Question about Canon iR2018N
Why error out of toner . change toner 2018 - Canon iR2018N
Err 553 Ricoh aficio 2018D
SC 553 is a fuser error code, could be thermistor or thermal fuse or fuser lamp
Sep 27, 2013 | Ricoh Digital Copier Toner for Aficio...
Error sc 553
error SC533 is a problem in the fuser check/replace thermistors and check thermostat/fuse for broken circuits. then check the fuser if it is heating or hot then check the contact of the fuser and the machine there might be a loose contact on the fuser and connector of the machine. after checking it reset the machine by the way is this SC 533 for the aficio 2018 or other model?
Sep 16, 2011 | Ricoh Aficio 2018 Copier
I av a problem wit my canon copier ir 2018 .it is having a display red light flashing indicating out of toner while toner is there.wat is the solution of this problem?
TRY SHAKING THE TONER AROUND ----- COULD ALSO NEED A NEW TONER SENSOR
ARE YOU USING THE REAL CANON TONER ? WILL NOT SENSE CORRECT WITH OTHER OFF BRAND TONER .........
Jun 29, 2011 | Canon iR 2016i Black and White Copier
System error e007
This error has to do with the Fixing film sensor detecting a problem with the Fixing Film. Replace the fixing film and it should be working again.
Here is a link to the Fixing Film Assembly:
http://www.precisionroller.com/fixing-film-assemblies---units-for-canon-imagerunner-2018/products.html
Jan 25, 2011 | Canon imageRUNNER 2018 Copier
How to i change the toner cartridge?
Open the front door.
On blue toner handle, press plastic nose, and turn handle in right side.
Pull out toner. Tip: place paper beaneath toner that residual toner dont spill on copier.
Put in new toner, while holding the handle pull out red tape, all the way.
Then turn toner, by handle, in left side.
On inner side of front cover are instructions for how to change toner.
Jul 10, 2010 | Canon imageRUNNER 2018 Copier
Toner will not insert into copier. Image runner 2018. Generic GPR-18 cartridge used.
Stay away from the generic toner. They are nothing but trouble and can make a bad problem even worst. If there is generic toner loaded in the machine, the toner hopper unit should be vacuumed out by a tech. But if this is your first attempt to install generic toner and you have been using original canon toner you should be able to install it as long as nothing is broken.
May 20, 2010 | Canon imageRUNNER 2018 Copier
Waste toner full..
Open the front door and the left door.At thefront door were you remove the toner,next to the toner there is a blue lever.Release the leaver and remove the drum unit.On the drum unit there is a plastic plug remove the plug and though all toner in the dusbin.Do not use this toner again.
Feb 17, 2010 | Canon imageRUNNER 2018 Copier
Where is the waste cartridge for the canon ir 2018
If you open the front cover and release the leaver of the drum unit.Remove the drum unit.On the drum itself is a plastic plug,remove the plastic plug and remove the waste toner in to a bin.The waste toner is stored behind the drum and must be removed reguarly.
Dec 14, 2009 | Canon imageRUNNER 2018 Copier
Canon iR2018N Logo
15 people viewed this question
old marine
old marine
