Question about Texas Instruments TI-1795 SV Calculator
How do you change the decimal digits
Change the decimal digits
How do I change the decimal plase on my casio fx300s calculator
If you mean the fx-300ES, press SHIFT MODE 6 then a digit specifying the number of digits you want to the right of the decimal point.
If you mean the fx-300MS, press MODE repeatedly until you get to the "Fix Sci Norm" screen, then press 1 then a digit specifying the number of digits you want to the right of the decimal point.
Jan 30, 2013 | HP 12c Calculator
How to change the decimal placement to more places? i currently only have 2 decimal places displaced
Press 2nd [FORMAT], type the number of digits you want after the decimal point or 9 for floating-decimal, then press ENTER 2nd [QUIT].
Mar 03, 2011 | Texas Instruments BA II PLUS Financial...
My answers always come in fractions by default. how do i change the settings so they come in decimal points by default? further. how do i change the settings to have the answer in decimal points up to 4...
Press SHIFT MODE 2 to select the LineIO mode. To select the number of displayed digits in fixed decimal notation, press SHIFT MODE 6 and select the desired number of digits.
Oct 21, 2010 | Casio fx-300ES Calculator
How to fix it . My calculator rounds up every number
It is configured to keep zero decimal digits. You must change the number of decimal digits you want displayed. The following screen capture from the manual will show you how to select the display format SCI, NORM, RND and the number of decimal digits to keep.
Jun 29, 2010 | Casio FX-300MS Calculator
How do i set my calculator to 4 decimal places
Press [2nd][FORMAT] displays the DEC indicator and the number of decimal digits currently set. To change the number of decimal digits type a number between 0 and 9 and Press [ENTER].
Feb 06, 2010 | Texas Instruments BA-II Plus Calculator
Decimals wont show
You need to change the display format.
Press the [MODE] key a certain number of times until the screen displays Fix, Sci, Norm on one line, and 1 2 3 on the next line, with 1 under Fix, 2 under Sci and 3 under Norm.
Press 1 (Fix) followed by a number (1,2,3, etc.) This second number will set the number of decimal digits. In other words, if you press 1 (Fix) 3 all your results will have 3 decimal digits. If you choose 0, your results will not show decimals.
Hope it helps.
Thank you for rating the solution.
Dec 04, 2009 | Casio FX-300MS Calculator
How do i change decimal place on a 12C?
If I am guessing correctly, you want to change the number of decimal digits in your results. To do so, you press the [f] key followed by the number of decimal digits you want. The number of digits you enter must be between 0 and 9
Exemple
14.87456320
[f] 4 displays the above number as 14.8746
Hope it helps.
Thank you for using FixYa.
Nov 20, 2009 | HP Office Equipment & Supplies
Default decimal settings
Your BA II PLUS stores numeric values internally to an accuracy of 13 digits. However, the numbers it displays depends on the number of decimal places to which you have it set (choice of 0–9 or floating decimal). To set the number of decimal places displayed to three: hit [2ND][FORMAT][3][ENTER]This setting also continues indefinitely (even though the calculator is turned off and on) until it is changed.
Jun 01, 2009 | Texas Instruments BA-II Plus Calculator
Change the decimal point
To specify the number of displayed decimal places press the black and orange key with the orange color on the bottom, then press the = button (DISP) enter 0-9 for the number of digits you wish to apear.
Dec 19, 2008 | HP 10bII Calculator
I cant change my decimal place Sharp Calculator model EL-531WH
Set up > TAB > then select how many numbers you want after the decimal place.
Nov 11, 2008 | Sharp EL-531VB Calculator
Texas Instruments TI-1795 SV Calculator Logo
66 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
