Question about HP PhotoSmart Office Equipment & Supplies
"busy" message on HP C510a, can't print anything.
Tried clearing print spool, disconnected printer from power supply source, cleared print queque same message remains. I do notice that on the dock for the Zeen, there is a red X and no other lights will come on. Tried doing a search to solve problems but apparently a solution seems to be hard to find.
  • 159 Answers
SOURCE: Need to clear all printing jobs from the printer 4250 HP
It's probably queued up on the computer you're using. If this is Windows or Mac, look for a printer icon toward the bottom-right corner of your screen.
If you don't have it and you're on Windows, click Start: Control Panels: Printers. Find your printer.
Inside the new screen, you should be able to first pause the printer, then cancel all the jobs. You may have to highlight all of them, then right-click to get cancel.
When they're all cleared out, go back to where you paused the printer, then hit Resume printing.
Posted on Jan 19, 2009
SOURCE: change papersize from LTR to LGL
Turn the printer off for about 10 - 15min ( or even longer ) by removing the power cord.
I had left it unplugged overnight as it was late and had given up on fixing this annoying fault. Once plugged back in it was working fine.
Posted on Feb 11, 2008
SOURCE: HP Business Jet 2800 stall error message
See http://fixyourownprinter.com/forums/inkjet/42029
"Carriage Stall or Jam" by Stephen
Clean encoder strip with clean water, clean rod with denatured alchol you can get at Home Depot and lube with Synthetic Lubricant that you can purchase at a gun shop for about $4.
Posted on Apr 10, 2009
  • 62 Answers
SOURCE: how do I clear the memory on a zebra gk420d?
Download the Seagull scientific GK420 ZPL driver. Version 7.16.
Open the driver file, (Double click on printer icon in printer & faxes folder)
Click Printer, properties, tools, action, reset printer.
Play around with the Seagull driver, it is very useful, you can format memory, read files stored in printer memory, see forms, fonts, images etc.
The forms stored in the G series printers are not cleared by the normal methods which one would use on it's predecessor the 2844 models. The G series will maintain the forms stored in its memory even if you download new firmware, or reset it. This is actually a good thing, as it prevents you from accidentally erasing forms stored in the printer.
Posted on Apr 18, 2009
tumi001
  • 102 Answers
SOURCE: SerialNumberJob appears in the printing queque
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost,Scanner does not work, Connection problem etc. For find all these software solution just clickhere....
http://www.hp.com/printer/prob676ijt65/solution
ab20
Posted on Jul 17, 2009
How do I clear a document stuck in the print que?
If you are on a network and the printer is shared by others, you are only allowed to clear documents you have spooled to the printer. If someone else has a file jammed in the queue, then they (or an administrator) must remove it.
Aug 03, 2014 | HP Deskjet D4260 InkJet Printer
Can't cancel printing jobs on Samsung SCX-4655f
Hello Lulian,
Provided you have the correct software and driver/firmware update then the ONLY thing that can cause this is the RAM buffer.
Yes I know that software on Win 7 can sometimes "loose" the odd icon, but with the printer problem you have I know its not that.
What is going on is that the on-board memory is buffering everything to the printer. What this means is that you can stop it at the printer (as its all there) but the software on the PC (IF its up to date) cannot do anything as all its been doing is spooling the file to the printer.
If you can....you could look through the printer booklet and see if there is a way to switch off the buffer which would then mean that the print job would be spooled to the printer via the PC bit by bit and the software would be able to stop it.
But before you do all that.... just go and manually look for the firmware and software upgrade and then see if that solves it.
Hope that helps you and if so please rate me.
Regards
Nov 11, 2013 | Samsung SCX Office Equipment & Supplies
My Printer ( HP Deskjet F2210 ) will not print. It is installed, plugged in, and has ink AND paper. I've waited several hours for it to print but it will not work. It's stuck in the queque, or...
Go to START then RUN and type services.msc and click on OK. This should open services window. Scroll down to on the list and look for Print Spooler. Click on STOP on the left pane then restart the service. This should clear put the stuck document in your print spooler and you should be able to print again.
Hope this helps.
Jun 14, 2011 | HP Deskjet F2210 InkJet Printer
I have HP Laserjet 5200N printer, i am not able to print due to error massege "10.00.00 Supply Memory Error". thanks Mohammad Hittini Director of IT Moevenpick Resort & Spa Dead...
Not sure if you have tried the HP knowledgebase, but there are a few steps they recommended trying.
Here is the direct link, but I copied the relevant information into my reply.
