How do I reset 42PFL5403/98 to factory settings
No sound on TV and A/V
Can you tell me the normal (factory) sound settings i.e equalizer, bass, treble, balancr, volume in videocaon 32" LCD tv
Do a factory reset to this TV. It will make all to factory settings.
There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done
Dec 13, 2014 | Televison & Video
Vizio tv problems
Have you checked the TV without other devices connected to the TV.
Eg. disconnect any home theatre or speakers from the TV.
Verify with audio menu if the settngs of TV speakers is on or off ?
To adjust the audio settings:
1. Press the menu button on the remote. The on-screen menu
is displayed.
2. Use the arrow buttons on the remote to highlight audio and press ok. The AUDIO menu is displayed.
3. Use the arrow buttons to highlight the setting you wish to adjust, then press left/right arrow buttons to change the setting:
• TV speakers - Turns the built-in speakers on or off.
Lastly have you tried restoring the TV to factory default settings.
To restore the TV to its factory default settings:
1. Press the menu button on the remote. The on-screen menu is
displayed.
2. Use the arrow buttons on the remote to highlight system
and press ok. The SYSTEM menu is displayed.
3. Highlight reset & admin and press ok. The RESET & ADMIN
menu is displayed.
4. Highlight reset TV to factory defaults and press ok.
5. If you have changed the default parental control passcode,
enter it now.
The TV displays, "Select Reset to restore all TV settings to
factory defaults and clear all account information."
6. Highlight reset and press ok.
7. Wait for the TV to turn off. The TV will turn back on shortly
afterward and the Setup App will begin
Apr 29, 2014 | Televison & Video
I have a flm-1511 problem...my tv had no sound but had picture.. so i thought it was the satalite so i did a reset still no sound..so i went to the tv and did a factory reset and now i cant even get a...
hi,
After factory reset all the settings of the tv will goto factory default. To get the video again you have to auto tune the TV. For the go to the menu and select setup then select Auto program. Wait till the auto tuning end.
OK
Sep 23, 2011 | Polaroid FLM-3232 Television
Pioneer pdp 507cmx has no sound does this tv have speakers
Yes,every tvs have a basic pair of speakers.Tries tv unplug,replug it back like about an hour later.Go into the tv Menu go to PICTUTRE SETTING go down to do a resetting for a back to factory setting of the whole tv main Tuner signal board.Go to Audio Setting go down to a resetting for the factory audio setting.Tries these steps,tv now should have sound back.
May 10, 2011 | Pioneer PDP-507CMX Television
Philips 32PFL3505D 32 in LCD TV How can the TV be set to factory setting?
Hello
There is no details about the factory reset of your tV in its user manual. But intvidual reset for picture, sound etc can be selected and can be reset to factory reset.
Summary of picture settings
The following picture settings can be confi gured. Depending on the
format of the picture source, some picture settings are not available.
• [Auto Picture]: Sets all picture settings to the factory default.
• [Brightness]: Adjusts the intensity and details of dark areas.
• [Contrast]: Adjusts the intensity of bright areas, keeping dark areas
unchanged.
• [Color]: Adjusts color saturation.
• [Tint]: Adjusts the color balance in an image.
• [Sharpness]: Adjusts the level of sharpness in image details.
• [Color Temperature]: To set the color temperature to [Normal],
[Warm] or [Cool].
Summary of sound settings
The following sound settings can be confi gured. Depending on the
sound source, some sound settings are not available.
• [Auto Sound]: Sets all sound settings to the factory default.
• [Equalizer]: Adjusts individual sound frequencies.
• [Virtual Surround Sound]: This selects the modes for more spatial
or surround sound reproduction.
• [Auto Volume Leveling]: Reduces sudden changes in volume, for
example, during commercials or when switching channels. Select
[On] or [Off].
• [TV Speakers]: Select [On] or [Off], or output sound to an
EasyLink compliant device. When [Speakers EasyLink] is selected,
the TV speakers are disabled and TV sound outputs to the speakers
of the compatible EasyLink compliant device. Adjust the volume
using the unit's remote control.
OK.
Mar 08, 2011 | Philips 32PFL3505D 32 in LCD TV
Sound becomes distorted after changing channel requiring pushing mute button and back to sound again to restore proper sound
Tries tv unplug,replug it back like about an hour.By letting the tv by resetting itself back to the factory setting.Now goto the tv menu goto Audio Setting,go down to do resetting,so resetting the tv Tuner board for resetting sound,setting back to factory setting.This should solved ur sound problems.
Jan 30, 2011 | Vizio M370VT 37 in. LCD TV
Trying to reset the settings for my toshiba model27a45
Hello
It is easy to reset your Toshiba set to factory defaults. Enter each options, ie, picutre, sound etc, and press "Reset" button on your remote control to reset each options to factory settings. The default factory settings for Video is DVD. Ok.
Jan 07, 2011 | Toshiba 27A45 27" TV
Philips 32pf9986 has no sound after being moved from our house to parents house. Oddly the sound menu only has as a setting for headphone volume.
Tries tv unplug,replug it back about an hour later,by letting the tv resetting itself back to the factory setting.Now,tv is on goto tv memu to PICTURE go down reset to reset the entire tv Tuner signal board.Then goto SOUND Setting,go down to resetting.This process are resetting everythings.The tv sould have sound now.
Jan 03, 2011 | Philips 32PF9986 32 in. HDTV-Ready LCD...
When turning on TV, sound is often absent.
Unplug,replug the tv about an hour later,let the tv reset itself.Tries goto tv menu,go to AUDIO,go down to reset the audio setting,back to factory setting.Goto menu to PICTURE,go down to reset,to resetting the Tuner board back to factory setting.The sound,should be there,now all the time.Not,than the Tuner board have problems.That the board,where the broscasting signal cable plug into it.That the Tuner board.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner board for the replacement.
Jul 23, 2010 | Sony Bravia KDL-40V5100 40 in. LCD HDTV
Picture no sound
Reset the tv back to factory setting,by unplug,repluging it an hour later.Go in ur tv AUDIO setting reset it,now it back to factory setting,Should work,not than the tv Tuner board recieve the broscast signal boad is have problem must br replaced.
Jun 02, 2010 | Goodmans GTVL32W27HDF 32 in. LCD TV
Televison & Video Logo
Top Televison & Video Experts
