Question about Minn Kota Riptide St Saltwater 80 Bow Mount Trolling Motor
Trolling motor will not hold charge
I recently had a minn kota trolling motor installed on my boat and it will not hold a charge. I left it plugged in for two days.. they installed two batteries to charge it with any suggestions?
  • Dean
    Dean May 11, 2010
    I dont think these motors actually have batteries themselves, and hence they don't hold any charge at all... it is the batteries it is connected to that supply the power to the motor, and the batteries themselves are what needs to be charged up to provide the power to the outboard.What batteries have you got installed?
  • 10 Answers
SOURCE: Hook up for one battery operation for minn kota trolling motor
I am not sure which trolling motor you have but click the link and scroll down to select your trolling motor the battery hookup is the last page
http://www.northlandmarine.com/MinnKotaQuickRef.htm
Posted on May 08, 2009
SOURCE: Minn Kota power drive trolling motor will not
It is the circuit board in the foot pedal. You will have to replace the whole foot pedal. This is a very poor design. The thin plastic which protects the contacts gets a little hole which allows water to enter and consequently the contacts corrode. Has happened to me two times in past four years. It might be OK for operation in a dirt-free water-free environment; but not under actual fishing conditions.
Posted on May 26, 2009
Editor925
  • 285 Answers
SOURCE: where to buy replacement brushes for electric
http://www.northlandmarine.com/MinnBushKit3.25.htm
Posted on Jun 20, 2009
bigcass
  • 35 Answers
SOURCE: is a minn kota mag 36 just 12V or 12V -24V run
I believe the Mag 36 is a 12v and the Mag 40 is a 24v......Ive been doin a little research and cant find anything that points to a 12 and 24v system.....
Posted on Jan 19, 2010
  • 122 Answers
SOURCE: How many amps does a minn kota 80lb thrust motor draw ?
max is 56amps on 24v system
Posted on Jan 31, 2010
Only have a model number and need to order a Minn Kota electric motor propellor
Minn Kota go by the thrust which is mentioned on the top plate. I got mine off Craigs List as well.
  • Minn Kota Prop Compatibility Chart - TrollingMotors.net https://www.trollingmotors.net/blogs/selection/86967623-minn-kota... Minn Kota Prop Compatibility Chart Minn Kota Prop Charts. ... Minn Kota with a serial number and they can recommend a compatible prop for your older Minn Kota motor. ...
  • Minn Kota Motors www.minnkotamotors.com Prop Selection & Part ... Electric Anchor Winches; Shop All; APPAREL. ... A combination of a Minn Kota motor and foot controlled rudder steering allow you truly ...
  • Trolling Motor Replacement Props - Minn Kota www.minnkotamotors.com/Accessories/Trolling-Motor-Accessories/... Minn Kota builds the world's toughest ... Electric Anchor Winches; Shop All; APPAREL. Mens; Ladies; Youth; Shop All; WHAT MOTOR DO I NEED? LET US HELP YOU ...
  • Minn Kota Replacement Propellers - www.fishntech https://www.fishntech.com/minn_kota_propellers.html ... Minn Kota Electric Trolling Motor Replacement Propellers & Nut Kits, ... Minn Kota Replacement Propellers . ... Minn Kota Electric Trolling Motor Replacement ...
  • Minn Kota props replacement props for Minn Kota www.minn-kota.com/minn-kota/minn-kota-propellor/page/2 Minn Kota Replacement Props for propellor Weedless Wedge 2 Props ... Minn Kota MKP 3 Prop 2061151 ... MinnKota Trolling Motor Power Center $57.58; DeckHand Electric ...
  • MINNKOTA MKP 37 2091170 TROLLING MOTOR PROPELLER ' ... www.ebay.ca/sch/...nkw=MINNKOTA+MKP+37+2091170+TROLLING+MOTOR+P... Find best value and selection for your MINNKOTA MKP 37 2091170 TROLLING MOTOR PROPELLER ... MINNKOTA MKP 37 2091170 TROLLING ... MINN KOTA ...
  • Jun 08, 2016 | Minn Kota Endura 30 Freshwater Transom...
    Minn Kota mk25 light will not move from yellow to green. I have moved the connections from one battery to another. I replaced a dead starter battery, and my trolling battery tested out at 100%. what could...
    Do you remove the trolling motor wires before charging..? ...If not.. try that......mine started taking a LONG time to charge.. after I remove the trolling motor cables.. it take less time and charges better!!!
    Feb 25, 2013 | Johnson Minn Kota Mk 25 & Mk 35 On Board...
    Old outboard ground wire melting
    1. Short in the trolling motor itself
    2. TOO SMALL a ground wire. ..need at least 8 gauge wire!!!!
    3. Bad/dirty/corroded battery connections
    ..Make sure your battery/trolling motor is not accidentally touching the metal boat.. DO NOT CONNECT ANY WIRES TO THE BOAT!!! - PERIOD!!.
    Sep 11, 2017 | Minn Kota Maxxum 70 Freshwater Bow Mount...
    Trolling motor doens't work
    I have a trolling motor and can't seem to get it to come on. I seen it work when I got the boat. But now it won't come on.
    May 06, 2009 | Minn Kota Maxxum 55 Freshwater Bow Mount...
    Apr 04, 2009 | Minn Kota Maxxum 70 Freshwater Bow Mount...
    Minn Kota tolling motor
    Reverse the polarity on the trolling motor by taking the trolling motor apart and turning ithe motor housingt 180 degrees and bolt it back up. The polarity will be straight then. I did the same thing when I pulled the armature back in.
    Nov 24, 2007 | Minn Kota Maxxum 70 Universal Motor/Sonar...
    Minn Kota Riptide St Saltwater 80 Bow Mount Trolling Motor Logo
    54 people viewed this question
    Top Minn Kota Boating Experts
    Mike Marcotte
    Mike Marcotte
    Andrew Taylor
    Andrew Taylor
    Colin Stickland
    Colin Stickland
    Are you a Minn Kota Boating Expert? Answer questions, earn points and help others