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=bpl51389&locale=en_US#A3
10.00.00 SUPPLIES MEMORY ERROR alternates with For help press ? Description An error has occurred in one or more of the printer supplies. Values of xx and yy are listed below: xx
  • 00 = memory is defective
yy
  • 00 = black print cartridge
Action
  1. Turn the printer power off, and then turn the printer power on again to clear the message.
  2. If the message persists, click here to access the HP support Web site at http://www.hp.com/support/lj2300 .
  3. If the printer has a 500-sheet Tray 3 installed, turn the printer off again and replace the print cartridge with a new HP print cartridge.
  4. Turn the printer on again.
  5. If the error does not clear, turn the printer off and remove Tray 3.
  6. Turn the printer on and verify if the error clears.
  7. If the error does not clear, contact HP support.
10.10.00 SUPPLIES MEMORY ERROR alternates with For help press ? Possible printer control panel error message 10.10.00 SUPPLIES MEMORY ERROR Description An error has occurred in one or more of the printer supplies. Values of xx and yy are listed below: xx
  • 10 = memory is missing
yy
Action
  1. Turn the printer power off, and then turn the printer power on to clear the message.
  2. If the message persists, click here to access to the HP support Web site at http://www.hp.com/support/lj2300 .
Jan 01, 2011 | Computers & Internet
Print cancelled will not clear. How do I clear
Please perform the following steps if the message is on the unit diaplay:
1. Disconnect the unit from the computer. Unplug the power supply from the wall outlet.
2. Unplug the power supply from the back of the printer.
3. Wait at least 20 seconds, then plug in the supply back into the wall outlet.
4. Plug in the power supply back into the printer.
5. Press the power button to turn the printer on.
:) Dr Tony
Apr 15, 2010 | HP OfficeJet 7110 All-In-One Thermal...
Paper jam - can't clear error message
Hello Nj,
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Paper jams are was very common on HP printer model.
Here are few instructions on how to clear the paper jam on your printer.
How to Clear a Paper Jam on an HP Inkjet Printer 1. Disconnect the power cord from the back of the printer before you begin. With the power disconnected, you will protect yourself from being shocked. This is an important step when you are fixing any type of electronic device.
2. Move your printer so that you'll have access the back panel. Unhinge the back access panel of the printer.
3. Look for paper through the opened back panel. Remove any paper you find jammed.
4. Close the back access panel. Make sure that it latches into place and looks the same way it did before you opened it.
5. Open the front or top access panel. This is the panel you use to access ink cartridges. If the carriage that holds the ink cartridges moves, then you forgot to unplug the printer. Go back and do that now. Look for paper that may be jammed in this area of the printer.
6. Remove any paper you find jammed here. There will be resistance from the paper feeder, so pull slowly or the paper will rip and create a more serious problem.
7. Close the front access panel. Make sure that it latches back into place.
8. Plug the printer in and attempt to print again. If you can print successfully, you have removed the paper jam.
Hope this helps.
Aug 08, 2009 | HP Office Equipment & Supplies
Printer error messsage
attempt to clear the print spool and set the its settings to print directly to the printer. Do a test print, then enable print spooling again. If the same thing happens, uninstall and reinstall the latest printer driver
Jan 16, 2009 | HP LaserJet 4350 Printer
How do I clear an incomplete print operation?
Try clearing your spooler queue:
Delete the spool printer files loadTOCNode(2, 'resolution'); In safe mode, delete the spool printer files. To do this, start Microsoft Windows Explorer, and then delete all the files in the following folder (where C: is the drive where Windows XP is installed):
  • C:\Windows\System32\Spool\Printers
Dec 08, 2008 | Lexmark Z600 InkJet Printer
HP Business Inkjet 3000
you may wish to clean the nozzles, and do a clean and calibrate
May 07, 2008 | HP Business Inkjet 3000 Printer
Error - carriage jam message
SolutionStep one: Perform a power reset and connect the printer directly into the electrical outlet Remove all the paper loaded in the main input tray.
Make sure that the product is turned off.
Disconnect the USB cable from the back of the product.
Disconnect the power cord from the product.
Disconnect the power cord from the electrical outlet and wait 10 seconds.
Reconnect the power cord directly into the electrical outlet and check for the following.
Make sure that the power cord used is the one provided with the product.
If a computer is connected to the product, make sure that the computer is connected to a grounded (three-prong) wall outlet.
Make sure that the power cord is firmly connected to both the product and the power supply.
Reconnect the power cord to the back of the product.
Press the power button ( ) to turn on the product.
Reconnect the USB cable to the back of the product.
If the issue is resolved, proceed to Step six: Print a self-test page.
If the issue continues, proceed to the next step.
for more information please go to below link>>
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01458822&cc=us&lc=en&dlc=en
Thanks for using FixYa.
Mar 20, 2008 | HP Officejet 6310 All-In-One InkJet...
Seeker5211
Seeker5211
