Question about Intermatic Inc. ST01C Digital In-Wall Timer
Need help programjng
Have 3 sec. to set my timer . what am I doing wrong
How do u use the rc6 for instint photos not two second. What do you set on the camera. 5D mark ll
don't set for 2 sec, set the camera to 10 sec self timer and click the remote, should work instantly with every click. just remember to set for regular shooting if not using the remote. can be very annoying to wait 10 sec for a shot, unless you want to be in one?
Jul 04, 2011 | Canon RC6 Wireless Remote RC 6
AEG single oven - clock runs for 12 hrs , buzzes and goes back to 12 o'clock - if set timer and check time remaining, it buzzes and jumps to clock setting loosing time remaining. Buzzer sounds ''hoarse''.
you must setting the count down timer instead of time of day. to set time of day. press centre button 4 times lamp flashes in bottom righthand of display. use + and - to get correct time after 10 secs time will lock in. to check you have not set count down press centre button 3 times lamp flashes top right corner of display if not at 0000 use - button to get to 0000 leave 10 secs then should revert to time of day. also check you have not entered cooking time. press centre 1x this also should read 0000. hope this helps
Jul 17, 2010 | AEG B2100-4 Electric Single Oven
I have 3 lights and want 1 light to come on for 15 sec and then off and another 1 to come on for 15 sec and then off and then the last light to come on for 15 sec and then off and start the process all...
Intermatic 70815CR
30 amp max, selectable voltage 120V 240V etc.
You want to control 3 separate circuits.
So you need a timer with minimum of 3 independent relays.
Each circuit has a different program.
So you need a 3-channel timer. Each channel is programmed separately to operate a different relay.
You want timer to operate in 15 second intervals. Most electronic timers have minimum 1 minute on-off, so you need electronic timer with pulse capability.
May 11, 2010 | Amperite Dayton Solid State Timer On Delay...
Stand by timer shuts tv off after 30 sec sony tv
Sounds more like it's been set to do that. Use the following to shut off the timer mode. It's possible that the set is set to the wrong time of day but that is unlikely. You can shut off the timer mode using the on screen menu. Follow the instructions below.
Using the Timer Menu
Current Time Set your TV to the current day and time. Press to open the Current
Time menu:
1 Use the F or f buttons to enter the correct day and time, then press
2 Press to exit the menu.
Timer 1 and
Timer 2
Scheduled
viewing
Use the timers to program your TV to turn on and off by day, time,
duration, and channel. The timer duration is a maximum of six hours.
When the channel is fixed, it is not necessary to set the channel.
1 Use the F or f buttons to highlight Timer 1 or Timer 2, then press
2 Use the F or f buttons to enter the desired day, start time, duration,
and channel, then press . The timer status should be On when the
Timer has been set, and the timer light on the front panel of the TV
should be on.
3 Press to exit the menu.
? When you perform Auto Program, Timer 1 and Timer 2 settings will be cleared. Also, in the event of
any loss of power, Current Time, Timer 1, and Timer 2 settings will be cleared
Apr 16, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
I want a programmable timer that can, eg, switch on a single phase electric motor for 10 seconds every hour. It may be 9 secs or 11 secs.
You need a programmable interval timer.
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#ET70
Intermatic and Tork make digital timers with interval settings that can be set for specific short-duration with 1 minute minimum.
(Or set to pulse bell ringing with 1-127 seconds.
10 minutes is 600 seconds)
For example ET70115 single-channel timer.
The timer would be set for 24-hour operation, and then programmed for Pulse, and then set timer with 24 programs, with 1 program for each hour.
Mechanical cycle timers from Intermatic:
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#cycle
1) Talento 1 hour cycle timer/ each tripper represents 1.25 minutes
2) Model C8835/ each tripper represents 15 seconds.
To operate these timers certain hours of the day, add another timer in-line.
The in-line timer could be digital, but remember digital timers are not protected from power surge and tend to have more problems, and do not have replaceable clock motors and trippers.
Apr 08, 2010 | General Electric GE 24-Hour Timer, 2-Pin...
How do you set the self timer to 20 seconds?
1. Go to the "Custom Menu"
2. Go to item 16 and set the self-timer duration (2, 5, 10, 20 secs.)
3. Go to item 4 and set the Shooting Mode to "Self-Timer"
You can also set the FN button to do this (item 11).
Oct 11, 2009 | Nikon D40x Digital Camera
I cant figure out how to set the self timer on this camera
If you press the left < button on the camera before you take a picture you will have the option to set the self-timer. The options that you can choose are: 1. Single shot; 2. Continuous shot; 3. Self-timer (10 sec) / Remote control; 4. Self-timer (2 sec); 5. Self-timer (10 sec): Continuous (2 - 10 shots).
Hope this helps!
Please rate!!
Cheers
Oct 01, 2009 | Canon EOS Rebel XSi Digital Camera
How do I use 360' lens on my Canon G9?
The C1 & C2 settings are for "Custom" settings. You'll most likely want to set your camera either to "P" or "Auto" mode.
To have it delay for 10 seconds and take 3 shots, press the "Menu" button and then scroll down to "Drive Settings". Then, choose the following settings:
Self-Timer: "C" Delay: 10 sec. Shots: 3 shots
Then, press the "Func./Set" key to lock in the change. Next, press the custom timer button on the back of the camera and then choose the "C" timer using the directional keys. Then, press teh "Func.Set" button.
Lastly, set up your camera, press the shutter release, and the timer light should start blinking. 10 seconds later, the camera will take 3 photos in succession.
Hope this helps!
Mar 10, 2009 | Canon PowerShot G9 Digital Camera
Front panel timer/stand by blinking light
did you clear the code by hitting display channel 5 volume up then power then press 8 enter or look at sony blinking codes to reset to factory settings
Sep 10, 2007 | Sony KP-57HW40 57" Rear Projection...
Intermatic Inc. ST01C Digital In-Wall Timer Logo
35 people viewed this question
Top Intermatic Hardware & Accessories Experts
Gene Haynes
Jay Finke
Jay Finke
Hippy_dd
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
