Question about Ronco Kitchen Appliances - Others
Stripped drive gear
Drive gear stripped
  • 3197 Answers
SOURCE: The nylon drive gear on Craftsman Garage Door keep stripping
The most common reason for this is a door that is too heavy. Release the door from the opener and lift it by hand. If it is heavy to you it is heavy for the opener. Be sure after replacing the gear to lubricate it heavily with the lubricant supplied with the gear. You can't apply too much.
Posted on Jul 06, 2009
  • 92 Answers
SOURCE: Gear after the motor is stripped
yes it can
Posted on Aug 28, 2009
jdlipscomb41
  • 157 Answers
SOURCE: stripped gears
try ebay.com
Posted on Oct 26, 2009
swolfinor
  • 504 Answers
SOURCE: Powerdrive PD422D 1/2 HP Security Plus Screw Drive Garage Door Opener: my garage door unit acts like the gear is stripped...
DOES IT MOVE AT ALL OR JUST RUN??
IS THE ROPE RELEASE PULLED??
IF THE GEARS ARE STRIPPED IT WILL NORMALLY MAKE A GRAVELLY SOUND. AND THE DOOR WILL MOVE BUT NOT LIKE IT SHOUL.
TRY DISCONNECTING THE DOOR FROM THE OPENER & SEE IF THE TRAVELER MOVES NORMALLY.
Posted on May 27, 2010
  • 1218 Answers
SOURCE: Drive gear on Royal 150MX
Yes you should be able to get parts...contact Royal at 1-800-524-0799 for availability and prices.
Posted on Jul 20, 2011
Why distributer drive gear lays done
check the drive system for the distributor
ford employ a shaft that drives the oil pump and if the oil pump is under undue stress, it strips the gear or breaks a shear pin
all the gear is driving is a distributor shaft and in the first instance could be a seized bush for the shaft but with replacements failing I would be looking further afield , like an oil pump
Apr 04, 2016 | 1994 Ford Taurus
Where is the fuser located on MXC 311
The fuser unit is located in the right hand side of the machine. If you open the right door, inside the upperpart of the machine you will see 2 grey handles, 1 towards the front of the machine, the other towards the rear. If you pull these handles out you can then remove the fuser unit. There are 3 known faults for loud fuser noises,1 is the fuser drive gear inside the machine strips the teeth on it, second, the main drive gear in the rear of the machine strips the teeth(usually caused by the 1st problem getting broken teeth stuck in the remaining teeth causing the drive motor to strip the main drive gear) & thirdly, the pressure release mechanism breaks on the fuser unit itself. If it is any or these then unfortunately you will need the assistance of a dealer to replace the damaged parts.
Hope this helps.
Dave.
Oct 13, 2014 | Sharp Office Equipment & Supplies
Wipers jammed half way up but motor still going and maiking a noise
Possibly the gear inside the moyor is stripped.. OR The drive shaft at the motor is stripped or disconnected. .. stripped drive shaft most possible.
May 26, 2014 | 2005 Audi A3
Drive shaft spinning and it will not go into gear.
If you put your cycle in gear and the drive shaft spins, but the motorcycle does not move, you probably have stripped worm gears in the final drive housing. Take off the large fill cap on the side of the final drive housing and inspect the large gear visually. It is probably cheaper to buy a final drive assembly and replace the whole unit than to pay the labor and parts to rebuild it. ($700 for the 1100, $850 for the 650)
Jul 12, 2011 | 2003 Yamaha V Star Classic
I have a Heritage Softail 87 on my way home I lost all gears, clutch feels fine, and I can feel it select gears but still no engagement of the gears, the bike also runs fine but no neutral light. Cheers...
Put the bike in gear with the engine not running. Try to push the bike. If the bike rolls freely, the final drive belt is broken. Check the tension on the belt. The only other thing that I can think of is the final drive belt front pulley has stripped out. The early belt drive bikes, the front belt drive pulley was very thin in the area where the splines were cut for the final drive gear. In 1994, Harley can out with an improved front pulley and offered a retrofit kit to replace the earlier models. When the front pulley strips the splines out, it will not drive the rear drive belt. The final drive gear simply turns inside the center bore of the pulley.
To change the belt on your Softail, you'll have to pull the outer primary cover, the entire primary drive mechanism, the inner primary, the starter, the exhaust system (to get the starter off), the rear wheel, and the swing arm. If the pulley is bad but the belt is good, you do not have to pull the rear wheel and the swingarm.
Good Luck
Steve
Apr 21, 2011 | Harley Davidson FLSTC Heritage Softail...
May 17, 2010 | Chamberlain Powerdrive PD422D 1/2 HP...
A drive gear seems to slipping when the blade cuts into thicker s
Yes you can get parts for it.The gears tend to strip the teeth.
Jul 06, 2009 | Homelite Expand-It Hedge Trimmer...
Jul 05, 2009 | Sears Craftsman LiftMaster Chamberlain...
Kitchen Appliances - Others Logo
35 people viewed this question
Top Ronco Kitchen Appliances - Others Experts
Andrew Taylor
Andrew Taylor
Gil Shultz
ray gallant
Are you a Ronco Kitchen Appliances - Other Expert? Answer questions, earn points and help others
