Question about Diesel Case 1370,1470,1570 Tractor Piston & Sleeve
1370 case fuel tank removal
How do you get it out
    Sergeant:
  • 226 Answers
It is as hard as it looks. one plate on each side of tank, slips out the back. If you can get unstuck from the dirt.
Posted on Dec 21, 2016
How to remove fuel tank
Remove the single screw or nut that holds the speedometer cas to the tank. carefully move the case forward and release from the front or the tand. disconnect the two or three plugs and the speedometer cable and remove the speedometer case. under the case you will find a bolt holding the front of the tank. remove it along with the rear bolt. Disconnect the fuel line and the petcock vacuum line on the left side and remove the tank straight up. As you remove the tank some models have a vent line on the right side under the tank that must be removed. Don't lose the rubber knobs that hold the tank straight. they are on the frame at the bottom of the tank. Good luck.......Jim
May 29, 2011 | 1999 kawasaki VN 800 Vulcan Classic
Tip
Garmin Nuvi 1370 Hard Reset Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi...
Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi 1245 , Nuvi 1250, Nuvi 1255, Nuvi 1260
Models: Nuvi 1300, Nuvi 1300, Nuvi 1310, Nuvi 1340, Nuvi 1350, Nuvi 1370, Nuvi 1390
Models: Nuvi 1410, Nuvi 1440, Nuvi 1450, Nuvi 1490
Does your Garmin Nuvi 1370 Freeze at Loading Maps?
Does it lock up or stop working?
This tip will describe how to perform a hard reset of the device, and how to backup your 'Favorites' in case the hard reset erases them. The next step in fixing your Nuvi when it doesn't start properly is to update its system software using Garmin WebUpdater.
A hard reset (or Clear All User Data) has been known to resolve unit quirks and strange behavior. It's generally recommended to perform it after a firmware update but is not required by any means. However, if you're seeing quirks and strange behavior with your unit after the firmware update, it is a good idea to do a hard reset of the unit.
Backup and Restoration Procedure for Favorites:
The Hard Reset procedure has been known to delete your Favorites, so back them up beforehand.
  1. From the Nuvi drive, copy '/Garmin/GPX/current.gpx' to a backup location on your computer.
  2. After the hard reset, copy your backed up 'current.gpx' from your computer back to the '/Garmin/GPX/' folder on the Nuvi, but be sure to rename it 'temp.gpx'.
  3. On the next power cycle, the Favorites will be read from 'temp.gpx' into the non-user accessible memory area on the Nuvi where they are actually stored.
Perform the Hard Reset:
*Note that this will clear all user selected settings on the unit
  1. Power the unit off.
  2. Remove the battery and wait several minutes.
  3. Install the battery.
  4. Press and hold (and continue to hold) the bottom-right corner of the screen while powering the unit on.
  5. Continue to hold the screen until the "Do you want to erase all user data?" prompt appears.
  6. Press "yes" and the unit will reboot. This resets all your location settings and user preferences.
If possible after the hard reset, let the unit sit outdoors in the open for about 30 minutes or so to let the unit re-acquire the satellite almanac data.
You have now performed a hard reset of your Garmin Nuvi 1370 series GPS unit.
I hope that helps.
__________________________________________
Garmin Nuvi 1370 Manual Download
Garmin Nuvi 1370 QuickStart Download
Garmin Nuvi 1370 Webupdate
Garmin Nuvi 1370 Favorites Backup
on May 15, 2010 | GPS
Tip
Download Garmin Nuvi 1370 Quickstart Manual
Have you lost your Owner's Quickstart Manual for your Garmin Nuvi 1370 GPS?
Would you like a digital copy of the Garmin Nuvi 1370 Quickstart Users Guide for easy searching of terms and quick reference?
The Nuvi 1370 Quickstart manual is available free in pdf format, just follow the photo link below:
I hope that helps.
________________________________________________
What is best way to replace fuel pump?
the fuel tank needs to be dropped , remove the fuel tank straps, then remove the fuel filler neck, then the connectors from the pump, then with help drop the fuel tank and slide the fuel tank away from the vehicle in case of fire.
then just remove the fuel pump using either the Ford special tool,. or a flat blade screwdriver and hammer to release the fuel pump holder
Feb 03, 2011 | 1998 Mercury Mystique
How do u get the fuel pump on
Removal & Installation To Remove:
  1. Before servicing the vehicle, refer to the precautions in the beginning of this section.
  2. Shift the vehicle into NEUTRAL and position it on a hoist.
  3. Release the fuel pressure.
  4. Disconnect the negative battery cable.
  5. Remove the fuel tank filler cap.
  6. Drain as much fuel from the tank as possible.
  7. Using suitable hose pinching pliers, clamp the fuel tank filler hose. Clamp the fuel tank filler hose in the location shown ford-05-00-396.gif
  8. Disconnect the three quick connect couplings from the fuel tank tubes at the tank.
  9. Disconnect the fuel pump electrical connector.
  10. Disconnect the fuel filter inlet tube from the filter.
  11. Position a suitable lifting device under the fuel tank.
  12. Remove the two fuel tank support strap bolts.
  13. Lower the fuel tank to access the fuel pump module while swinging the fuel tank support straps away from the tank.
  14. Clean the area around the fuel pump mounting flange.
  15. Disconnect the fuel pump module electrical connector and the fuel pump module fuel outlet tube.
  16. Using the special tool, turn the fuel pump module retaining ring counterclockwise and remove it. CAUTION
    The fuel pump module must be handled carefully to avoid damage to the float arm, filter and convolute hoses.
  17. Turn the fuel pump module counterclockwise and the fuel pump module will release from the locking tabs. Remove the fuel pump module from the fuel tank.
To Install:
  1. Install the fuel pump module in the fuel tank.
  2. Connect the fuel pump module electrical connector and the fuel pump module fuel outlet tube.
  3. Raise the tank into position and install the mounting strap bolts. Tighten the bolts to 26 ft-lbs (35 Nm).
  4. Connect the fuel lines and electrical connectors at the fuel tank.
  5. Lower the vehicle and refill the tank.
  6. Connect the negative battery cable.
  7. Turn the ignition key to the ON position to pressurize the fuel system.
  8. Visually inspect the fuel system for leaks.
Aug 19, 2010 | 2001 Ford Taurus
Tip
Download Garmin Nuvi 1370 Manual
Have you lost your Owner's Manual for your Garmin Nuvi 1370 GPS?
Would you like a digital copy of the Garmin Nuvi 1370 Users Guide for easy searching of terms and quick reference?
The Nuvi 1370 manual is available free in pdf format, just follow the photo link below:
I hope that helps.
Tip
Garmin Nuvi 1370 Hard Reset Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi 1245...
I hope that helps.
on May 15, 2010 | Garmin nuvi 1370T Car GPS Receiver
What are the steps to re-attach throttle to trigger and fuel line to tank on Mac 110? If the fuel line is attached first, the trigger seems impossible to reach and if the trigger is attached first, can't...
Did you remove the rear case first? That allows direct access to the fuel tank and line. I have found the throttle trigger connection to be the worst offender when the front case is removed to access the carburetor and ignition system. Hope this helps!
May 05, 2010 | Garden
Tip
I hope that helps.
Tip
I hope that helps.
Diesel Case 1370,1470,1570 Tractor Piston & Sleeve Logo
87 people viewed this question
Top Diesel Garden Experts
Dennis Key
Dennis Key
john h
Ted Maxwell
Are you a Diesel Garden Expert? Answer questions, earn points and help others
