Question about Dyson DC05 Cylinder Bagless Canister Cyclonic Vacuum
I need to change the filters on a miracle mate vacuum
Where are the filters located and how do I get to them off?
Miracle Mate Platinum. Why does it get hot & turn off?
Carmen,
Sounds like the motor is overheating possibly because of a clog or maybe a filter that needs to be cleaned. Make sure you have a new bag and clean all the filters and hopefully that will take care of your problem. Hope this helps!
Jun 04, 2015 | Vacuums
Miracle mate vacuum will not turn on
put a brand new switch on it and that should solve your problem the switches on vacuums go out all the time causing people to through a great vacuum out and I pick them up put a new switch on them and then they work like new
Mar 20, 2014 | Vacuums
Miracle mate power head not getting power
Most likely you have a broken wire in the neck assembly, where the wand meets the floor nozzle. To check unplug the cord and remove wand from floor nozzle. On the neck, remove 3 small screws and slide the cover off the back of the neck. You will see 2 wires, one white and one black. Gently tug on each to see if if they are connected. If one is loose you have the problem, if not you will then have to remove the five screws that hold the cover on the nozzle body and trace the connection to the circuit board.
Aug 18, 2012 | Vacuums
My miracle Mate vacuum doesn't have suction.
you might have to take the hose off and blow through it, mine had the same problem and it was full of trash, it works fine now.
Jun 11, 2012 | Vacuums
I need a operators manual for a miracle mate platinum vacuum
Hello Skip798,
Please visit the link provided below for all detail for Miracle Mate Platinum Vacuum :
http://miraclemate.com/platinum.html
Dec 26, 2011 | Vacuums
Owners manual for kenmore power-mate # 116
Greetings from GoVacuum,
I wasn't able to find the manual for the Kenmore model, however I did find the instruction manual for the corresponding Panasonic canister vacuum cleaner. Your particular Kenmore model is actually made by Panasonic for Sears, and then Sears puts the Kenmore name on the vacuum cleaner. They are identical internally, and have the same parts and components, besides the filter that is behind the bag. Sears makes Panasonic put a specially designed filter in the Kenmore's so that the customer has to go back and purchase that filter from Sears.
To download the instruction manual, please visit the link below;
Owners Manual For Sears Kenmore Power-Mate Model 116.3489890C
You can also find a parts schematic of the power head below if you need to purchase parts;
Parts Schematic For Sears Kenmore Power-Mate Model 116.6489890C
I hope that this information helps you. Please let us know if we can provide you any further service, or if you have any further questions we can answer. You may email me at chris (dot) jones (at) govacuum.com.
If this helped you, please click the Helpful button below.
Chris Jones
GoVacuum.com
Mar 18, 2010 | Kenmore Vacuums
Dead Miracle Mate Vacuum cleaner
You don't have to open the cannister. You can easily remove the black plastic collar through which the cord is supposed to emerge. The collar has a little springy tab that holds it in place. Once the collar is removed, you can reach in and grab the cord and pull it out.
Steve
Aug 02, 2009 | Vacuums
Our Hoover floor mate won't **** up the water. Motor runs but pick up is limited.
you will need to replace the squeege that is located on the nozzle. 3 screws will take it off. you can get this at a vac shop or order it from the company, filter may also need to be changed
Jul 18, 2009 | Hoover Floormate H3000 Upright Wet/Dry...
I have a miracle mate platinum vacuum. How do I
You can always call the toll free number on their paper bags and ask for a service tech. They have walked me though a motor replacement after my kids sucked up water.
Mar 07, 2009 | Vacuums
Model 116 hose clog?
http://geeksquad.fixya.com/ThreadView.aspx?prdid=109459&thid=699656
Posted by rfrazelle on Jun 23, 2008
My old canister model 116 followed with numbers 2839580 marked Kenmore 3.9 with power-mate, worked fine until the bag got overly full. I have changed the bag, cleaned the filter, and removed a nasty hair/fur/dust clog :-p from the lower metal tube of the power mate. It now has very weak suction and won't pick up anything. I suspect a clog in the grey plastic flexible tubing attached to the canister but cannot get it apart. Advice?
RJ
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Kenmore 22313 Bagged Canister Vacuum. The best way to find a clog in an electric hose is to use a steel ball or a large marble to place inside the hose and to let it so threw as far as it can to determine where the hose clog is. Once you have determined where the hose clog is then you can use a small end of a broom handle of take an old wire coat hanger and place a hook on the end and try to pull the clog out of the electric hose – the electric hose is very expensive so try not to damage the hose in any way, shape or form. Or another way is that id you have another canister vacuum you can try to pull the clog apart by using two vacuums turned on and running. If you are successful then run the round marble or steel ball thru the hose again and the clog should be cleared.
http://www.sears.com/ Customer Service 1-800-4-MY-HOME 1-800-469-4663
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 23, 2008 | Kenmore 22313 Bagged Canister Vacuum
Dyson DC05 Cylinder Bagless Canister Cyclonic Vacuum Logo
107 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Nick Olsen
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
