Question about SewShop.com Singer Model 9030 Instruction Manual
Install Apollo Bobbin Case in 9030
My Singer 9030 had a broken Bobbin case. I purchased a new one and need to know how to install it.
2 Suggested Answers
SOURCE: bobbin case jumps out of position when sewing on Singer 6412
Bobbin might be too low on thread, needs more weight to hold it down.
Posted on Aug 30, 2014
My needle hits / bottoms out on the bobbin holder and hook assembly. Do do I need to fix timing
there are several things that may cause this situation.
the needle may not be seated all the way up where it is supposed to be.
here is a site that may give you more insight.
How can fix the needle hitting the bobbin case on my sewing machine
Mar 05, 2015 | Singer 8763 Curvy Computerized Sewing...
How do I replace a singer 4212 bobbin case correctly?
I would go to Google or IE and paste the question in their search box. You should get several opinions.
Nov 27, 2014 | SewShop.com Singer Model 4212 Instruction...
Bobbin mechanism case popped out of my Singer 9020. How do I get it back into the machine?
this is a link to the manual for your machine. It shows you how to insert an fully wound bobbin. http://www.manual-hub.com/manuals/singer-9020-1-pdf-manual.html
Oct 20, 2014 | SewShop.com Singer Model 9020 Instruction...
Bobbin case jumps out of position when sewing on Singer 6412
Aug 30, 2014 | SewShop.com Singer Model 6412 Millennium...
I bought a singer lockstitch 2000 at a yard sale. it came without an instruction manual and i cannot figure out how to load the bobbin correctly
Hi. I'm not familiar with your model, but in most cases, one would set the bobbin into the bobbin case, pulling the tail through the tension and letting a couple of inches of thread hang out. Insert bobbin case and bobbin together as one unit, with the bobbin on the inner side towards the hook. It should snap into place only one way and should require very little effort.
Sep 14, 2011 | Vacuums
I amhaving trouble with the thread brahing and I don;t know if it is the tension. Which way should the pobbing turn right or left and how do you set the tension For my Singer sewing machine
Check the upper threading and make sure it is threaded correctly. When you pull on the thread before it goes through the needle does it give a bit or does it break? If it is breaking when you pull then the tension is way too tight or it is threaded incorrectly. Make sure it isn't looped around some guide along the line too.
For the bobbin thread... when it is in the bobbin case outside of the machine dangle it by the thread. It should hang there until you flick your wrist a bit, which should cause some thread to release and drop the bobbin down towards the floor a bit. (If it just pulls out right to the floor it is too loose). Most bobbin tension is tightened by a small screw on the bobbin case near where the thread comes though. Breaking thread would not be from the bobbin thread being too loose. Too loose would cause looping on top side of the stitch not breakage.
Make sure the bobbin is in correctly. You should feel and hear a slight "click" when the bobbin goes in correctly.
Apr 26, 2011 | Singer Vacuums
SewShop.com Singer Model 9030 Instruction Manual Logo
Top SewShop.com Vacuums Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a SewShop.com Vacuum Expert? Answer questions, earn points and help others
