Question about Toys
The safey belt on my Eddie Bauer swing is broken.
The plastic piece that fastens the safety belt on my Eddie Bauer Classic Wood Swing is broken. I contacted the manufacturer several times for a replacement part when it intially broke three years ago. I never received the part and gave up after my daughter got too big to use it anyway. I am now expecting another child and would like to be able to use the swing this time.
Any idea on how to get replacement part????
  • 867 Answers
Often with a trip to a hardware store you should be able to fine something you could replace it with, and probably it will be stronger than the original
Posted on Jun 15, 2009
I bought an Eddie Bauer infant swing 2nd hand and it won't swing. I put new batteries in but still it won't do what its suppose to. Any ideas?
Does it play the tunes? If not, verify that the batteries are installed correctly. If that is not the problem, read on:
I don't know about your particular infant swing, but those I have seen use a vibrating motor to drive the swing. This a small electric motor with an intentionally out of balance weight on the shaft. When it spins, the whole assembly shakes. The drawbacks to this design are that the weight may come loose so the motor spins without turning the weight, the wires to the motor may break off from the vibration, or the motor bearings may go bad from the heavy wear.
You would need to open the housing to see what the problem is. A broken wire is usually easy to repair if you are good with soldering. A loose setscrew on the weight can be secured with a thread-locking compound. A worn motor bearing, on the other hand, cannot be economically repaired. (The shaft of a worn-out motor will have a lot of side play - if it's worn to the point of failure, the armature inside the motor may drag on the field magnet and be hard to turn, or the motor brushes will not make proper contact with the commutator.) These motors are generally very common varieties and are available from Jameco Electronics or Radio Shack. For example, Vibrating Motor 3 Volt DC 75 mA is $3.25 plus tax and shipping.
Nov 30, 2014 | Eddie Bauer Baby Gear
How do I change batteries on Eddie Bauer "Gentle VIbrations" baby swing?
i believe it uses 4 c batterries there is a compartment at the bottom and it screwed in with a philips screw. you need a philips screw driver number 2
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/tony_a41fa0b801734e2f
Aug 29, 2014 | Baby Gear
Need directions to install a replacement ******** a safey 1st easy care swing tray booster seat
The question has not published fully. Which part are you trying to replace on the Safety 1st Easy Care Swing Tray Booster Seat?
Sep 09, 2012 | Safety 1st Easy Care Swing Tray Booster...
I bought a used Graco baby swing (I think from about 2001) and I can't fiure out the buttons. There are four - low-timer- high - music. It has 6 speeds, 15 songs, and time listed on the front. I don't...
YOU NEED THE MODEL NUMBER then follow link below
LOOK FOR THE MODEL NUMBER
  • BOUNCER On the back of the vibration unit, below the battery compartment door
  • OPENTOP™ SWING Inside the battery compartment behind the batteries
  • WIND-UP SWING On the underside of the top housing- the piece of plastic that runs across the top of the swing and is right above the baby's head
  • TRADITIONAL SWING Under swing tray
  • TRAVEL LITE™ SWING On the bottom of the contoured plastic seat
  • SWEETPEACE™ NEWBORN SOOTHING CENTER On the bottom of the seat
  • DUETSOOTHE™ SWING + ROCKER On the underside of the housing
  • DUETCONNECT™ SWING + BOUNCER On the underside of the housing
  • DUETCONNECT™ DLX SWING + BOUNCER On arm with motor hub
  • LITTLE LOUNGER™ Inside leg near Rock Lock
  • DUET ROCKER™ Backside of front plastic panel with Graco Logo
  • GLIDING SWINGS Under motor housing unit (electronics hub on right hand side of swing)
  • SIMPLE SWAY™ INFANT SWING On tubing on bottom of unit
  • COZY DUET™ SWING + ROCKER Under battery hub on back of swing
  • DREAMGLIDER™ GLIDING SWING + SLEEPER On side hub with electronics
Product Instructions Search Results
Jan 01, 2018 | Graco Toys
I have the Eddie Bauer Classic Wood Swing that wont swing. The music still plays but the swing function will not turn on. I replaced the batteries just in case and that still did not help. What could be...
take apart the side with the on and off switches take apart the swing arm, remove the plastic cover over the motor look at the
blue wire from motor thru the plastic all the way to the contrl board prob broken where it goes thru plastic from motor looks like it happens alot
Sep 07, 2010 | Eddie Bauer Baby Gear
Washing Carseat Fabric
You may have solved this problem already, but I had a similiar situation. If you can remove the round hard plastic fasteners that the straps pass through, it really is not too difficult to take the pad off. They are just clips that push against the hard plastic back of the seat to hold the straps in place. To remove them, I just took a flat head screw driver and placed it against the long side of the fastener and pushed up and toward the center of the fastener. I did this for both sides of the fastener and it popped right out. The straps then just unhook from the back and thread through to the front. Make sure to note how the straps are placed so that they can be replaced correctly. The pad washed up very nicely for me. I used warm water and regular detergent. I let it dry in the sun. Hope that this helps.
Jun 10, 2009 | Eddie Bauer 31447 Booster Car Seat - Sage
Eddie bauer stroller manufactered in 2002 need model #
personally i would go cut off the seatbelt off of another old stroller or swing or bouncer and sew it in myself lol I got my son the Urbini Reversi stroller and the Sonti car seat that goes with it and im sooooo happy with i can just pop the care seat on to the stroller and go with no hassle
Jun 22, 2017 | Eddie Bauer Lightweight Travel System...
Eddie Bauer Classic Wooden Swing
where did you purchase the swing?
Sep 28, 2008 | Toys
Toys Logo
132 people viewed this question
Top Toys Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
