Question about Dynex Wireless Optical Laptop Mouse DX-PWLMSE
Dynex PWLMSE Mouse
Worked fine for 5 weeks then it died. I changed the batteries and the USB port and still no luck. I have a HP Laptop.
rtrahan
  • 741 Answers
SOURCE: will not open on click; have to right click and
go into control panel and click on "mouse" to check your settings. You can set your mouse to several different combinations on what it does upon right-click or left-click..see if your settings are correct. If you have any questions let me know.
Posted on May 09, 2009
SOURCE: dx-pwlmse dynex mouse Newer HP computer, windows
Rollover the drivers
Posted on Nov 06, 2009
firesnake09
  • 2923 Answers
SOURCE: My Dynex Wireless Optical Mouse just stopped working
If the mouse light is not turning ON even though you have new batteries and the mouse is turned on, then you need to contact the manufacturer for RMA.
Thank you!
Posted on Dec 22, 2009
  • 903 Answers
SOURCE: Dynex wireless mouse DX-PWLMSE won't work
The mouse should be Plug and Play. Did you install the drivers before plugging the mouse's receiver in? The PC has to have the drivers first in order to take advantage of the Plug and Play capability. If you plugged the mouse's receiver in before installing the drivers, unplug the mouse receiver, uninstall the driver, reboot your PC, reinstall the driver, then plug the receiver in and you should be fine.
Otherwise, press the Connect button on the receiver first, and then the Connect button on the mouse, and that should establish the connection. You don't need to disable your touch pad in order to use the mouse.
Posted on Aug 20, 2010
  • 903 Answers
SOURCE: have a dynex wirless optical mouse how do i get it
Hi, you'll need a USB receiver in order for the mouse to work with a computer. The USB receiver connects to the computer and transmits the mouse's movements and clicks to the motherboard. Without the receiver, your computer has no way to know what the mouse is doing.
You can purchase replacement receivers for many kinds of wireless mice, but for the price it will cost you are probably just better off buying a brand new mouse so that you know it will work correctly with the receiver.
Posted on Jan 10, 2011
Have a dynex optical mouse model # DX- PWLMSE how does it connect
The Dynex DX-PWLMSE uses a 27 MHz frequency wireless connection between the mouse and a specific USB receiver. For the specifications, see https://www.dynexproducts.com/pdp/DX-PWLMSE/8632063 .
To use the mouse, you need to press the Eject button behind the scroll wheel. This lets you open the battery/USB storage compartment. Put two AAA batteries into the mouse. Then remove the USB adapter (it's between the two battery slots). Close the storage compartment and put the USB adapter into an available USB 2.0 slot on the computer with a version of the Windows OS above Windows 98. (Note: the specifications I see indicate Dynex wrote drivers for Windows Vista. It may not work with Windows 7, 8 or 10.) Make sure that the computer is on and can get driver updates from on-line sources. Turn on the mouse and it should auto-pair with the receiver. If there is no response, try pressing and holding the connect button on the bottom of the mouse.
I'm not aware of any vendors that sell the USB receiver for this mouse. The manual for the DX-PWLMSE is available from Manuals Lib: https://www.manualslib.com/products/Dynex-Dx-Pwlmse-Wireless-Optical-Usb-Laptop-Mouse-4908.html .
I hope this helps.
Jul 16, 2018 | Dynex Computers & Internet
I dont know how to install my mouse to my laptop. The laptop is an ASUS. please email me asap
You can only connect USB mouse to yout laptop. For USB mouse the driver is not needed. You can just plug in the USB cable of mouse in USB port and go ahead. Windows will install the relevant software automatically.
Thanks,
Amar
Sep 05, 2011 | Dynex Wireless Optical Laptop Mouse...
My dynex wireless mouse model dx-pwlmse just stopped working after having it for a couple years. changed the battery,moved usb to different usb ports doesnt matter wont work anywhere.
Hi.
There should be a small button on the underneath of the mouse which should say "connect" press that button and also the one on the USB receiver if it has one. Also check if you have put the batteries in the right way round.
Regards.
Aug 23, 2011 | Dynex Wireless Optical Laptop Mouse...
Dynex wireless mouse with new batteries (kodak AAA) inserted properly fails to move the cursor. Mouse barely used, purchased last year at Best Buy, Hadley MA
Make sure the mouse is turned on (power switch on the bottom) and then reconnect it with the USB receiver. Press the Connect button on the receiver, then press the Connect button on the bottom of the mouse.
Feb 19, 2011 | Dynex Wireless Optical Laptop Mouse...
Mouse does not work when used under xp. Followed installation guide but mouse appears inoperable. Mouse batteries are good and usb receiver working but no cursor movement with mouse. Attempted several...
I called Dynex customer support and they walked me through the troubleshooting process. It turns out there was a problem or conflict with one of my usb ports. The port recognizes my flash drive and other usb devices but not the mouse. I tried using the other two remaining ports and the mouse was recognized and works just fine.
Feb 16, 2010 | Dynex Wireless Optical Laptop Mouse...
Trying to add the Dynex wireless remote to my HP Notebook
Right below the scroll button there is an eject button. Push this and slide out the cover. You will find the battery compartment. Insert 2, AAA batteries. Be careful about the polarity. It is marked. Just match the polarity. In between the 2 batteries you will find the receiver unit. Slide this one out. Insert this receiver unit into the USB port of your laptop. Close the battery compartment cover. Turn the mouse upside down. You will find an on/off (on the right side top) switch. switch it to on position. If the mouse is not detected, press the connect button below the on/off switch. Good luck.
Feb 08, 2010 | Dynex Wireless Optical Laptop Mouse...
How do i get my wireless mouse to connect with my laptop
Do you have a wireless keyboard also. It may be the reciever.
Apr 06, 2009 | Dynex Wireless Optical Laptop Mouse...
Jan 22, 2009 | Dynex Wireless Keyboard/Optical Mouse...
Dynex Wireless Optical Laptop Mouse DX-PWLMSE Logo
Top Dynex Computers & Internet Experts
Prashant M
Prashant M
micky dee
Mike
Are you a Dynex Computer and Internet Expert? Answer questions, earn points and help others
