Question about Singer 132QRFB Mechanical Sewing Machine
Bobbin stitch is loopy
I have re-threaded the bobbin and machine at least 20 times and the bobbin stitches are still loopy. What should the tension be set at? It is a Singer Touch-Tronic 2010
4 is the "middle of the road" tension number, but it depends on the thickness of your fabric.
Posted on Jun 15, 2009
  • Hassy
    Hassy Oct 18, 2011
    For a comprehensive 5 page illustrated tutorial...Check this solution link, just copy & paste:
    http://www.fixya.com/marketplace/service...
Why does the bottom tread come out loose and loopy
First, check the stitching to verify that it is in fact the bobbin thread that is loose & loopy. Usually, loopy thread under the fabric is the upper thread--which, if that is the case, is an indication it is either threaded incorrectly or the upper tension is too loose.
Make sure you are using a brand-new needle.
Always RAISE the presser foot and then thread the upper thread making sure that every guide and the correct path is followed.
Set the upper tension to the midway point between high & low number and re-test the stitching. Re-adjust as needed. The tension is correct when both upper and bobbin threads meet in the middle of the fabric.
Understanding Thread Tension Threads
If it is in fact the bobbin thread causing looping, it could be that the bobbin case is not threaded properly or the tension is way off.
Liz Kettle adjusting your bobbin case tension 1 wmv
Apr 11, 2016 | Sewing Machines
Model 525B. Why is bottom stitch loopy and the hand wheel and needle jam?
try a new needle
try adjusting the top thread tension to see if that helps the bottom loopy stitch
Jan 10, 2016 | Janome Sewing Machines
Thread tension
Needle/fabric/thread combination is wrong. hope this helps
Aug 17, 2017 | Sewing Machines
Tension issues with the bobbn area
No, I have not had a consistent problem with this.
What looks like a bobbin issue could be a threading issue.
If a sewing machine is threaded with the presser foot down, the tension control does not capture the thread as it should. The top thread then cannot form a proper stitch with the bobbin thread.
If I forget to have the presser foot up when I thread, then I get loose stitching on top and loopy stitches on the bottom.
Mar 30, 2010 | Janome 659 Mechanical Sewing Machine
The thread from the bobbin is all loopy in the stitches
Always thread the sewing machine with the presser foot up.
This allows the thread to properly enter the tension control.
If the thread is not in the tension control as it should be, when it connects with the bobbin thread it is not tight enough to form a proper stitch.
The bobbin gets the blame because it feeds from the bottom.
Mar 10, 2010 | Janome Sewing Machines
Tension problem
Set the top tension as recommended by the mfg - this is usually between 3 - 6.
Now re-thread the machine with the presser foot up and see if this doesn't eliminated the loopy stitches.
What appears to be an issue with the bobbin may actually be the top thread was not seated into the tension during threading and the tension cannot control the flow of thread to the needle and you get a loopy stitch.
Keep the bobbin case clean as built-up lint can cause stitching problems.
Feb 20, 2010 | Brother LS-2125 Mechanical Sewing Machine
How do you change the tension on a bobbin for a singer 5050 We don't have an instructional manual?
Unless you are going to hand wind a heavier thread on the bobbin, you do not need to make any adjustment to the bobbin tension.
There is a screw on the side of the bobbin case and this is where you adjust the tension.
You can download a free manual here - http://www.singerco.com/accessories/manuals.html
If your stitching is loopy, it is not the bobbin.
Re-thread the machine with the presser foot up. This will insure proper tension when the top thread and bobbin thread combine to make a stitch.
Feb 20, 2010 | Singer 5050 Mechanical Sewing Machine
My top stitch is flat, but the bobbin is bunching and looping extra thread. cotton fabric, polyester thread
What looks like a bobbin problem is sometimes the threading of the top thread.
If you threaded the machine with the presser foot down, the tension is closed and the thread cannot enter as it should.
Improper seating of the thread into the tension results in loopy stitching as the thread is not being guided at the proper tension to create a satisfactory stitch.
Try re-threading the machine with the presser foot up.
Feb 18, 2010 | Bernina Virtuosa 160
The top thread is really loopy on the underside of the fabric, sometimes it misses a stitch, sometimes, the upper thread breaks, and it often gets so tangled underneath that the machine won't feed.
Your tension is way too loose on top or too tight on the bobbin. Try adjusting the top tension one number at a time until you get it right. (Only adjust the bobbin tension as a last resort). Also you could have different thickness of thread in the bobbin than on the top or are sewing a very heavy fabric. Try adjusting the tension with same thread in both bobbin and top and use a normal weight fabric until you find the right tension to get you back to a normal stitch before going to a heavier fabric or thread.
Nov 19, 2009 | Craft Master 4300 Mechanical Sewing...
Top thread will not pick up bobbin thread makes a big loopy mess
This is sometimes caused by the upper thread not threaded correctly. You need to thread it first with the pressure foot in the up position. You need to "floss" the thread into the clear plastic guide as this is where the tension is. The tension should be set to E for embroidering. Also make sure you get the bobbin thread in the slot on the bobbin case. Also, lower your pressure foot before you begin embroidering. Hope this helps!
Sep 20, 2009 | Singer CE-100 Futura Computerized Sewing...
Singer 132QRFB Mechanical Sewing Machine Logo
666 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
