Question about Whalen Furniture " - High Console TV Stand for Flat-Panel TVs Up to 65"" BBHC60DBC"
Console is sagging in the middle, doors don't close right.
Console is 5 months old and nothing is heavy in it.
Why won't door on Samsung side-by-side refrigerator stay closed? Pops open after closing, like the seal isn't working.
The door isn't lining up right when it's closed. I suspect you have been putting heavy stuff on the door racks, like several 2 liter soda bottles or gallon jugs of milk. Over time the door will sag from the weight until it won't stay closed.
Nov 06, 2014 | Samsung RSG307AABP 30 cu. ft. Side by Side...
Door sags open when hot.
i just had this problem with a jenn air range i was repairing, installed new hinges door closed fine, heated oven hit 200 degrees and light came on (door opened slightly) as per techline I shimmed the hinge reciever to make a bit tighter. sure enough!!! been 3 weeks she hasnt called back yet (and trust me if it didnt work she would!.. call the tech back and have him call the tech line while in home
Mar 13, 2008 | Frigidaire PLCS389DC Dual Fuel (Electric...
What is the plastic knob under the door hinge used for on kenmore model 7803 refrigerator?
Most modern fridges have these small plastic knobs [usually both top and bottom]. They are usually only COVERS for threaded mounting holes so that the fridge/freezer doors can be mounted for either left OR right opening ... ok They are generally around 1/2" [13mm] in diameter x 1/8" [3mm] in height.
They also help support the door [when it is closed] and prevent any "sagging" and/or mis-alignment or distortion of the fridge door which [these days] can be quite heavy when fully loaded.
Oct 20, 2014 | Kenmore Refrigerators
Driver side door sags.
If your door sags it means the bushings in the door hinge are worn out, but there is a way to adjust it without replacing the hinges if they aren't too bad. If you open your door there are bolts that attach the door hinges to the A-Pillar, most of the time they are accessable from the outside. First get a car jack and position it under middle edge of the open door, put a small piece of wood on the jacking point to protect the door. Loosen the bolts to the hinges and raise the jack so it raises the door up. tighten the bolts on the hinges back up and open and close the door to determine if the door was raised enough to eliminate the sagging.
Jan 25, 2011 | 2002 Pontiac Sunfire
Garage door has a dirty grease mark down middle of door as if chain or something is rubbing on it.as it opens. When I watch it opens it appears that nothing is even coming close to door as it opens and...
When the door is opening the chain on one side of the rail is pulled tight and the opposite side sags. It is just the opposite when the door is closing. It could be the sagging side is rubbing against the door but it seems you would have seen this. Also the chain shouldn't have grease on it. Just a light coat of lubricant from the factory. You might try tightening the chain just a tad.
Nov 11, 2010 | Sears Craftsman LiftMaster Chamberlain...
WITH MY LIFT-MASTER DOWN FOR PARTS,I'VE BEEN USING THE MANUAL MODE UNHOOKING THE TROLLEY& LIFTING.I'VE USED THIS BEFORE WITH OUT MUCH EFFORT,NOW ITS REAL HEAVY.THE DOOR CLOSES UN-EVEN WITH RIGHT SIDE...
You are probably having either spring or lift cable troubles with the door since it is so heavy. A bad running door can strip the gears quicker than anything though. You will have to look inside the unit to see. Thanks BB
Sep 02, 2010 | liftmaster Chamberlain Garage Door Opener...
Freezer door on Kenmore AS-18 is sagging
I have this fridge and the sagging door means that you are missing a plastic washer. you might have accidentally placed this washer on the top rather then on the bottom where it belongs.
Jan 04, 2010 | Kenmore 18.3 cu. ft. Top Freezer...
Garage door chain is sagging
If the chain is adjusted properly the chain will sag slightly on one side when the door is closed and on the other side when it is open. It should not sag enough that it is dragging on the T-rail. You can adjust it at the trolley. If you over tighten it you will hear a clicking sound when the opener opens or closes.
Jul 28, 2009 | Sears Craftsman LiftMaster Chamberlain...
The freezer will not get cold, i replaced the defrost timer and the t-stat inside the freezer, and it keeps icing up, the heating element does work, the unit is only 2 years old
Turning it down a 1/2 to 1 knotch id try, the Whirlpool recommended is 0-5 degrees in freezer, im sure you have already cleaned coils.
So my last recommendation is the door. Ensure is closing and sealing. Sometimes the hinges wear out and the door sags, seals but sags causing humidity to get in and freeze up.
Try slipping a piece of paper between seal and door, if it goes right in its sagging, just make sure you check the whole area this way.
May 02, 2008 | Refrigerators
Bosch 500 series Front Load Washer Door hanging a bit lower than when purchased
Even if you do not realise it most people lean on the door as they open it, to rectify with the door open but almost in the closed position lift the door by pulling up on the door catch end, this will straiten the hinge, very common problem Regards Engineer
Jul 26, 2007 | Bosch WFMC 3200 Front Load Washer
Whalen Furniture " - High Console TV Stand for Flat-Panel TVs Up to 65"" BBHC60DBC" Logo
Top Whalen Furniture Furniture Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whalen Furniture Furniture Expert? Answer questions, earn points and help others
