Question about Seagate (ST3500601CB-RK) (ST3400601CBRK) 400 GB Hard Drive
Seagate Drive is asking to be reformatted?
I have a ST3400601CB-RK (Seagate 400GB Pushbutton Backup - External HD). I have used this drive for 2-3 years on both windows xp and vista with no issue what so ever.
Today I plug it in (to a windows machine) and it is saying that the drive must be reformatted? I assume if I do this I will loose all my data on this drive. Is this assumption correct?
I tried to plug this drive into my mac as well. Same request for formatting before use?
I have read though many of the posts about powering down and some "simple" solutions. Can someone point me to a thread that shows how to get the data off the drive. I have only stored data (pics, docs, movies, etc; no applications) on the drive.
  • 57 Answers
Yes your assuumtion is correct, you WILL loose all your data.
I have been there before.... and the outcome was not good.
If your PC will recognize the drive and give it a drive letter, you can run chkdsk (Check Disk) from the Run prompt to verify that the drive does not have damaged sectors. many times chkdsk will fix minor errors allowing you to access the drive again.
Click Start, Run CMD, enter, then type: X: (X being the drive letter of the Seagate) then type chkdsk /r and hit enter. If it completes 100% try accessing the drive again.
If you cannot acquire a drive Letter when you plug in the Seagate try going to Disk Management and assigning a drive letter.
Click Start, then Right click on My Computer and click Manage, then click Disk Management. See if your Seagate drive shows up in the list. If it does, right click on the larger box on the right and see if it will allow you to assign a drive letter.
Another option you may have is taking the hard drive out of the Seagate enclosure and either connecting it as a secondary drive in a desktop PC, or installing it into another external enclsure USB device, and try again to access the drive.
If none of these options work, your last option is to contract a Disk Recovery Service to acquire your data. They are usually very expensive.
Posted on Jun 15, 2009
I have a Seagate 3.5 inch pushbutton backup external hard drive, M# ST3400601CB-RK that states that it needs to be formatted. I would like to remove the hard drive and put it as a slave on another PC. ...
Attaching it to another PC will just move the problem to the other PC. USB drives frequently have the problem you are seeing.
You can have your partition and data restored remotely by this guy. http://FreeDataRecovery.us
May 27, 2011 | Seagate (ST3500601CB-RK) (ST3400601CBRK)...
Please i need the power adapter rating for seagate
Have you got the original power adapter?
If so the voltage details are printed on the label on the bottom of the adapter.
If the external USB Seagate hard drive houses a 31/2" drive then it requires an power adapter that provides +12 volts and +5 volts both supplying approx 2000mA of current.
If the Seagate uses a 21/2" (laptop) hard drive then it only requires +5 volts power adapter.
The only problem is the power connector to the external drive, make sure it suits the external hard drive unit and the power pins are correctly wired for the Seagate. If the polarity of the plug is incorrect lt wired (ie reverse polarity) then it could damage the USB hard drive and adapter case.
Nov 20, 2009 | Seagate (ST3500601CB-RK) (ST3400601CBRK)...
Lost power supply for Model#ST3400801CB-RK
The power supply for this drive is not ordinary. This means it has two pairs: 5.0V (1.5 A) and 12V (1.5 A) of power pins
http://www.ixbt.com/storage/maxtor-ext/seag400gb/powersup.jpg
Connector is S-Video like type
Feb 13, 2009 | Seagate 400GB 7200rpm External HDD Retail...
I reformatted my C: drive and ever since Windows will not recognize my Seagate External Free Agent hard drive. It shows up under ?My Computer? as Removable Disk (I: )? It used to be listed as Seagate...
Try connecting it to another computer. If you can see your data then back it up etc.
After you have recovered your data connect it to your computer, from Disk Manager, remove the partition, recreate it again and then format the drive, hopefully your external drive will be operational again.
There is a possibility that the hard disk has died and you will have lost your data. If you are desparate, hard drive data recovery companies charge an arm and a leg to recover data from dead drives.
Jan 10, 2009 | Seagate Free Agent Go Small 12 GB USB...
Help!
You have not yet formatted the drive to work with you MAC. You will need to use your MAC's Disk Utility to format the drive in order to write to the drive, but be aware that formatting will erase everything already on the external drive, so back up anything on the drive you want to keep first.
May 29, 2008 | Seagate 400GB 7200rpm External HDD Retail...
Help for Seagate Free Agent 500 GB external hard drive
465.66 x 1024 x 1024 x 1024 = 499,998,617,764 bytes. The problem is the definition of gigabytes.
May 10, 2008 | Seagate Free Agent Go Small 12 GB USB...
Power supply for Seagate 400GB
Ebay or seagate.com may be a solution.
I've used those Seagate portables and 2 have caused problems.
Or disassemble the unit, remove the drive and buy a portable case or USB adapter.
Oct 16, 2007 | Seagate 400GB 7200rpm External HDD Retail...
Seagate (ST3500601CB-RK) (ST3400601CBRK) 400 GB Hard Drive Logo
146 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
pankaj rautela
pankaj rautela
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
