I have tried every boot sequense I could find on the internet and nothing works. How do I find the motherboard number?
SOURCE: My Toshiba Satellite L300D keeps shutting down when I start it up
restart in bios setup
then click to default settings press f10 to save and exit
if problem persists let me know
don't forget to rate
SOURCE: toshiba satellite a135 s2386 will not boot
have you pulled out the battery as well or hold down the power button for 10 seconds, then try it again. that did it for me just a thought toshiba told me too pull out the battery once it was going then put it back.... sorry am not an expert
SOURCE: need to unlock BIOS password
Unfortunately there is no easy fix. Removing the CMOS battery does not work nor are there jumpers on the MB. The only way to get it reset is to go to an authorized Toshiba dealer or repair facility and have them do it. This is going to cost you since normally it is not covered under warranty.
SOURCE: forgot password for bios
Hi Arthur Clarke,
Did you set the BIOS password for your notebook or was it set automatically by the computer? Anyway, to solve this problem, you may need to bring out your system to a near Toshiba ASP.
If you need further assistance or information regarding your problem, call Toshiba Tech Support (800-457-7777). Hope this helps.
SOURCE: what cable do i need to plug a toshiba satellite
depend on yr tv and laptop, normaly use hdmi cable to connect laptop and tv
