Question about Brother P-Touch Brother Pt90 Label Maker BRTPT90
I only have 2 options, small or large, for the size on my Brother PT-90 label maker. How can I double the height of the letters, not the length ?
I can't find anything in the manual to explain how to do this.
How do I change the font size
Hello,To change the font size, do the following: 1. Press the “Function” key 2. Press the “Left Arrow” or the “Right Arrow” key until the display shows “SIZE”. 3. Press the “Function” or the “Return” key. The current selected size setting is displayed and a triangle indicator pointing a sample of the character size above the display. 4. Press the “Left Arrow” or the “Right Arrow” key until the desired Size is displayed. * SIZE1 equals Standard Size. * SIZE2 equals Double Width. * SIZE3 equals Double Height. * SIZE4 equals Double Width & Double Height. * SIZE5 equals 4 x Width & Double Height. * AUTO, the machine will automatically adjust the characters to the largest possible size according to the width of the tape installed in the machine. Press the “Function” key or the “Return” key to select the characters size. I hope this helps.
Jan 04, 2016 | Brother P-Touch Brother Pt90 Label Maker...
PT 1280 suddently printing miniscule letters. Can't reset, have turned off using Shift/clear buttons, but doesn't change after settings redone.
What size tape are you using? If you have switched from half-inch to quarter-inch tape, then chances are that the printer is working correctly as the general size of the print is determined by the size of the tape. Beyond that, you can use the Text button at the top-center of the keyboard to enter the options for customizing the print such as the font used, the size (small, medium, or large), the width of the letters, and the style (such as bold, outlined, or shaded).
Jun 05, 2015 | Brother P-touch PT-1280 Label Printer
Brother p-touch model 1880 label maker- how do you change the font size
1. Press the "Function" key
2. Press the "Left Arrow" or the "Right Arrow" key until the display shows "SIZE".
3. Press the "Function" or the "Return" key. The current selected size setting is displayed and a triangle indicator pointing a sample of the character size above the display.
4. Press the "Left Arrow" or the "Right Arrow" key until the desired Size is displayed.
Press the "Function" key or the "Return" key to select the characters size.
I hope this helps.
Aug 09, 2010 | Brother P-Touch 1180 Label Printer
Model PT-1900/1910 operational manual is lost.
I assume that you need the manual for your printer.
Here you can download:
http://www.ptouchdirect.com/ptouch/manual/PT1900.pdf
On page 26-28 it explains what you need to do to change the size of letters.
Apr 09, 2010 | Brother P-Touch 1900 Label Printer
The barcode printing on the label is very large. I need it to be more 'compact'. How do I change? What are my options? Thanks.
Select the correct label size in the printer setup.Go to printing preference in driver and changet label width and height according to label which you use.Eg: 52MM and 25MM
when label is large double click the barcode and decrease font size according to your label size.
Aug 03, 2009 | Zebra S4M Thermal Label Printer
How do i change the font size on my P-Touch ModelPT-1880?
By pressing function button (Fn) and the number 1, you will get the choice between Large, Medium, Small and Max.
Also, you can press Fn, tap the left or right array until you get "Size" in the display, and then press OK to enter the size menu.
Jun 05, 2009 | Brother BRTPT65 PT-65 Label Maker Printer
Cannot remove backing
Bend the label in half length-wise
Mar 02, 2009 | Brother BRTPT65 PT-65 Label Maker Printer
Can't change the font style & size on my Brother PT-65 Label make
In case you've forgotten how to change the text size, hold down 'Code' and '& Size' key to display the current setting. While still holding the Code button, push and release the '&' key to change the size.
To reset, I would try removing the batteries for a few minutes before reinstalling them.
Just two guesses.
Jan 04, 2009 | Brother BRTPT65 PT-65 Label Maker Printer
Brother PT 65 Label Maker
i've never been able to change the font. just sizes, and make it BOLD, Italic, underlined ect.
only one style font however
Dec 31, 2008 | Brother BRTPT65 PT-65 Label Maker Printer
Brother Model Pt-65
There are two vertical fonts - small and normal. To put the labeler into vertical mode, hold down the [Code] key and tap the [J] key.
When it asks " 1-9 ", let go of the [Code] key.
Press the [8] key if you want small vertical type, OR the [9] key if you want normal size vertical type. Then you have to hit the [ <--' ] enter key.
Now you are stuck in Vertical mode ! :-O
To get back to normal, hold down the [Code] key and tap the [J] key, Let go of the [Code] key.
Then tap the [3] key and the enter [<--'] key. You are back to horizontal labelling.
:-) phew!
May 26, 2008 | Brother BRTPT65 PT-65 Label Maker Printer
Brother P-Touch Brother Pt90 Label Maker BRTPT90 Logo
85 people viewed this question
Top Brother P-Touch Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Brother P-Touch Office Equipment and Supply Expert? Answer questions, earn points and help others
