Question about Dehumidifiers
Manual for blyss wdh-1012ea
Defrost light flashing
Our dehumidifier seems to be working fine but the orange light is flashing above the star mark
When an error occurs, the Alarm lamp flashes orange. Check the status of the lamps, then take the appropriate action in Alarm Lamp Flashes or ON Lamp and Alarm Lamp Flash Alternately.
Jan 10, 2017 | Dehumidifiers
Our dehumidifier has formed a sheet of ice amongst the coils and will no longer pull moisture from the air. The hole from which the water drips is completely iced over. It is 70degrees in the room and...
Turn the unit OFF and unplug it from the wall. Allow it to thoroughly thaw and remove the humidifiers cabinet to expose the cooling coils. Clean those thoroughly and coat with a very light coating of WD40. Reassemble the humidifier and turn it ON. Set your humidity control at 50% and allow the unit to run for at least one hour. Check for water collection in the bucket and for any signs of icing, after one hour. If water is in the collection bucket and no signs of icing, lower the humidity to 45% and continue. If you not any signs of icing, watch the unit, as you need to know if it automatically goes into defrost mode. The compressor should shut off, but the fan will continue to run until defrosting is completed. If it doesn't the auto defrost sensor has failed and will need to be replaced.
Hope this helps you to troubleshoot and solve the problem. Please let me know. Thanks.
May 08, 2011 | Dehumidifiers
Why is the defrosting light coming on periodicaly.
Defrosting is a normal function of a dehumidifier. When the evaporator gets too cold and starts to ice, the dehumidifier goes into defrost mode to clear / stop the ice formation. How often is the defrost light coming on and does the dehumidifier seem to be dehumidifying as expected ?
Charlie
Feb 01, 2011 | Danby DDR4010E Dehumidifier
How to defrost a dehumidifier lost instruction
Simply turn it off and let it set! this will allow the coils to thaw.
Nov 27, 2010 | Dayton Dehumidifiers
Auto-off light keeps flashing
I have the same issue.  Any responses?
Jul 03, 2008 | Kenmore 54351 Dehumidifier
Red full light blinks, humidity level stays at 01, runs for one second or not at all.
I just now noticed this posting even though it is now November. I will post this in case you still have the dehumidifier & haven't solved the problem yet, or for those who may be searching for a solution later.
The 01 code & the blinking light indicates that the defrost sensor is probably shorted. Replace the sensor assembly with part #6877A30013L. It includes the humidity sensor & defrost thermistor & plugs onto the main circuit board for an easy repair. Sears lists it on their website for 9.99 + shipping.
Jun 24, 2008 | LG DH404E Dehumidifier
Dehumidifier Error?
This error code indicates that the problem is most likely a shorted defrost thermistor or possibly a pinched wire going to the thermistor. You will need to replace the sensor assembly - part # 6877A30013L. The Sears website has it listed for 9.99 + shipping. The humidity sensor & defrost thermistor come together in a wiring harness that plugs onto the main circuit board. It is fairly simple to repair. Just remove the front & rear grill & the metal cabinet. Remove the thermistor from the copper tube on the cooling lines; remove the humidity sensor from the front of the evaporator; pull the wire plug off the bucket switch; & remove the small 7 pin plug from the main circuit board inside the metal control box. Reverse procedure to install new sensor assembly.
May 09, 2008 | Kenmore 54701 Dehumidifier
Dehumidifiers Logo
389 people viewed this question
Top Dehumidifiers Experts
Bill Long
Gil Shultz
jasbo
jasbo
Are you a Dehumidifier Expert? Answer questions, earn points and help others
