita & 1/2 Inch Drill
I have a makita Hammer drill # 6914D model 527047E looks like it is need of some oil what kind. The glass window is empty can you help me tried to find a manual but cannot.
Go to the below site for a manual. There isn't any reference to a glass window in the manual but the tool does need to be regreased as indicated in the manual, especially if it's used frequently. If you do it yourself, pay close attention to how much grease you put in the tool. Too much grease causes excessive drag and makes the motor work harder.
You can find an owner's manual and parts breakdown on Makita's website: http://www.makitatools.com/en-us/Modules/Tools/ToolDetails.aspx?ID=173.
Apr 26, 2011 | Makita HK1810 Power Scraper, Small,...
Can I buy a new motor for a 12 v Makita cordless? How much?
You need to contact Makita directly. But from experience, it's usually cheaper to purchase new drill than replace parts.
Mar 09, 2011 | Makita 12 Volt Cordless Drill/Driver Kit
Drill will not turn but will you can here a grinding sound. Drill will turn when done by hand. Drill has not been run for over three years.
The gears are worn out,take it apart to verify. They need to be washed out with mineral spirits and greased if okey,otherwise they wear out the gears
Buy a new one on--- Tool Barn.com
Best prices for Makita
Nov 06, 2010 | Makita 6402 3/8" Drill, 5.2 AMP, 0 - 1,200...
Need a brack down manual for 18v makita driver drill
Go to the Makita web site and enter your model#. open the pdf ( schematics) file and download/print it.
Oct 24, 2009 | Makita 18v Cordless Driver Drill Mt065sk2
Makita 8406C Gearbox oil
It uses grease to lube the gearbox. makita supply their own grease so you should be able to get a small tube from your local dealer. You don't have to use Makita grease though, just general grease should be fine. Not too thick and heavy, or too oily and light. I know that sounds a bit vague. Do you have other machines that you have grease for? SDS hammer drills, saws, any small power tool like that will use a similar type of grease.
Nov 01, 2008 | Drills
Drills Logo
Top Makita Drills Experts
John Trevino
Are you a Makita Drill Expert? Answer questions, earn points and help others
