Question about Kenmore Dishwashers
Whirlpool dishwasher 857537 leaves debris on top rack dishes
I've had the machine for about 4-5 years and recently it began leaving debris on the top rack glasses/dishes. Usually mostly on the exterior, but sometimes on the inside of the glasses as well. Technician advised me to increase hot water temperature, change detergent, and add more rinse aid. None of those things have helped. Any thoughts? He disassembled the pump, inspected the spray arms, etc. and didn't find anything unusual.
  • 338 Answers
SOURCE: kitchen aid dishwasher doesn't clean dishes in the top rack
Sounds like you have 1 of 2 problems. Either your pump is clogged or you need a bigger drain loop.
Posted on Nov 25, 2008
larryyb
  • 291 Answers
replace the top spray arm and it should work ok again
Posted on Nov 27, 2008
  • 423 Answers
SOURCE: LG dishwasher wont clean top rack dishes
Recommend you remove the approximately 10 screws to pull the entire filter and manually clean. Remove all debris you find and thoroughly rinse out the filter if you can separate the top from the bottom. If the sump area is greasy, use a de-greasing spray to cut through it. Resemble, checking that there are no blockages in the holes on the spray arms.
Fill a bowl or cup with white vinegar and place it on the lower rack of the empty dishwasher. Do not add detergent. Run the quick cycle. The inside of the dishwasher should now be clean and not greasy. If still greasy, use the de-greasing spray (avaiable at all stores in the cleaning section.)
For 30 days, use only Electrosol or Cascade powder. Do NOT use gel or tablets, ever. Please report back your results. Good Luck!
ianc435 , please ask your question in as a new problem and I will help you out. I understand your problem.
Posted on Mar 29, 2009
SOURCE: My 6 yr old Kitchen Aid dishwasher is leaving food residue
After checking all sprayer arms for clearance, and checking heating element and discharge pump, the problem was solved by replacing the small sprayer arm at the top of the washer. This small arm had popped off some time ago - obviously the water pressure was excessive for the small and unimpressive fastener. Luckily we had saved this piece, which I refastened with a strong aluminum non-corroding small bolt. Presto - now the water distribution is back to design specs, with sufficient water coming out under pressure from the mid level arm. Lesson: always look for the simplest cause first with the simplest solution. TCA
Posted on Jun 24, 2009
  • 677 Answers
SOURCE: Dibris on glasses afterwash. Dishes not coming clean
could be hard water in your area leaving minerals on your dishes.www.dishwasherfilter.com has an amazing product out that fixes this problem once and for all. it is a small filter that filters the hardminerals out of your water before entering the dishwasher. it is very affordable and guaranteed to work or your money back. you will be amazed how clean your dishes look.
Posted on Aug 11, 2009
Whirlpool dishwasher leaving debris on top rack dishes
You did not list the model of the machine. But it appears to me that the disposal in the unit might be in need of work. There are teeth in the machine that grind food.
Mar 24, 2014 | Dishwashers
Kenmore dishwasher ultrawash debris on glasses
Fill the soap cup with vinagar and run it while its empty.
Mar 09, 2012 | Kenmore Dishwashers
Dry time for touch-up paint 676453
I would let it dry for 24 hours before using the dish racks.If you are going to leave the racks inside the dishwasher after you paint them be sure to leave the door open to help the paint dry.
Jul 25, 2011 | Whirlpool 676453 DISHRACK REPAIR
Dishwasher leaving debri and food partical on dishes. the top arm seams to be not moving but water is getting threw.
top arms are normally free-wheeling, depending on water pressure from beneath to operate and distribute the rinse water. Is it possible you have dishes or utensils being placed in the top rack which would prohibit the arm from turning?
Nov 27, 2009 | Frigidaire Dishwashers
Whirlpool du1055xtsq 3 not cleaning top rack of
In my experience, you probably have a clog in the spray arm/arms for the top rack. Take the arm(s) out and see if the holes in them are clogged. Rice, plastic wrappers, and glass from dishes that broke in there are the most common culprits I've seen.
Nov 25, 2009 | Whirlpool Dishwashers
Normal cycle leave dishes half clean. Heavy cycle
in the bottom of the machine, under the bottom rack, is a screen looking piece. twist or just pull up, should be able to clean that then replace.
Aug 08, 2009 | KitchenAid 24 in. KUDP02CR Built-in...
Kenmore Dishwasher not cleaning dishes - especially top rack.
put a pump kit in the dishwasher..and the water coming up is a house drain problem
Aug 06, 2009 | Kenmore Elite 45986 Front Load Washer
Jan 11, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
If the unit is cleaning the bottom dishes normally, try unplugging the unit for 5 minutes to reset the control board.  If that doesn't work, then the control board needs to be replaced.  The problem is that control board is not diverting the water to the upper wash arm during the cycle.  Possibly a program problem
May 30, 2008 | LG 24 in. LDF 7811 Stainless Steel...
Dishwashers Logo
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
