Question about Sharp 13VT-R100 13 in. TV/VCR Combo
Tv won't turn on with remote or start button on tv
Won't turn on, just makes a clicking noise
3 Suggested Answers
SOURCE:
nick_vitelli
SOURCE: DVD won't eject
Manually pull the door open. If you can see the motor spinning in there it may have a rubber "band" that looks like and O-ring. If that is broken then it can be replaced but it is a difficult manuver with a screwdriver. They tend to dry rot like all rubber parts and fail...
Posted on Feb 23, 2012
gopakumarg43
  • 76046 Answers
SOURCE: Sharp Aquos tv model LC GP1U won't turn on
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Posted on Jul 14, 2016
Zenith a27b41w won't turn on. It just clicks whether using the remote or the button on the tv
Probably a power supply problem. The click could be a relay closing
Nov 04, 2012 | Televison & Video
My remote control for my lg flat screen tv not working i changed the batteries and the light won't go on
Take the remote to any working radio, change radio band to SW, press various buttons of the remote and if you can listen to some clicking noise on the radio, the remote is ok. The problem might then be on the sensor and might need attention by a qualified service technician. You can also try switching off the TV, removing the plug and retry after 48 hours.
Aug 02, 2012 | LG Televison & Video
My samsung tv is making clicking noises and won't turn on
Clicking noises may mean a power supply voltage is not staying correct or that board is bad---a suggestion: visit shopjimmy.com who has by model number a list of all the boards used in almost every Samsung Flat screen set made.
Jun 17, 2012 | Samsung Televison & Video
Rca 24" tv remote won't operate tv
If set turns on with the power button on set the remote is : not set to TV, not programmed for the set, has bad batteries or is bad.
If it even works one function it may need to be reprogrammed or taken apart to see if works---you can test the remote by pointing it at a digital camera with a LCD screen and pressing buttons to see if it makes the screen flash on the camera.
Test the remote first
Apr 09, 2012 | RCA Televison & Video
How do you turn off the FPA lock on the RCA TRUFLAT TV? I Can't access menu.
Hello
First of all, you must ahve its original remote control to unlock FPA lock. If you have it, go through the folloing steps.
* Hold down Menu button on the remote control, and the Volume Down button on the at the same time for at least 4 seconds. "The set won't say so, but the lock will be released".
** Hold down Zero button on the remote control, and the Volume Down button on the TV. The set won't say so, but the lock will be released.
*** Hold down Menu button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds. The set won't say so, but the lock will be released.
Mar 11, 2012 | RCA TruFlat 27F520T 27" TV
My RCA Truflat T.V won't turn on and the FPA lock is turned on, I have the original remote. what should i do?
TV won't turn on • Press the TV button. Make sure the TV is plugged in.• Check the wall receptacle (or extension cord) to make sure it is "live" by plugging in something else.• Something might be wrong with your remote control. Press the POWER button on the front of the TV. If the TV turns on, check the remote control solutions on page 26.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).Buttons don't work
• If you're using the remote control, press the TV button first to make sure the remote is in TV mode.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).• Unplug the TV for two minutes and then plug it back in. Turn the TV on and try again.TV turns off unexpectedly • Sleep timer might have been activated. Go to page 24 for instructions.• KidPass might have been activated. Go to page 21 for instructions.• Wake-Up timer turned on the TV and no remote or front panel buttons were pressed for two hours.• Electronic protection circuit may have been activated because of a power surge. Wait 30 seconds and then
turn on again. If this happens frequently, the voltage in your house may be abnormally high or low.
• Unplug TV. Wait five minutes. Plug it in again.
Sep 16, 2011 | RCA 20F420T 20" TV
Hi our tv just won't turn on any ideas? We have pluged it into another power source and checked the cable . the cable is fine. thanks
If it does not turn on then it is usually due to a component level failure on one of the boards. Does the LED at the front blink or just stay on? Does it make a clicking noise like its trying to turn on when you press the power button on your remote? Also please let me know the make and model of the tv. Please provide this info so that I can offer you insights into the cause of the problem and how to fix it.
Sai.
May 28, 2011 | Televison & Video
My Magnavox plasma screen tv, model number: 42MF237S/37 makes a clicking sound when I try to turn it on. No sounds, no picture, just the clicking noise. Things I have tried so far: 1) Turning the TV off...
You either have a cold solder joint in your horizontal deflection circuits or your or in your horizontal output circuit. please be careful due to the fly-back transformer still holds power even unplugged until you discharge it.( ground it out). Hope this helps.
Jan 03, 2010 | Philips Magnavox 27MS343S 27" TV
Clicking noise when turning on the tv. Everything works but the clicking.
When you turn your tv off turn it off using the remote control then turn off the tvs switch itself... Try this for a few days hope it works for you.
Thanks.
Jun 22, 2008 | Akai PT5492S 54" Rear Projection...
Sharp 13VT-R100 13 in. TV/VCR Combo Logo
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
