Question about Dell XPS M1530 Notebook
HOW TO REMOVE SPACEBAR KEY
KEY NOT WORKING
How to safely remove spacebar key Dell XPS M1530 Notebook
Danyent,
You can click the link below for information on removing your spacebar key on your keyboard.
How to remove a key on your laptop keyboard
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Dec 07, 2013 | Dell XPS M1530 Notebook
Logitech DInovo edge spacebar not working
try to remove dust in your keyboard by using paint brush or compressed air.
Nov 05, 2013 | Logitech diNovo Edge 9676850403 Keyboard
Spacebar and b key won' work
Did you try removing and re seating the keys?
What keyboard layout are you using ?
Jul 26, 2012 | E-Machines Computers & Internet
I broke my spacebar off my laptop gateway computer! How do i fix this?
Of all the keys on the keyboard, replacing the SPACEBAR is probably the most difficult. The SPACEBAR is kept even by a metal wire that is inserted into slots on each leg of the plastic bar key. However, you have to get the wire into the slots without depressing the wire. If you push the wire down, you compress the wire and installation becomes impossible. As a general rule, do not remove the SPACEBAR unless absolutely necessary. If you remove the SPACEBAR, remove several surrounding key caps also. This will let you get some tools under the SPACEBAR wire later on. Once the SPACEBAR is reinserted, you can easily replace any of the other key caps.
Jan 19, 2011 | Gateway 2520915 Keyboard
IBM Wheelwriter 10 Series II Typewriter 6783. Spacebar suddenly does nothing. Everything else functions fine. Removed spacebar key and vacuumed dust underneath. When investigating possible problem we found...
you will need to replace the keyboard. we see this alot,keyboard starts to fall apart due to age. batteries are only used to hold tab and margin positions in memory. machine works fine without batteries.
Dec 15, 2009 | Televison & Video
How do I reseat the space bar on the mx 3200 . the logitech keyboard accummulates cat hair behind the keys, easily removed. But the space bar has a spring and white gunk and does not reseat easily. Mine...
Use a credit card or plastic Id, insert it and bend it gently. If it fails, you can use 2 cards, one on each side of the spacebar.
If after all you are unable to remove the spacebar, try removing the keys around it, just remember their distribution.
Beware, the spacebar is a little more complicated to put back in place compared to the other keys, as you said, there is a spring.
Sep 04, 2009 | Computers & Internet
Keyboard Failure
Buy a new one.not worth fixing.RICHARDM69
Aug 31, 2009 | E-Machines AAFQ50400000K0 Keyboard
Spacebar is super sensitive. You barely touch it and it goes two,three or more spaces between words.
the spacebar key is misaligned. you may try removing the cap but putting it back is a pain the @ss, and usually does not work. if this is within warranty, call dell and have it replaced for a reason that the key popped out
Apr 30, 2009 | Dell Inspiron 6000 Notebook
Spacebar key wont click back on
get a new keyboard...those springs that need to go under the keys if you loose them they never function the same.
Feb 14, 2009 | Compaq Presario C700T Notebook
Dell XPS M1530 Notebook Logo
14 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
