Question about Cisco Computers & Internet
Linksys password reset
My password does not work,as of last 4/20/14
Im trying to find my password for my router but i cant.
Reset Button
Note:
Resetting the router to the factory defaults will delete any changes you have made to the router, including any security settings. This should be used as a last resort.
The first method involves simply pressing a button located on the back of the router. The image below (courtesy of Linksys) shows where the button is located.
Linksys WRT54G Reset Button Location
To reset your router, use the following steps:
  1. Press the reset button for 30 seconds.
  2. The settings should now be returned to the factory default settings, meaning any changes you had made would be deleted.
  3. Open up your Web browser and enter "192.168.1.1′ in the address bar.
  4. For the login, leave a blank ID and enter "admin" as the password.
The router has now been reset. Follow the steps in Securing Linksys WRT54G Wireless-G Router to secure your router and create a good wireless network security.
Through the Web Administration PagesThe second method involves logging into the Web administration pages of the router. Use the following steps to reset the router using this method:
  1. Open your Web browser and enter the IP address of your router. By default, the address is "192.168.1.1′.
  2. Enter your user ID And password when prompted. Hopefully this has been changed, but if it hasn't, the default is no ID and "admin" as the password.
  3. At the top of the Web page, click "Administration" and then "Factory Defaults".
  4. Beside "Restore Factory Defaults", click "Yes".
  5. Now click the "Save Settings" button at the bottom of the Web page.
Your WRT54G wireless router should now be reset to the factory defaults. Ensure you follow the steps outlined in Securing Linksys WRT54G Wireless-G Router to secure your router and maintain your wireless network security.
SummaryThis post has provided two methods you can use to reset your Linksys WRT54G Wireless-G router. If you are having problems with your router, try resetting the router to the factory defaults, and then make the changes again and see if the router starts working again.
Sep 24, 2011 | Linksys Wireless-G WRT54G Router
I 'm trying to get my wifi..it wont work, i called comcast and they said to reset it and the password. i dont remember any login or password...help
The default password for Linksys routers is admin the user is left blank
some routers have slightly different than this user id admin and password also admin the last possibility is user id admin and password is just password
good luck!
Sep 16, 2011 | Linksys Wireless-G WRT54G Router
How can i find out my pssword.
The default username and password for Linksys routers are:
Username: admin Password: password
or
Username: admin Password: admin
or
Username: <no username> Password: password
If all of this fail you'll need to reset your linksys router so that it will also reset the password to the default. To reset you linksys router you can check it out on this website: http://technicallyeasy.net/2008/01/how-to-reset-linksys-wrt54g-wireless/
Note: Reseting your router means it's going to reload the factory default settings and all of the settings that you made on your router will be deleted permanently.
Apr 23, 2011 | Linksys Wireless-G WRT54G Router
I cannot find or remember the password for my E1000 Linksys router
Hi the default password for linksys unless you or someone has changed it is:
USERNAME: leave it blank PASSWORD:admin
If this would not work and you cant access the Linksys you need to reset the router by poking the reset hole at the back of it.Thanks
Feb 01, 2011 | Cisco Linksys Wirelessn Router Black...
I need to figure out how to re-set my Linksys WRT54GX2 Wireless0G Broadband Router With SRX200
This article will guide you how to change the router's password and reset it to factory default.
NOTE: Accessing the router's web-based setup page requires a password. The default password of a Linksys router is "admin". For security purposes, it is recommended to change default password.
Changing the Router's Password
Resetting the Linksys Router to Factory Default
Resetting the Router Using the Web-Based Setup Page.
If any more problem encounter,post or thumbs back.
Nov 02, 2010 | Linksys WRT54GX2 Wireless-G Broadband...
If i can't remember my username and password for http://192.168.1.1 how can i change it or find it out??
thers is no way to retrieve the username and password. you just need to perform hard reset for the router to restore to its original factory settings. please refer ti this link http://screenshots.leeindy.com/linksys.shtml
thanks
Mar 27, 2010 | Linksys Wireless-G WRT54G Router
Admin isn't working for the default password. Any workarounds?
The Linksys default login = admin
and the default PW = admin.
If you have forgotten the changed password the you can reset the Linksys back to the factory default by power up the Linksys and pressing the pinhole RESET button at the back of the Linksys for 30 secs. Then enter the configuration URL and configure the Linksys with a new password plus the wireless SSID and encryption etc.
Dec 25, 2009 | Linksys Wireless-G WPS54G Print Server
Need to find my password
1. Access the Linksys webpage
*To access the linksys gui
a. connect your linksys to the computer via RJ45 (ethernet cable)
b. Open internet explorer and on the address bar type 192.168.1.1
c. A pop-up will ask for a username and password
c.1 username and password is both admin
c.2 username admin and password blank
c.3 username blank and password admin
d. If none work reset the modem at the back of it there is a reset button "warning if you reset the modem it will be reset to factory setting and you need to setup your router again"
e. disable your computer firewall
2. Contact you ISP for assistance setting the Linksys
Nov 16, 2009 | Linksys Wireless-G Broadband Router
Forgot linksys password
Reset your Linksys router back to default:
The easiest method of resetting your Linksys router’s password is to reset your router back to the default factory settings. This is done by simply holding down the reset button located on the back of the unit for at least 30 seconds. Once the router has been reset, it must be reconfigured. Using your web browser go to URL address http://192.168.1.1. You will then be prompted to login to your router. A log-in screen asking for the password will automatically appear. At this time enter the default password “admin”, in lower case letters into the password field. The username field may be left blank at this time. (Note: both the default username and default password are set to “admin” on some of the newer Linksys router models).
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jan 31, 2009 | Dell Inspiron 6400 Notebook
Internet connection
bring sterlite company of modem. and give last one to repair to nearby computer engineer
Dec 03, 2008 | Alcatel Speed Touch Home Modem
Computers & Internet Logo
10 people viewed this question
Top Cisco Computers & Internet Experts
Prashant M
Prashant M
brian soufane
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
