Question about Whirlpool Washing Machines
Filter cap stuck
Whirlpool wml520
I can't seem to remove filter the cap came off but I can't seem to get filter out
With the cap off the filer was not turned far enough for it to clear the locks. Grab the filter with a pair of pliers and turn it to the unlock position then pull it out.
Aug 14, 2014 | Whirlpool 21.8 cu. ft. Side-By-Side...
How do you get at the filter?
It should be at the front of the machine down the bottom or underneath th machine.
Apr 06, 2013 | Hotpoint WML520 Washing Machine
How do you take the cap off to check the filter is'nt blocked
Wheres drain plug usually at bottom front face filter often behind drain plug
Mar 23, 2013 | Hotpoint WML520 Washing Machine
How do i open the filter as we have tried and it wont come out on our whirlpool AWM1203
I assume your talking about the drain filter. If you are you would open the small access panel located down the bottom of the unit and turn the filter to the left in counter clockwise direction. It is best to have a small pan and a shop vac in place to vacuum up the water that will come out of this area. Note sometimes when the filter is stuck you can use a screwdriver across the two tabs to turn the filter. If you have any further questions message me back. Thanks again Rick
Jul 02, 2011 | Whirlpool AWM5125/1 Front Load Washer
Hotpoint - WML520 washing machine - Not pumping water
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} You could have a blockage in the sump filter or there may be a foreign object in the pump housing stopping it from working, there may be a faulty or lose wiring connection on the pump. Is the tub still full of water? If yes then try lowering the outlet hose into a bowl or bucket and see if any water comes out, if yes the system is clear and it would be pump related, if no then you have a blockage somewhere.
Mar 06, 2010 | Washing Machines
I can't get the bypass cap off to replace the
I just got my whirlpool fridge and I'm having the exact same problem! The blue cap appears stuck and I'm afraid I'll break it if I force it with a tool. Please post a solution if you get one - I'll do the same. Thanks.
Oct 23, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Need to replace or remove water filter cartridge from our Whirlpool refrigerator. Cannot turn the cartridge cap to the virtical position in order to remove it. It is stuck or frozen. Afraid to use...
Called company.  Have to eliminate water pressure by moving refrigerator out and turning off incoming water from line in back.  They said water pressure was preventing cartridge cap from turning.
Jul 18, 2008 | Whirlpool Refrigerators
Washing Machines Logo
13 people viewed this question
Dan Webster
Dan Webster
Sal De
