Question about Braun Silk-epil Cosmetic Hair Remover EF 20
Stopped running will not run even with new batteries
E300 razor scooter would run then stop then run then stop. Is it possible it is the batteries even if they read 12 volts on a meter?
Well how long between runs and stops? Batteries can be bad even with 12+ volts on a meter with no load. Is the on/off regular like the controller cycling, or irregular like a damaged wire? The hall sensor in your throttle could be causing it, if it's loose or not working properly. You can open the throttle with a socket and a screwdriver. Check all wiring, check the batteries under load. If you say more about the frequency and duration of the stops and run periods it would help.
Jun 16, 2015 | Razor E300 Scooter
71 c10 not staying charged... new battery alternator fuses good and new voltage regulator
Maybe it wasn't running long enough to charge up the battery?
Stop trying to jump it, when you are having problems with it dying, take the battery off and have it charged. And/or buy a $20 voltmeter to see what the battery shows. If it says less than 12 volts, it is discharged, and needs charging. A good battery that is not run down should have at least 12.5 volts. A new battery that is charged should have very close to 13 volts, maybe 12.8 volts.
When you have the truck running, check the alternator for charging. You put the voltmeter right on the battery and check it again. This time, with truck running, battery should show at least 13.5 volts. That shows the alternator is working. A good alternator will put out about 13 or 14 volts-the regulator will keep it from going any higher to prevent problems, like a melting battery or electrical parts burning out.
I would say get the charging system working right, then address the problem of dying at stop lights. That could be a carburetor problem, if the alternator is working.
Aug 15, 2013 | Chevrolet Cars & Trucks
89 lincoln,while the car is running it will just quit, got a new battery and the alternaor seems to be alright. It will quit running and will not start on its own, get a jump start and will run for...
It sounds like the alternator is the problem and that the starter is on it's way out. Even if the alternator tests okay with an amp meter, it can still be an issues, especially if it is more than 2 years old. If you continue to run the car without changing the alternator and doing a light tune up, you'll probably need a new battery too, even though you just got a new one. If you have to jump it more than three times in a week, the battery gets over loaded, even new ones.
Aug 11, 2010 | 1989 Lincoln Town Car
My watch is 8 months old and just stopped..the screen still displays the exact time and date that it died..but because it's digital if it was the battery the screen should have gone blank?!!
Best bet is to start by replacing the battery. At 8 months it'll be due for one soon anyway and a new battery may "reboot" it so it runs again. As a battery wears out it doesn't just stop, it may still maintain the display even though it stops keeping time. Also, new "e-ink" displays require no power to maintain the display 0 only to change it.
Apr 28, 2010 | Columbia Digital eBook Watch for Women
The radiator fan runs continuously after engine is off.
the temperature sender unit activates the fan
replace it! & get a new mechanic!!!!
Cheers Rob
PS:
im in AUSTRALIA & I just dont believe how much you guys get ripped off!
ITS STAGGERING!!!
Jul 20, 2009 | 2000 Renault 181
The computer will only run from a fully charged battery.
friend
the problem clearly shows the fault is in the motherboard
thanks
Apr 10, 2009 | Toshiba Qosmio G35-AV650 Notebook
Health & Beauty Logo
20 people viewed this question
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Gary
Gary
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
