Question about Frigidaire 24 in. PLD3465REC Stainless Steel Built-in Dishwasher
Washer wont start showing error code
Reset the breaker. it tried to restart but error code showed up
  • 158 Answers
SOURCE: when trying to start washer LOC shows on the
Unplug the washer power cord and plug it back after 2 minutes and see if the washer reset it self. I think it will.
Posted on Oct 01, 2009
tbirdfan1
  • 3051 Answers
SOURCE: Frigidaire double oven beeping and showing f8 code
Hello there
First i would unplug it for 1 hr to allow the oven internal reset to reset it'self than plug it back in and see what happens but if this doesent help than here is a listing of the code and what it means
F8 Lock motor relay watchdog is ative when it should be off Microprocessor checking the operation of the EDC lock relay after self clean is selected, relay failed. Replace EDC.
Lock switches Check or Replace component
Posted on Dec 31, 2009
  • 202 Answers
SOURCE: my front load affinity wont
Hi... You have a bad speed board
Posted on Mar 29, 2011
chrispolkele
  • 4342 Answers
Our people make the difference
    Verified Fixya Pro
    SOURCE: fridgidaire upright washer E41
    Hello Marcee Peterson - Typically error code E41 indicates that washer has detected that the main control board thinks the door switch is open. Try reprogramming the washer by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and restart unit. If it proves to be ineffective, contact a professional to move forward accurately and properly assist with the repairs.
    Posted on Feb 22, 2013
    goodwinpeg
    • 744 Answers
    SOURCE: Error code E61 shows on my Frigidair Affinity washer. Do you know what E61 Means?
    Hello Murray;
    My name is Peter. I am a retired field service appliance technician.
    Hi E61 means that the control board is sensing an incorrect/abnormal voltage present at its input.
    1.) Unplug the unit for 5 minutes. If the error comes back -
    2.) Lets check your power cord:
    a.) Unplug the machine. Is the middle connector on your power cord connected to 'N'?
    b.) Tighten all the connectors. Make sure you have a good ground.
    c.) Check the voltage. Between 'L2' & 'N' = 110V, 'L1' & 'N' = 110V, 'L2' & 'L3' = 240V.
    3.) Lets check your control board for shorts:
    a.) The following link will show you how to access. Ground yourself by rubbing your hands on bare metal. Static electricity will knock out a board.
    b.) Check all of the connections, push in on the wires at the connectors.
    c.) Reassemble and try to start
    http://www.applianceblog.com/manuals/5995413084_Washer_2004.pdf
    4.) Well, if none of the above solved the problem, you have to replace the control panel.
    Part #: 134523106 - Cost: $168.00
    Posted on Dec 08, 2014
    Bosch dishwasher she43m06uc/48 constantly trying to drain. Cannot reset to end cycle.
    Have you tried shutting off power to it from circuit breaker panel for about a minute and leave door open to dish washer . If that does not fix it the float Is stuck from grime build up . You can down load a maintenance manual online on how to access it and cleaning tips.
    May 17, 2014 | Dishwashers
    Affinity washer flashing EFO
    Good Morning Friend,
    I understand that your Frigidaire Affinity washer, model# ATF7000E, is flashing an EFO code. I do not show an EFO code for your appliance.
    I do show an EF1 code, which means the drain pump is clogged. In this instance you would unclog the drain pump.
    I also show an EF2 code, which means too much soap was used. All you would do for this would be to try using less soap.
    It could also be a false error code. I suggest resetting your washer, by either unplugging it or shutting the power off at your homes circuit breaker, for 3-5 minutes. When you restore power, start any cycle on your washer. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer status has changed successfully. Hope this is helpful.
    -Best Regards-
    WP
    May 15, 2014 | Frigidaire Affinity ATF7000E Front Load...
    My Frigidaire Affinity washer stopped working in middle of cycle and shows E41 code.
    Hello Shawn Smith - Typically error code E41 indicates that washer has detected that the main control board thinks the door switch is open. Try reprogramming the washer by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and restart unit. If it proves to be ineffective, contact a professional to move forward accurately and properly assist with the repairs.
    Mar 03, 2013 | Frigidaire Affinity ATF7000E Front Load...
    Laveuse show err
    Hello tseitlenok - Typically ERR indicates that the washer has detected an error. Try reprogramming the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and restart unit. If error code does not clear, I would personally recommend consulting a certified technician for an accurate diagnosis and to assist with the repairs.
    Mar 01, 2013 | Frigidaire Gallery GLWS1339EC Top Load...
    Fridgidaire upright washer E41
    Feb 21, 2013 | Frigidaire Affinity ATF7000E Front Load...
    My Whirlpool Duet Front Load Washing Machine is showing a F28 error. What does that mean?
    F28 is a communication error which usually means there is a connection that has come loose. Removing the top and unpplugging and replugging the connectors in will fix 75% of these codes. If the bottom toe panel is not on it will also give you an F28
  • Unplug or turn the circuit breaker off for 30 seconds.
  • Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
  • Press the Pause/Cancel/Stop button twice to clear the display.
  • Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts if you have any further questions message me back and please remember to rank how this opinion has helped in your appliance situation when our chat has concluded Thanks again Rick
  • Jan 16, 2011 | Whirlpool Duet GHW9150P Front Load Washer
    ERROR CODE E50 SHOWING AFTER POWER SUPPLY INTERUPTION
    It was probably your washer that tripped the electric . e50 relates to the motor check the carbon brushes they will be worn out. hopefully with new brushes you will be back in action. the programme wont start with a fault on the motor
    Jul 24, 2010 | Zanussi ZWF1430W Front Load Washer
    Machine wont drain or spin the manual says to check hoses and
    just unplug it to try and reset it. should show some code
    Mar 31, 2009 | Maytag MAH8700A Front Load Washer
    Frigidaire 24 in. PLD3465REC Stainless Steel Built-in Dishwasher Logo
    44 people viewed this question
    Top Frigidaire Dishwashers Experts
    Mike
    Charles T Nevin
    Charles T Nevin
    Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
