Question about Fujitsu Televison & Video
How to work a fujiysu remote model #P-42RM07-W
THIS IS COMPLICATED REMOTE,,HOW DOES IT WORK,,TRYIN TO PUT IT ON CHANNEL3
I have a okishi tv and tryin to set my rm-300f+ universal remote to it is proving impossible can any1 help please
U need to contact the manufacturer of universal remote for possible code. If they do not have one then you are simply out of luck and will have to purchase the original remote or find some other universal that may accommodate your equipment.
Oct 06, 2015 | Universal Televison & Video
We have no remote. Is there a way that I can get my tv to stop on channel 3? It just goes from channel 2 to channel 4 and does not allow 3 to come on -- skips right over it . I just need to use it for a...
it simply means that channel3 has been set to skip/go to the tuning menu and select manual search.select channel position3 and cancel channel skip function.
Oct 05, 2013 | JVC AV-32F703 32" TV
I have a fujitsu 42in monitor model no p-42rm07-h I hooked dish box up to it in it show green...then I tryed my dvd which have the rgb outputs in it showed green ask well someone please help
Sound like a panel fault. Check the site linked here for more details. Screen-shots to panel defects are illustrated. http://electronicshelponline.blogspot.com/
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Sep 10, 2013 | Televison & Video
Can I turn on my fujitsu p-42rm07-h without a remote control
If it has a manual on/off it will be on front or usually on one side (right)
Mar 20, 2012 | Televison & Video
Fujiysu siemens USB speakers problems (no sound coming out but the laptop Toshiba satellite speakers work , windows7)
Right click on the speaker icon in the System Tray next to the clock in the Start Bar. Click Playback Devices. In the window that comes up, select your USB speakers and click "Set Default" near the bottom of the window. Click Apply, then Ok. Your sound should now be coming through your USB speakers.
Mar 23, 2011 | Computers & Internet
I require the tv universal remote code to program a Citizen TV model JCTV 3082 serial V 43535298
i cant give u the exact one ull have togo thru these and find the one that works but here nthey are 0002 0502, 0906, 0112, 0512, 0520, 0115, 0701, 0402, 0805, 0407 one of these 4 digit codes should work just keep tryin them until u find the right one hope this helps
Feb 24, 2010 | Jensen JR300 Remote Control
Tryin to program remote and cant find the instruction
I NEED HELP WITH A PHILPIS UNIVERSAL REMOTE......TRYING TO PROMGRAM IT WITH ESA TV
Sep 15, 2009 | Philips Magnavox Learning Universal Remote
How to set to channel 3
Look at the back of your comcast box. See if there's a ch3/4 switch. Make sure it is on ch3. Also make sure the cables are going in the right order. If you have a lot of stuff, simplify your connection -- wall to comcast box to TV. Once that works, add in the DVD player, etc.
Jan 31, 2009 | iLO 2600 Television
PHILPS 29PT449A, FAULTY REMOTE, PROGRAMMING HASSLE
regarding tv remotes please check web site for proper help. www.remotes.com give model name in search. hope this will help.
Sep 30, 2007 | Televison & Video
Televison & Video Logo
27 people viewed this question
Top Fujitsu Televison & Video Experts
Electro Med Services...
Are you a Fujitsu Televison and Video Expert? Answer questions, earn points and help others
