Question about KitchenAid 15 In. Stainless Steel Ice Maker - KUIC15NRXS
Kuci15nrts0 won't stop making ice
Makes ice until it overflows out of the door when you open it.
fridgetech
  • 473 Answers
SOURCE: Kitchenaid superba side by side ice maker stopped producing ice
This is a picture of an ice maker module.  Which is behind the white plastic cover.  The cover just pops off.  Look at the two little tabs in the center of white wheel.  If yours is twisted, pressed together, or one is broken then the module is bad.  If not, take the icemaker out and let it set for a few hours to let it defrost.  Put it back in and see what you get.  The ice maker won't cycle and fill with water until it gets below freezing so you will have to wait awhile.  It can be started manually by inserting a jumper wire into terminal T and H.  Let it start to cycle for about 10 sec. then pull the wire out.  At the end of the cycle it will fill with water then wait for it to freeze.  Also, if door was left open check all vents in fridge for ice build up.  This cause cooling problems of they are plugged.  Let me know what you find.
Posted on Oct 21, 2007
cresguy
  • 75 Answers
SOURCE: kitchenaid superba ice maker stopped working
the oil in the compressor has pumped up to the top hence the ice is not formed the lead valve in the compressor is not working properly so change the lead valve and you could make ice as before
Posted on Jul 25, 2008
jumptrout51
  • 3361 Answers
SOURCE: ice maker will not dispense the ice
The auger motor and coupling in the rear may be frozen and won't turn.
Remove the ice bin.
Place a screwdriver or similar device in the forks of the auger and twist counterclockwise till it moves. The replace the ice bin and try again.
It will be difficult to move.
If that does not work. Turn off the fridge and use a hair dryer to hrat the auger gear and motor till it frees up.
Posted on Mar 23, 2009
  • 10865 Answers
SOURCE: My ice maker MAKES the ice but doesn't dispense it.
yes. completely warm up the ice maker with a blow dryer until the metal is all dry then spray it with the cooking spray called pam. just regular pam, no other. this will lubricate everything and it will work like a charm. rememer tho it can take up to 24 hours before it will make ice again.
Posted on Aug 16, 2009
walesarumi
  • 6993 Answers
SOURCE: Frost collects under the ice
There is frost under the ice making machine because its thermostat is set too high. There rate at which frost will form is going to increase because of the high thermostat.
Turn off the appliance and allow all the frost to melt. Then reset the thermostat and resume normal usage. Be sure not to use any utensils or tools to scrape off the frost, as it is very easy to puncture the evaporator and ruin the freezer.
Also, its normal for a ice making machine to form frost, but when the frost gets too much, then it means the defrost time of the Machine maybe defective.
Good luck.
Posted on Oct 08, 2010
6ED2FHGXVA ice maker making too much ice, why?
That is the dual water control valve that is leaking water to the ice maker. The ice maker will only fill for 7.5 seconds and then the water is turned off but if the valve is bad it will continue to leak water drips until it overflows the ice maker and forms an ice wonderland inside your freezer. There is no picture of the valve but here is a link to the valve part=> http://click.linksynergy.com/fs-bin/click?id=q2qDfOBHgas&subid=&offerid=92089.1&type=10&tmpid=2111&RD_PARM1=http&RD_PARM2=%253A%252F%252Fwww.appliancepartspros&RD_PARM3=.com%252Fwhirlpool-valve-inlt-w10158157-ap4371188.html
APPLIANCE 911
Dec 05, 2015 | Whirlpool Refrigerators
Ge pfs22mis ice maker won't stop
Hello:
No real fix here, just a design flaw..
Try switching ice maker on /off switch until you ready for more ice..
Cheers
Jul 15, 2017 | GE PFS22MIS
Fridge freezer door won'tstay closed
Faulty door seal.The seal that holds the door has a grip and a magnet on other side.May be that needs to be replaced.Or any fringe section tray is not completely fitted,to its end causing these.
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 24, 2012 | Frigidaire Refrigerators
Ice maker over makes ice then ice cube tray cannot empty and new water comes in and overflows into ice bin. stop are does not seem to be low enough to cut off production.
WHEN THE UNIT GETS FULL YOU ARE GOING TO HAVE TO SHUT ICE MAKER OFF...
unfortunately there is no sensor to tell the ice maker to stop production so this will happen. sounds like the unit makes more ice that your family uses which normally would be a good thing... just shut the ice maker off until time to make some more and then switch back on ...
hope this helps you out.....
Jan 03, 2011 | LG LRSC26910 Side by Side Refrigerator
Ice maker is overflowing
Older icemakers have a bar that drops from above your ice bin; once the bin is full the bar is raised and trips turning the ice maker off so that it won't dump. If your's is this style, try manually pushing the free end of the bar upward so that it locks in the upward position. Newer ice makers with the ice bin in the door have a small panel that moves to the open position when the door opens and closes when the door closes. Mine also includes an optical sensor that is visible when this panel is in the closed position. Try placing a non-clear tape over the optical sensor (don't know if that will work or not but worth a shot). If effective in stopping the ice flow then call a repairman. If none of this works, turn off the water supply coming out of the wall to your freezer.
Sep 08, 2009 | Kenmore Freezers
Maytag MCD2257KES ice maker shoot door does not open
Yes, the ice/water unit can be removed from the door to give access to the switch and solenoid that opens the ice door.
Dec 28, 2008 | Maytag MSD2656G Side by Side Refrigerator
Free standing 25lbs ice machine
It sounds as though the bin therrmisotr is defectice, which as you stated the unit is not sensing the temperature and just continues making ice.
The second issue would appeare to be a drain issue, it should be a gravity drain into either an open drain or a sealed pump.
Apr 08, 2008 | Viking Professional Series VURI140TL...
KitchenAid 15 In. Stainless Steel Ice Maker - KUIC15NRXS Logo
35 people viewed this question
Top KitchenAid Kitchen Appliances - Others Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Appliances - Other Expert? Answer questions, earn points and help others
