Question about Ariens 46 in. 20 HP Hydrostatic Riding Lawn Mower
Do you have any trouble with safety switches
Will not start new battery in it worked fine turned it off now will not click or nothing
I have a 88 Plymouth horizon was running fine And all of a sudden I turned the key on and nothing happened I changed the battery new ignition relay and still nothing can anyone tell where to find wiring...
Try holding key in start position while moving shifter slowly through all gears to see if you get a click or start at all. Safety neutral switch/back-up lights on transmission were known to cause that problem.
Feb 28, 2015 | 1988 Plymouth Horizon
I have a riding yard machine mower. Had trouble starting without jumping the battery. Bought a new battery & it started right up. Mowed the front & side of the yard & shut it off to open my...
Now you are describing 2 different problems... If you have nothing I doubt the battery is dead but would check for a safety switch problem. If it clicks or turns over slowly then we need to be looking at a bad connection or other issues... Please describe your problem better to let us help you solve it
Nov 13, 2013 | Yard Machines 155 Torque Briggs Stratton...
Lights work, radio works battery is new and fully charged but when I try to start it...nothing. No starter clicking..nothing
A mechanic would check for voltage at the starter. You should have battery voltage on the large cable, and power on the small wire when you turn the key switch to start.
There is a clutch switch or neutral safety switch in the circuit between the starter and the key switch that could have failed.
Jan 08, 2013 | 2001 Kia Rio
I bought a brand new starter and new battery in the last 7 days. When I try to start my car, the engine does not engage, instead, all I get is a loud rapid clicking noise. Does anyone know what it mig
I guess I will start by saying we can only guess because we are not there in person.
My first question would be, where is the noise coming from ?
If it is the starter, you could have missing teeth on the flywheel and nothing for the starter to engage.
Depending on the make model and year, if you have a starter relay other than the one on the starter it could be faulty.
As long as you have 12 volts and a couple hundred amps of power at the starter post, and a good ground, the starter should turn. If the neutral safety switch was faulty you would get nothing when you turn the key. And the alternator would not come into play until after the engine starts.
Can you turn the engine by hand ?
Can you jump the starter with a screwdriver or jumper wire and make it turn ?
Dec 11, 2012 | Cars & Trucks
Car won't start
A mechanic would check for voltage at the starter, the neutral safety switch, and the key switch. Also check the ground connections.
Jul 30, 2012 | 1991 Plymouth Acclaim
Car won't start. its got a hot battery. Turn key, dash lights up but does nothing,not even click. got under car to ckeck starter used screwdriver on selonoid and it turned over fine. turn key switch...
If your car rolls over when you short the selonoid then the possibilities are limited.
The most likely is your neutral safety switch
the others are the ignition switch or damaged wiring.
Jun 11, 2010 | 2002 Pontiac Grand Am
Nothing happens when you turn on the lawn mower key for craftsman mower model 917 272072. I put a new battery in the mower, and new switch and a new solenoid switch but the mower don't make any noise when...
Check your seat, drive safety switches. Can you turn the engine with jumper cables attached to the starter? It won't start, but should turn over, one of your safety switches is not working.
Apr 16, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Ignition problem
Check the starter fuse. Could have popped, and would explain the trouble.
Apr 29, 2009 | 2000 BMW 7 Series
Ariens 46 in. 20 HP Hydrostatic Riding Lawn Mower Logo
14 people viewed this question
Top Ariens Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Matt Olenzek
Matt Olenzek
Are you an Ariens Garden Expert? Answer questions, earn points and help others
