Question about LG WM2016C
Front-load washer doesn't clean!
We have an LG WM2016 washer - about 3-months old; previously we had a Whirlpool top-load set.
The LG front load washer does not clean our clothes, and I'm wondering if there's something wrong.
Whites, especially, are not getting clean. We've tried nearly all combinations of settings (soil level, extra water, pre-wash, temperatures, different detergents (and detergent amounts)) and we can still take a pair of socks 'clean' from our front-load (still with dirt stains), run them through a friends top-load, and have them come out looking far cleaner.
Is there possibly a problem with the washer? Everything I've read indicates that front-loads should clean better than top-loads!
Thanks!
  • LG Master
  • 4,498 Answers
I don't know anyone who thinks the front loader is better except for stacking things on top of...
Certainly the performance of the modern water-saving front-loader is questionable when compared to earlier models - which is why I think a wash takes much longer these days with a modern machine, I think it has to in order to be effective. My friend's new front loader can take a couple of hours to complete a programme and it is only a washer and not a waser/drier.
The older washers used to take everything that could be pushed inside and the laundry would emerge smiling. These days overloading is a complete taboo and should be weighed to ensure nothing is strained.
Your washer might have a fault but in the final analysis you made a contract with a retailer to, in return for a consideration, supply you with a washer to clean your laundry. The supplied washer doesn't clean the laundry in spite of your best efforts and that means the retailer has broken the contract. It is up to him to sort matters out to your satisfaction.
Posted on Mar 25, 2017
  • robert Mar 25, 2017
    Is the washer tumbling your clothes thru the water in wash cycle? Back and forth in both directions?
  • 100 Answers
SOURCE: LG TROMM WM 2077CW LE Error
An LE error is a locked rotor. The hall sensor on the stator part of the motor is not sensing the rotor part of the motor is turning. So the short version is you need a new stator(which has the sensor on it or just the sensor) replaced which should have a 5 year warranty on it so call LG for your nearest authorized service center
Posted on Dec 05, 2007
  • 249 Answers
SOURCE: Oil stains on whites after washing in our Kenmore Oasis
seals are gone big job!!
Posted on Jun 14, 2008
  • 958 Answers
SOURCE: Clear greasy stains appearing on clothes from brand new LG front loading washer
the grease i'm sure would be coming from the machine. look at the water solenoids, detergent dispenser, dispenser solenoids, everything with rubber hoses.
they do put a clear grease just to insert the hose easier in the plant. and if it was not removed during QC, then it would come out now as you uses it.
tnx 4 using fixya,
drcool
Posted on Sep 28, 2008
barkencoa
  • 3463 Answers
SOURCE: Clothes are not clean How can I take washer aprt to clean soap dispenser???
Make sure you are washing at the correct temp, and that you have the correct prog selected for what you are washing. and that you have suficient powder and or detergent in. Check to see if the water is getting hot, because if it is not , then the heater may not be working, and then your clothes will not be clean.
Hope this helps with your prob.
Plz rate my solution.
Thanks.
Posted on Jan 03, 2009
  • 98 Answers
SOURCE: Spots on clothes after washing
Put another filter on before the washer. Try to find out if it is in the hot water or the cold. If it is the cold try a filter. If it is the hot, replace your hot water tank.
Posted on Jun 06, 2009
WHY THE BREAKER IS SHUT DOWN, WHEN I PLUG MY WASHING MACHINE
I solved that problem by junking my LG front loading washer and replacing it with a good old reliable Whirlpool top loader
Jul 06, 2014 | LG WM-2277HW Front Load Washer
Broken Glass Sound
OK, who washing the dishes in the CLOTHES Machine?! Broken glass sound? You are sure your neighbor isn\'t playing a trick on you! I am going to guess that you have either a BAD bearing, in which it is time to look at Other Machines as an option. I mean if the clothes are getting clean and it drains all the water? Just shut the door! No I can\'t say that...Can I? Whirlpools (in my opinion) are one of the Best. The problems we are having today are these Front Load Machines are a Piece of Crap! They do not use enough water. You have to use Hi Definition 3X\'s more expensive soap..that doesn\'t Clean the garments. This sounds BAD. I had the same problem and bought a USED Whirlpool Top machine for $150 dollars from a guy who"Likes" to tinker/work on them and three years later...Going Strong! Sorry I could not help you
Jan 03, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Soap dispenser is full of water and soap at the end of the cycle.
You will need to remove the top and clean the lines from the dispenser.
Nov 23, 2012 | LG WM-2277HW Front Load Washer
Own a lg wm1832cw front load washer doesnt seem to clean properly when wearing tee shirts for an hour smells like they never were washed paid alot of money for this thing seems cheaper top load machines...
Hi
The smell usually comes when the washer is unable to drain water completely, you can run your washer at its hottest temperature setting with 1 cup of vinegar inside the unit. After this take off the bottom front panel and clean it completely, also clean the drain hose and drain pump filter, the smell should disappear after doing all this. Hope this helps...please post back for further assistance.
Daniel
Sep 12, 2011 | LG WM1814CW Front Load Washer
My Whirlpool front loader washer has "clean pump" light displayed. How do i clean the pump.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Aug 22, 2010 | Whirlpool AWOE8748 Front Load Washer
Standing water in washer after cycle
take off the bottom front panel and clean the coin trap it will be up front just unscrew it have some towels handy
Dec 20, 2008 | Whirlpool GHW9400 Front Load Washer
Kenmore elite front loading wash & dryer-5 yrs old: should i buy?
all kenmore named washer will have 110 as first 3 digits of model #..the he washers are usually good washers..like all front loads they have their quirks ..if you read reviews from other consumers they indicate problems ..most of which are easily remedied by reading owners manuals..mold /mildew usually a bleach clean every few months ..vibration need real solid floor..oversuds use HE detergents only..just a matter of changing mind set from top loads with 25 gals of water each fill to a front load with 5-6 gals each fill..top load with 750-850 rpm spin speed to front load 1000-1200 rpm ..if willing to learn proper use and what to expect they can best investment..just don't let opinions of those unwilling to adapt affect your decision
Dec 16, 2008 | Kenmore Elite 45986 Front Load Washer
Whirlpool duet sport washer 3.6 WFW8410SW cycle will not start
set it to spin dran cycle and select no spin and push the rinse hold button 4 times it should read c00 on the dis play and go thew to c08 it will lock the door frist and then go thew all the cycles it will flash on a c# that has trouble
Nov 29, 2008 | Whirlpool Duet 3.8 cu. ft. Front Load...
Refer to your manual regarding cleaning your filter
Apr 28, 2008 | Whirlpool Duet GHW9150P Front Load Washer
LG WM2016C Logo
113 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
