Question about Citizen CT-S310 Printer
Ct s310a faint print
Printer faded print
Why my hpC6100 printer is not printing blk
It went out, You have to put a new cartridge inmediatly. As soon as you notice a faint color you should have a new cartridge available, You hurt your print nozzel when you print without ink.
Jul 25, 2014 | HP Office Equipment & Supplies
Prints pictures faded
On the pixma printer each time you remove a cartridge. you will need to do a clean of the nozles and print head. you can find instructions in your online operators manual. You hold down the wi-fi button and watch the
Home Click Here to Search
MG3500 series > Overview of the Machine > Maintenance > When Printing Becomes Faint or Colors Are Incorrect
Maintenance Procedure
Printing the Nozzle Check Pattern
Examining the Nozzle Check Pattern
Cleaning the Print Head
Cleaning the Print Head Deeply
Aligning the Print Head
Page top
error light flash. 1 flash release prints all saturation levels2 flashes prints the head alignment chart. 3 cleaning 4 flashes deep clean and so on. or its a transfer problem and this case do a transfer belt clean, and a head alignment.
Feb 28, 2014 | Canon Ink Cartridge for Pixma MP252
Faded strip
Hi, faded strip or faint printing is cause by the drum as the toner distribution is uneven.
Dec 17, 2013 | Samsung CLP 300 Laser Printer
Printing is faint on edges of documents. I have a CLP-300 printer, when I print the edges of the sheet are very faded, but the center seems to be fine. Any ideas what would cause this?
If your printer prints like this with areas printing faintly,
The problem is with the developer in the imaging unit. The problem can be fixed by either replacing the imaging unit for $100+ or you can fix it yourself by cleaning the imaging unit. You will need simple hand tools and if you are careful restore the print quality of your printer. I have a link to instructions that should help you http://www.fixya.com/support/r4120906-clean_developer_blades_samsung_clp_300 Hope this helps you.
Dec 08, 2010 | Samsung CLP 300 Laser Printer
Print's faintly
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&objectID=c01393223&prodTypeId=18972&prodSeriesId=501044
this may help you fixing the problem.
rate this solution.
Jan 12, 2010 | HP Office Equipment & Supplies
Printed pages contain contain traces of (faded)
I solved this by indicating I was using Recycled paper in printer properties.
Gisele
Jan 08, 2010 | HP Color LaserJet 2600n Printer
Hp 2600n faded printing
you need to take the scanner out (not very easy to do)unless you are a printer tech.
and clean the mirrors.
Sep 14, 2009 | HP Color LaserJet 2600n Printer
Black printing faded although toner not low
The black developer is defect, you have to call the service to solve this problem. and install FW Update V1.29.12.35
May 27, 2009 | Samsung CLP 300 Laser Printer
Won't print but few lines til black fades out
It pretty much sounds to me like you have "outdated" or old cartridges. Are you using the photo setting to print photos? Before you purchase more expensive cartridges do a head cleaning! Good luck.
Dec 16, 2008 | Dell 924 All-in-One InkJet Printer
Ricoh Aficio CL 2000N printing problems
If the colors are good and solid with no fades, only black streaks, then black is the culprit. I suggest replacing the black cartridge.
Feb 20, 2008 | Ricoh Aficio CL2000N Laser Printer
Citizen CT-S310 Printer Logo
65 people viewed this question
Top Citizen Office Equipment & Supplies Experts
jay kaye
jay kaye
Roy May
Are you a Citizen Office Equipment and Supply Expert? Answer questions, earn points and help others
