Question about Ricoh Office Equipment & Supplies
Paper will not feed through scanner
Aficio Sp 5200s
  • 86 Answers
SOURCE: driver for Ricoh Aficio SP-C210SF
Please browse the link below;
http://www.ricoh-support.com/enduser/downloads/downloads.asp?fileid=11342&ricohmodelid=6317&url=http%3A%2F%2Fsupport%2Ericoh%2Ecom%2Fbb%2Fhtml%2Fdr%5Fut%5Fe%2Fre%2Fmodel%2Fspc210%2Fspc210en%2Ehtm
Good luck and please rate me, thanks.
Posted on Jan 29, 2009
El Geek
  • 148 Answers
SOURCE: AFICIO SP C410DN BRAND NEW
There are several steps involved in unpacking your particular color printer.
I'm sure you have the quick start guide which provides very nice photographs of how to remove the packing tape and materials within the printer, but just in case:
http://www.ricoh-usa.com/downloads/manuals/printers/c410dn/manuals/Quick_Installation_Guide.pdf
I hope this helps.
In the odd case that everything is clear and you still get paper jams, take it back and have it replaced before your 30-day or whatever exchange warranty runs out.
Good luck. Keep us informed.
Posted on May 22, 2009
  • 903 Answers
SOURCE: Paper Jam
Open up the doors and blow some compressed air throughout the paper path (where the paper travels up). Make sure to blow air onto the sensors, because paper dust can coat them, causing false jams.
Does the paper get out of the tray at all? There is a feed roller that feeds the paper up into the machine; if you remove the paper tray you can see this roller -- it's big and gray and has grooves across it -- above where the paper sits toward the front of the printer. Blow air onto this roller as well, and if you have either D-ink or a rubber rejuvinator, clean the roller with a lint-free cloth.
Also make sure the paper is snug in the tray and not bent or crooked.
Posted on Jun 05, 2010
radar001
  • 1051 Answers
SOURCE: scanner not feeding on lexmark x7170. paper feeds
I have the same all-in-one printer and have just recently, the unit is a few years old, started having the same problem. I found that that if I make double sure the pages are evenly stacked and very carefully placed in the feeder tray, the problem is less common. It doesn't work everytime but ar least I get my faxes through on the first attempt 75% of the time.
Posted on Nov 10, 2010
  • 121 Answers
SOURCE: I have Printer and Scanner
Hi Mach,
Click on the download link below to goto the driver and software download page of Ricoh.
Download Link
E.g : If I want the printer/scan/fax driver for windows 7, I will click on the download icon under Windows 7 as shown in the image.
shreysri_7.png Regards,
Shrey
Posted on Jun 02, 2011
I know how to replace it But Where can I find the waste toner bottle in Aficio MP 8001
In the manual (free download) here: Aficio MP 6001 6001 SP 7001 7001 SP 8001 8001 SP 9001 9001 SP download page I can't find any entry about waste toner, only the waste toner can't be reused, but no entry where to find the container. Sorry
Feb 09, 2015 | Ricoh Aficio Mp 8001 Copier - 910k Copies...
Ricoh aficio sp 100su has error code c6
SC101 c6 C CIS Lamp/Scanner Motor Error A problem occurred with the CIS or scanner motor in the flatbed scanner: -Carl
Nov 13, 2014 | Ricoh Aficio SP 100SU e Laser...
How to change feed roller on RICOH Aficio SP C242DN ?
1. remove all the cartridges.
2. remove the waste toner bottle.
3. rear cover
4. left cover
5. paper feed clutch
6. close the top cover and front door.
7. pull out the tray.
8. stand machine with the rear side facing the table.
9. slide the paper feed shaft to the left side.
10. remove the paper feed roller.
Jul 09, 2014 | Ricoh Corp Aficio SP C231N Laser Printer
How to change feed roller on RICOH Aficio SP C231N
You would need a technician to help out with the stuff.
Continuous jam paper feed cl3500n
I THINK THE NUMBERS BUTTON HAD PROBLEM, TRY TO CHANGE THE NUMBERS BOARD & SEE IF THE PATTERN STILL PERSIST. IF THE PATTERN PERSIST ALTHOUGH YOU INSERTED NEW NUMBER BOARD, THEN YOU HAS TO GO IN SP MODE TO CHANGE PRINT SETTING
Sep 26, 2013 | Ricoh Aficio SP-C210SF Printer
BYPASS MISFEED, FEED FROM TRAY IS OK
the bypass tray does not have paper sensors, so when you print you need to specify the dimensions of the paper ion the print driver and in the machine system features-tray paper settings..
Jan 20, 2013 | Ricoh Corp Aficio SP 6330N Laser Printer...
Need to reset maintenance count on a richo aficio AP410n laser printer ?
• After the technician replaces the fusing unit, the maintenance counter must be reset with engine SP mode 7-804. • 7-804-1: Transfer roller • 7-804-2: Paper feed roller • 7-804-3: Fusing unit).
Jul 27, 2010 | Ricoh Aficio AP410N Laser Printer
Error code
SC531 Paper feed / Fusing motor error 1. LOCK signal is not detected for more than two seconds while the motor START signal is on. 2. LOCK signal is not cancelled within two seconds after the motor is off. • Defective paper feed/ fusing motor 1. Replace the paper feed/ fusing motor.
Apr 30, 2008 | Ricoh Aficio SP C410DN Laser Printer
Doc not feeding
You need a new paper feed tire assembly
Nov 24, 2007 | Ricoh Aficio IS420 Flatbed Scanner
21 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
