Question about Gigabyte GA-G41M-ES2L Motherboard
G41 circuit schematics
Biostar g41 m7 wont power up after installing cpu
have you an ATX/BTX PSU?
with 24pins ATX + 4pins P4 connector?
if you haven't that it's normal that's don't work
else your PSU 5Vsb or/and your motherboard are dead
Nov 19, 2012 | Biostar G41-M7 Motherboard - Socket 775,...
Does the Biostar G41D3 Intel G41 Socket 775 Motherboard except a single 4gb memory module
Yes, with one you will not run in dual channel mode but, depending on what you are doing,may not notice any difference.
May 09, 2012 | Biostar G41D3 Intel G41 Socket 775...
I bought Motherboard Biostar G41-M7 , after establishing and setup the utilities the coumputer worked well (all devices except video) , when I operate video files the computer shutdown and...
There are problems with the video files for this board if you are using windows 7. Firstly I'd try downloading the latest drivers and see if that resolves the problem
Dec 29, 2010 | Biostar G41-M7 Motherboard - Socket 775,...
Need 64 bit usb drivers for my motherboard - a Biostar G41-m7
Hi, intially when you install the chipset drivers from the website http://www.biostar.com.tw/app/en/mb/driver.php?S_ID=421 it will install the USB 2.0 drivers for you as it is already in the package. However, I now currently have the same problem as you as it seems that either a Windows Update or other software has removed this.
May 13, 2010 | Biostar G41-M7 Motherboard - Socket 775,...
try this one
Mar 23, 2010 | Biostar G41-M7 Motherboard - Socket 775,...
IBM G41 Backlight
Your problem is likely with the actual back light itself. These can be difficult to replace. I'd suggest replacing the whole LCD panel, you can likely get one by checking out eBay.
can also check www.smartmicrousa.com
www.ccflwarehouse.com
Aug 19, 2009 | IBM G41 Monitor
IBM G41, Can't load fresh Windows XP OS
You will get a better response if you pay for the expertise we have to offer!
May 08, 2008 | IBM ThinkPad G41 Notebook
Gigabyte GA-G41M-ES2L Motherboard Logo
46 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Tony
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
