Question about Dirt Devil SimpliStik / VersaPower Vacuum
How to connect crevice tool
Don't know how to connect crevice tool
2 Suggested Answers
  • 61 Answers
SOURCE: how do I attach the
Just pull REALLY HARD at the bottom of the vacuum cleaner, it'll pop off.
Posted on Aug 27, 2012
CANT FIND CREVICE TOOL IN NEW SHARK ROTATOR BAGLESS VAC
Hello, this is Ava with Think Crucial.
You can purchase a wide variety of high quality Shark replacement parts for your Shark vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=crevice+tool
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Nov 21, 2016 | Shark Vacuums
How do I use the crevice attachment
Hi there! The crevice tool can only be used when using the unit has a hand vac. Remove the handle and nozzle from unit. Attach the crevice tool by inserting into hand vac nozzle opening. To remove, gently pull apart. Hope this helps!
Sep 30, 2014 | Dirt Devil SD20000RED Versa Power AllinOne...
I have a Samsung SU3364 vacum cleaner have never been able to use the crevice tools as there is no suction when you take pipe off, only when you use it as a floor vac, any suggestions have tried every
If the vacuum is old, the intake path from the hose to the dirt receptacle may be plugged from years of dust, dirt and grime. This happened to one of our vacuums, and I had to take off the bottom guard, the belt and the sweeper bar to access the intake, and it took me about an hour to get it unplugged.
If this is a new machine, the hose may not be properly connected when you are using the crevice device. Check the manual for proper installation.
Jul 22, 2014 | Samsung 5490M Lightweight Upright Vacuum...
How do you use the flip out function?
Hello. The flip out crevice tool is used for hard to reach areas such as corners and couches. To use, this feature simply flip out the crevice tool. Hope this helps!
Jul 03, 2014 | Hoover Handy Plus Sp60dsr6 Rechargeable...
How to attach crevice tool
Hi! Below is step-by-step instructions for attaching your crevice tool.
1. Place unit in an upright position. Push release button forward, then pull handle from unit.
2. Remove floor tool from nozzle.
3. Attach crevice tool by inserting into nozzle. To remove gently pull apart.
Hope this helps out!
Apr 26, 2014 | Dirt Devil Simpli-Stik 3-in-1 Bagless...
I have trash in the area around the fan. How do I clean this area out.
Randy, if you have a vacuum with a hose and crevice tool attachment, that will work fine. Be sure to turn the unit OFF & unplug it, before attempting any cleaning. Use the crevice tool carefully and your shouldn't have any problems. If the trash that you want to remove is wet, allow it to dry first.
Hope this helps and thanks for choosing FixYa.
Jul 29, 2011 | Samsung AW1003B Air Conditioner
My ipod will only work while plugged into the docking station
If the part is stuck inside the iPod you can take the case apart quite easily and remove the broken part. If this is not the issue and I am way off please do let me know :)
Top Case Removal Begin by using a flat tool to separate the white plastic front case from the silver backcase. You will need to stick your flat tool into the crevice, work it down into the crevice,and then pry up so that the casing separates. Apply enough pressure so that your flat tooldoes not slip and scratch your iPod!Continue separating the casing by gently prying up all the way around the unit. It shouldbe much easier to pry the casing apart after you get the initial corner started.
Mar 28, 2009 | Apple iPod nano MP3 Player
No power in power nozzle
http://geeksquad.fixya.com/ThreadView.aspx?prdid=19674&thid=493359
Posted by pjs5451 on Apr 06, 2008
Vacuumed with power nozzle one day working fine took attachment off to use crevice tool reattached power nozzle and no power whatsoever.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Rainbow E Series Canister Wet/Dry Vacuum. The Rainbow Power Nozzle does have a reset button on the newer model on the top of the power nozzle, just push it and it should reset, or check all your pigtail connections to make sure they are connection and the cord leading to the actual Rainbow Vacuum itself. Out in left field might be that the power nozzle motor could be shorting out or not working or dead and might be in need of replacement. Check the cord for any frays or bad connections. If you have a problem please feel free to contact your local vacuum cleaner dealer in your area. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
The Rainbow / RexAir Factory phone number is listed below:
http://rainbowvacuum.com Customer Service
1-248-643-7222 Monday thru Friday from 9:00 am to 5:00 pm EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Apr 06, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Dirt Devil SimpliStik / VersaPower Vacuum Logo
Top Dirt Devil Building Materials Experts
Terry Smith
Level 1 Expert
Tom Chichester
ray gallant
Are you a Dirt Devil Building Material Expert? Answer questions, earn points and help others
