Question about AT&T Blackberry Curve 8300 Smartphone
My keyboard is lcoked up.
I had my blackberry in my purse and got it out to use it and the keyboard was locked up. Nothing would work. I plugged it in the charger in car and it would light up but no keys work. It is fully charged.
  • rxtechcjc Jun 15, 2009
    I already tried the battery thing. Also left it out all nite to see if that would help but didnt. Any more suggestions?
Try removing the battery
Posted on Jun 15, 2009
Blackberry curve 8330 keyboard and trackball doesn't work
Your trackball and the keyboard seems not working. You may need a replacement for both parts.
Jun 17, 2017 | RIM BlackBerry? Curve 8330 Cellular Phone
Tip
How to enable auto-lock and BEIKS keyboard lock on BlackBerry OS 5.0.0.464
The recently released BlackBerry OS update version 5.0.0.464 has introduced a number of imprvements, but has also been reported to "strip" keyboard lock funtionality and break the ever-popular <a href="http://blackberry.beiks.com/showprod.asp?prodid=990">BEIKS Keyboard Lock application</a>.
As it turns out, the functionality is not removed, but slightly modified: you now need to have a password set in the BlackBerry in order for the lock fumctionality to kick-in.
The password is set through the global Settings (or Options, depending on which BlackBerry you use) application, then in Keyboard.
I in particular find this new requirement rather confusing and even dubious. I hope they remove it in the next update.
on Mar 24, 2010 | Cell Phones
How to unlock the key pad of blackberry curve ?
if you do not set a BlackBerry® device password, you can lock your keyboard to avoid making calls and pressing keys accidentally.
Press the Lock key on the ***top**** of your device .
To unlock the keyboard, press the Lock key again.
If you have set a Black Berry device password and the security timeout has exceeded,
you are prompted to type your password.
Good luck.
Jan 27, 2011 | RIM BlackBerry Curve 8520 Smartphone
Blackberry curve 8520, the a button works on and off and it types a's when i type other letters, whats wrong? please help
if you carry the blackberry in your pocket it collect lint and dirt. blow the keyboard with compressed air to clean the key board. blackberrys are very susceptible to moisture, sweat, body heat which cause moisture. so they should be in a holder on your belt or in a purse
Oct 17, 2010 | RIM BlackBerry Curve 8520 Smartphone
My blackberry curve 8330 keyboard is locked up. dont know how this happened. ball moves curser up and down on the facepage but will not work when i press the keys. the screen goes black in a few seconds...
the keyboard on the device isnt registering the key clicks because either the keyboard isnt pressing down all the way or the circuit board that the keyboard belongs to is malfunctioning. If it is that, parts for the phone is available on ebay.
Oct 07, 2010 | AT&T Blackberry Curve 8300 Smartphone
My trackball works on my blackberry and i recieve calls but it seems like my keyboard is locked i cant pick up calls or select options
Have your keypad checked out, I used to fix alot of blackberries and they suffered from defective keyboards, this seems to be a common problem with them. Replace the keypad under the keyboard, swap out your phone if you have insurance.
Good luck.
Jun 12, 2010 | RIM Blackberry 8310 8320 8330 Curve 8100...
BlackBerry 8700c Cellular Phone: how to unlock blackberry keyboard. where is the l...
Its not possible that you can get free code its comes from server based on your IMEI.
Yes you can use as normal GSM phone after unlocking.
This unlock code provider generate full LEGAL unlock code direct from Blackberry server which wont void your warranty, & generate code based on your IMEI, means individual code for every blackberry set.
***SPECIAL CHEAPEST PRICE till 31th July from one of oldest provider.***
After unlocking from this provider's code your blackberry not only work with any network, you can use your Blackberry in any part of world with any GSM networks including your browser & MMS picture messaging to work, yes with just one time entering code from your keypad.
They unlock from network who locked your blackberry & remove restrictions like AT&T or any
This site will help you a lot & good email & 24/7 phone support.
http://blackberryimeiunlockcodes.com/
May 17, 2010 | RIM BlackBerry 8700c Cellular Phone
I turned my blackberry pearl off before i work every time which is about 4-5 times a week and put it in my purse. When i was done with work. I would turn on my phone like everyother night. I had a 3/4 full...
try to close all the application runnig.if not den formatte ur memory card.....if u want to check out den for a day keep ur memory card out,, see urbattery back up wll increase........
Mar 20, 2010 | RIM BlackBerry Pearl 8100
My blackberry curve 8310 was working ...then i put it in my purse then came home an took it out an there was no screen and a flashing red light what do i do
Take out the battery and sim card from the device and then check.
If problem persists take backup and reinstall the software using Blackberry desktop manager.
If still problem persist contact service center.
Nov 12, 2009 | RIM BlackBerry Curve 8310 Smartphone
Blackberry curve 8330 - mute key quit working
This is an odd one. I have worked with Blackberys for many years not come across this.
How long do you take the battery out? Keep the battery out for at least 2-3 minutes.
Also, is the mute key button broken inwards?
Does the Battery Charge still when you plug it to the Mains paower socket?
If the battery is fine then I would suspect the Device having some fault.
Let me know how it goes,
Thanks.
Mar 14, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
AT&T Blackberry Curve 8300 Smartphone Logo
137 people viewed this question
Top AT&T Computers & Internet Experts
Prashant M
Prashant M
Are you an AT&T Computer and Internet Expert? Answer questions, earn points and help others
