Question about Motorola Mobility Bluetooth Hands Free Headset Wireless Headset
I can't connect s10 dh to my ipod touch
How do I do it?
Tip
How to convert 220 volts to 110 volts for the iPod Touch
<p> <p>The battery of an iPod Touch prepared for use in the United States is designed to be reloaded from the current supplied by a 110-volt electrical system. Power is transmitted to the battery charger with an iPod battery, which are connected via a USB cable and then connected to a 110 volt outlet. To use the power of a 220 volt outlet with an iPod Touch, set the current 220 volts to 110 volts. A conversion adapter voltage, also known as "Step Down Transformer," it is necessary and can be obtained from an electronics store, a hardware store and even some drug stores. <br /> <p><br /> <p>1. Place the 220-110 voltage converter card (aka, "Step Down Transformer") next to a 220 volt outlet. Plug the adapter into the outlet. <br /> <p><br /> <p>2. Connect the end of a USB cable to the USB connector USB iPod charger iPod. Connect the other end of USB cable into your iPod's own socket on the bottom of the iPod Touch. <br /> <p><br /> <p>3. Plug the iPod into the 110 volt outlet in the battery adapter for the iPod Touch. <br /> <p><br /> <p>4. Unplug the charger from the iPod adapter and the adapter from the outlet when the battery is charged. Unplug the USB cable from the iPod charger and iPod Touch. <br />
on Aug 09, 2011 | Apple iPod touch
Tip
How do I Connect my iPod Touch to a Netgear WNR2000 Router
<p>Netgear WNR2000, a wireless-N router, you can connect to the Internet without the hassle of cables. IPod touch supports Wi-Fi (wireless) connections. If you're within range of the router, you can connect to the wireless network. Once connected, enjoy a fast transfer speeds that allow you to quickly scroll pages and run the programs enabled network. <br /> <p><br /> <p>1. Connect the iPod Touch. Tap Settings on the Home screen settings of media player to start. <br /> <p><br /> <p>2. Scroll through the settings when you come to "Wi-Fi, tap to activate the feature. IPod touch detects networks in range. <br /> <p><br /> <p>3. Select the Netgear WNR2000 Wi-Fi network can include the name has been set, so it helps to know the name. If a secure network, enter the password. If you do not know the password, your iPod Touch cannot connect to the network. Once selected, your iPod automatically connect to the network. The Wi-Fi icon in the status bar at the top. <br /> <p><br /> <p>4. Select "ON" next "Ask to Join" if you want your iPod touch to ask you to connect to wireless networks within range. <br />
on Aug 05, 2011 | Apple iPod touch
I have an 8 gb ipod touch that is now disabled because I can't remember the 4 digit code. The message on the ipod's screen says 'ipod is disabled. Connect to itunes.' The computer that I originally used...
connect your ipod to itunes and then click on your ipod. then click on updater and your ipod should be good as new.
this process is all on the computer.
May 20, 2010 | Apple iPod touch
IPod touch Digital Media Player: i have an ipod touch and it claims i have full int...
This is most likely a problem with the internet connection itself. There are a few things you might need to check. First, an iPod touch will usually only work on a Channel 6 internet connection, though it can connect to other channels. Second, you should make sure that there is an internet connection with the wireless network, and that it's not local only, but instead local and internet.
