Question about Crosley CDE6000 Electric Dryer
Drum wont turn
Smells like it is burning and drum won't turn
    Sergeant:
  • 446 Answers
Check your belt and idler pulley. could also be the motor
Posted on Nov 04, 2015
LG WM 0642 HW Direct Drive Making a thumping sound when spinning and smells like burned rubber. Smoke coming out of durm when front load door was opened.
Hi Paul.
What you're describing is probably the inner drum rubbing on the door seal.
It could be because the rear bearing assembly has collapsed or because the drum is distorted.
Turn the drum slowly by hand and see if the gap between the rim of the drum and the rubber seal stays the same. This will tell you if the drum is 'round' or bent out of shape.
Alternatively, if the drum flops up and down inside the outer drum it would be because of bearing collapse
Either of these situations would require a service visit and parts.
Get a quote...
Good luck.
Nomess
Jan 11, 2015 | LG Washing Machines
Whirlpool duet ghw9250 smells like burning rubber and very loud
Does the drum turn, if not then the drum bearings may have siezed.
Dec 30, 2012 | Whirlpool Washing Machines
Older topload maytag won't agitate , smells like burning belt
Best to look at replacing belt, but first check to make sure nothing is seized, drum spins freely etc.
Jul 23, 2011 | Washing Machines
Washer wont spin, smells like burning rubber
The burning rubber smell is coming from the belt which goes around the drum and is driven by the motor. The belt has probably stretched and is now slipping. It will need to be replaced.
Jul 13, 2011 | Washing Machines
We have a MMDE9206AYM model dryer that makes a low humming sound but will not start. Last night it also produced a burning smell. I assume either the belt is gone or the motor is overheating although it...
Sounds like drum is locked and motor is running and burned the belt. Try to spin drum by hand, Might check drum ends felt seals, Teflon bearing strips located on the bottom lip of front drum end for wear causing drag. Also check 2 drum support wheels to see if they spin freely, take the belt off motor pulley and spin drum by hand, if easier & motor runs drum is dragging. How is the spring on tensioner, does tensioner pulley spin free? Hope this helps locate the problem.
Feb 13, 2011 | Maytag Dryers
I have a Kenmore Electric Series 80 Dryer that the drum inside won't turn but it heats up and smells hot like something is burning. I can however turn it manually.
Remove the top and the front panel to remove the drum after you purchase a belt and teh idler pulley that Sears selles for your dryer. The pulley's bearing has froze up causing the belt to burn up and falling off
Jan 22, 2011 | Kenmore Dryers
The drum wont go around and it smells like its burning.
if you can turn the drum by hand it may be the motor start capacitor.fitted just above the motor if you cant turn the drum one of the drum seals will have jammed the drum the belt will have snapped as well.
Aug 06, 2010 | Zanussi TD4112W Electric Dryer
DRUM WONT MOVE SMELLS A LITTLE LIKE IT'S BURNING
well the drum should rotate...it has a broken drive belt or the mechanism has failed on the drum rotor
Jul 20, 2010 | Frigidaire GLEQ2152ES Electric Dryer
Hoover 600MD wont spin dry
it seems that the motor problem you should replace it
Apr 17, 2010 | Washing Machines
Maytag dryer, LDG9334, won't start to rotate, burning smell
Hello Friend, From my experience, it sounds like the motor is tired and getting ready to fail. Only option is to replace. Happy to help, Tim.
Jul 11, 2009 | Dryers
Crosley CDE6000 Electric Dryer Logo
60 people viewed this question
Top Crosley Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
charles
Are you a Crosley Dryer Expert? Answer questions, earn points and help others
