Question about True TCGG-36-S
Compressor cycling on, and off. - True TCGG-36-S
    Novelist:
    Scholar:
  • 187 Answers
Not too many things to say when it has gotten to that point. Check the condenser to make sure its clean and the fan is running. Make sure that the electric cord is plugged in and making a good connection. If you put gas in you may have too much in there, possibly the start relay and capacitor have failed. After checking the condenser and plug I would suggest calling a refrigeration tech. Good luck and hope this helped.
Posted on Oct 18, 2014
Ac works but when compressor cycles, it wont come back on until i rev engine to 4500 to 5000 rpm's and compressor kicks back on until it cycles again. i have to repeat reving engine every time com
you need to check the pressure of the system if the system is a little low on freon it will cycle more also if the cooling fan is not working the pressure will raise and also shut off
Aug 17, 2012 | 1997 Nissan Pickup
I have a large walkin freezer and the compressor and heat strip come on at the sametime, I have to disconnet the compressor when the defrost comes on. Im not sure what wire goes where.
Open following links for 8145-20 wiring diagram and resources:
http://waterheatertimer.org/images/8145-20-wiring-350.jpg
http://waterheatertimer.org/Paragon-timers-and-manuals.html#defrost
8145-20 is 240Volt defrost timer.
Heat strip and compressor should not activate at same time.
As a general rule heater connects to NO terminal 3 and compressor connects to NC terminal 4
NC terminal 3 compressor is on all the time until defrost cycle begins.
NO terminal 4 heat turns on when defrost cycle begins, and at same time NC terminal 3 compressor turns off.
At then end of the defrost cycle, NO terminal heat turns off and NC terminal 3 compressor turns on again.
Jun 29, 2011 | Paragon 8145-20 Defrost Timer
My compressor suddenly quit cycling what went wrong?
hi there!
there are several factor on cycling failure, most common on it is the pressure switch device,checking on this,plug out or switch off main circuit breaker for compressor, disconnect pressure switch if this is a single phase connection,there are two supply wire coming in and two wire coming out on pressure switch.direct connection of compressor motor on power supply to test if it is cycling manually,after direct connection of motor compressor to power supply w/out pressure switch,switch on for 5 to 10 minutes o build a low [pressure then swict off again,then switch on again even there is a low pressure observe if there is cycling motor running if this done replace pressure switch.if still have same problem motor tripping another case not to cycle bring this to electric motor service center.have a nice day dont forget to fix my rate.
May 07, 2010 | Campbell Hausfeld 04 Gallon Twin Stack...
Compressor cycles only occasionally, not cooling well
the compressor cycles as needed, don't worry about the compressor if the temp is correct!!
Nov 15, 2009 | Marvel 61AR Compact Refrigerator
Compressor seems to cycle on and off 2005 nissan maxima
For protection of your compressor the system has a low pressure cut-out switch that turns the compressor off when pressure is too low (normally due to insufficient charge). This cycling on/off indicates low freon level. Charge the system and you'll be OK.
Jun 29, 2009 | 2005 Nissan Maxima
2005 Toyota Corolla A/C compressor cycling problem.
Could be low on freon. Or the cycling switch is bad. Hope this helps.
Jun 20, 2009 | 2005 Toyota Corolla
Cycling compressor
The pressure switch will shut off when the set pressure is obtained. Usually about 100 to 120 lbs. If the compressor stops at lower pressure than mentioned you may try to adjust the pressure by looking under the switch cover for adjustment screw/nut.(no more than a few turns) Increase pressure by increasing spring tension. Quick cycling is usually caused by air leaking from tubing, drain valve or check valve. After compressor shuts off unplug it from the outlet and spray soapy water on all fittings and drain valve. Repair leaks and test for quick cycling, however the compressor should reach 100-120 before shutting off. Some small compressors have a thermal reset but that usually takes a few minutes to reset. Pressure switch is defective if it shuts off before setting mentioned. Enjoy
Dec 11, 2008 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Compressor short cycling
If the compressor is run off of a relay then you could install a delay timer to prevent short cycling.
http://www.climatedoctors.com/items/item.aspx?itemid=429504
Jun 04, 2008 | Dometic Heating & Cooling
Refrig compressor "knocks" when cycling off
could be a broken spring inside the compressor and would only make a noise as the compressor stops. nothing you can do about it. you would need to break open the compressor, replace the spring, weld it back, then charge it up again with refrigerant.
Feb 11, 2008 | Refrigerators
True TCGG-36-S Logo
35 people viewed this question
Top True Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
Are you a True Refrigerator Expert? Answer questions, earn points and help others