May 17, 2010 | Apple iPod touch
Tip
How do I Download WiFi on my iPod Touch
<p>Apple iPod touch comes with several features that distinguish it from other iPod devices, namely the touchscreen navigation interface. Another unique possibility for the iPod Touch on iPod is the device built-in wireless adapter, allowing you to make the Web browser, e-mail and web-based mobile applications. Internet access to an iPod Touch you need to download anything, but to connect the wireless adapter and search for networks. <br /> <p><br /> <p>1. Connect your iPod Touch or if it is already connected, touch iPod touch "Home" button to return to "Home" screen. Touch the "Settings", indicated by a series of gears of silver. <br /> <p><br /> <p>2. Tap "Wi-Fi." Touch the white "Off" to switch wireless adapter box. If a blue button "On", then your wireless is already enabled. <br /> <p><br /> <p>3. Scroll through the list of wireless networks that appears, and play what you want. Password input of the network, if necessary, and tap "Join". <br />
on Aug 05, 2011 | Computers & Internet
Tip
How do I update my iPod Touch updated to 3.2
<p>Apple iPod Touch is a touch-screen iPod that contracts with the iPhone and iPod parts. To update the iPod Touch, iPod Touch you have to program a computer running iTunes 3.2. Update the iPod Touch is free and takes only minutes. <br /> <p><br /> <p>1. Connect the iPod Touch to your computer using the USB cable that came with the iPod Touch. <br /> <p><br /> <p>2. Let iTunes opens automatically when the iPod Touch is connected to the computer. <br /> <p><br /> <p>3. Click the name of the iPod on the left side of the screen. If the iPod does not have a name, it will read "iPod". <br /> <p><br /> <p>4. Click "Sync" in the lower right corner of the iTunes program. Disconnect the iPod Touch during the synchronization process. Progress, looking at the status bar at the top of the iTunes program. <br /> <p><br /> <p>5. Disconnect the iPod Touch as the synchronization is complete. You said that the synchronization is complete by reading the status bar at the top of the iTunes program. He will tell you that it is now safe to turn off your iPod Touch. <br />
On my ipod touch, it says that ipod is diasabled and connect to itunes. when i connect my ipod touch to itunes, itunes say that itunes cannot connect to ipod touch because it is locked with a passcode. i...
this is the solution for this kind of issue. please try it. It might work on your ipod touch.
please click here
hope this helps . . . please don't forget to vote for this solution if this works for you :) . . . thanks
Apr 12, 2010 | Apple iPod touch
Ipod touch connector
Hello serafineb,
The Alpine Full Speed cable for the iPod supports the following versions:
Fourth generation iPod
Fifth generation iPod
iPod photo
iPod mini
iPod nano
According to their website it does not appear that Alpine currently has a cable for the iPod touch. They do, however, make a "generic" cable for most MP3 players that connects directly to the earphone jack. Although this would not allow you to control the iPod from your stereo's head unit, you should be able to connect the iPod touch via this cable to play music through your car stereo.
More information about the "generic" cable can be found here.
Best Regards,
Ken
"Go Ahead. Use Us."
Jun 17, 2008 | Apple iPod touch
Ipod not getting connected to itunes nor getting charged, and please recommend which ipod converter to download. Thank you in advance my ipod is not charged, when connected to a computer
hello!
if your IPod touch is not connected to itunes, please try the ff:
Check the iPod touch Display
-- When you connect iPod touch to your computer, the iPod touch should display an image or message on the display
-- If you do not see any image, check some basic troubleshooting here: http://support.apple.com/kb/HT1737
-- If you see a message on the screen, this indicates that the iPod touch does not have sufficient battery charge to operate and will need to be charged for several minutes before it can be recognized in iTunes.
Verify Windows PC System Requirements
--iPod touch requires iTunes 7.4 or later
Check USB Connections
-- iPod touch requires USB 2.0 to function properly
-- Try connecting iPod touch to a different USB port, preferably a port that is built-in to the computer instead of an external USB hub. Connecting iPod touch to your keyboard's USB ports is not recommended.
Restart your PC
-- In some cases, your computer's USB ports may become temporarily disabled or you may experience other software related issues. Restarting your PC is an easy troubleshooting step that may resolve this issue.
Verify iPod touch Driver/Service Installation
-- iPod touch requires two important pieces of software to operate properly on Windows. First, the driver must be installed; for iPod touch the driver is USBAAPL.SYS. Second, Apple Mobile Device Support must be installed as a Windows Service.
May 08, 2008 | Apple iPod touch
Motorola Mobility Bluetooth Hands Free Headset Wireless Headset Logo
14 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
