Question about Konica Minolta Minolta Bizhub C353 Copier
Where do I find the motor connector in the bizhub c-353
I am trying to locate the motor connector in the bizhub c-353
  • Konica Minolta Master
  • 6,161 Answers
For which motor and which connector there are about eight motors and about 70 conectors
Posted on Jan 14, 2016
BACKGROUND BLUE
may be
-paper already have a blue back ground or any color.
-from CIS (camera) or Main board.
you can check option named drop out color.
Mar 19, 2016 | Konica Minolta Bizhub C 353, Bizhub...
I have documents hung in que that has machine not printing
need details - what OS, is it hardwired via USB or connecting via network or wifi - could be port is blocked in your router's firewall, could be port is blocked in the PCs firewall, could be lots of things. Not sure what you mean by going online to clear documents - online where? is this a "cloud" printer? try shutting off printer for 20-30 sec then restart it - that may clear docs stuck in it's internal memory. going to need more details if you expect anyone to offer more detailed troubleshooting.
Dec 10, 2014 | Konica Minolta Bizhub C 353, Bizhub...
Konica minolta bizup c550 printing black copy what will i do?
The corona housing for the back drum need to be replaced. Get a new black image unit drum and developer units
Aug 15, 2014 | Konica Minolta Bizhub C 353, Bizhub...
Errore Trouble code C-C172
Refer to Konica Minolta Bizhub C451 Printer/Scanner/Finisher's User Manual or Call Service Center.
May 01, 2014 | Konica Minolta Bizhub C451...
Bizhub 353 c-c172
You meet a Bizhub C-353 with a Code of C-C172, which is a problem that will require tech to look at. It deals with your control board and Non Volatile Memory which houses special info and counter information, it is either bad or the main board, hopefully the tech can come out and re flash the copier software, Or replace NVRAM chip, worse case the main board, he might check all the connectors on the boards for a loose connection or a bad pin, unless you want to that let say 50 connectors, any you might cause more problems worse case the tech say main board need to be replace, you can not get the software for the copier on line. It is located on a secure server at Konica Minolta website for dealerships and KMBS they like to protect there software.
Feb 24, 2014 | Konica Minolta bizhub 250 All-In-One Laser...
C 172 on minolta 353
is that a c353 or a bizhub 353, code normally have four C-XXXX
Jan 30, 2014 | Konica Minolta bizhub C450P Laser Printer
Konica minolta bizhub c450 error code c- d370
I have minolta c450 show error c d370... how can I solve this problem... plz reply me with solution.
May 14, 2013 | Konica Minolta Bizhub C 353, Bizhub...
BizHub 353 error code C-4152
Polygon motor rotation trouble
-Check the connector for proper connection and correct as necessary.
-Change PH unit.
-Change REYB/PH.
-Change PRCB
Feb 13, 2013 | Office Equipment & Supplies
Machine showing error D370
when machine waqs working atonce power failure occurred and after that it showed error D370
Oct 26, 2012 | Konica Minolta Bizhub C 353, Bizhub...
Konica Minolta Minolta Bizhub C353 Copier Logo
37 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
