Question about Toyota Forklift Carburetorgas 5k 5f61018
7bws13 fault codes
Toyota model = 7BWS13
TOYOTA ALTEZZA WITH 3S-GE ENGINE FAULT CODES 14 AND 21 MEANS WHAT?
G'day zac, the codes mentioned don't really relate to a 2001 model, the first thing to check though is the fuses for the left bank heater circuit these codes will be there but no apparent difference in performance. Now, is the engine running rough or pinging as the 3s depicts the engine as a twin cam and these 2 codes would indicate that the cam positions are too far advanced. Best course of action would be to get a tradesman to plug in his trusty obd11 fault code scanner and see what comes up on the magic screen.
May 08, 2016 | 2001 Toyota Altezza
I have a 2kd ftv Toyota hilux i change the fuel pump and it didn't start it just crank the ecu is ok. Whats the problem please. Help
run the fault codes to find the fault
could be cam/crank position sensor, immobilizer, ignition module
Nov 21, 2015 | Toyota Cars & Trucks
Fault cade 96
cade = code?
and 96 the code or the year?????????????????????????????
and dyna heavy truck
built 1979 to present, vast forms. what is yours.?????
no engine stated.
my motto:
NO YEAR?
NO MODEL (dyan)
No engine size. (or transmission type A/T or M/T?, if that is in question)
NO HELP (or your joy)
No country , too , is a royal pain , all cars are different by country (laws)
Jan 10, 2014 | Toyota Cars & Trucks
I repleaced all 4 abs sensor on my 1996 toyota avalon, but the abs light still on, what could be the problem?
abs light on means some fault codes stored in your car,
toyota it2 can help you clear the code and turn off the light with airbag.
May 16, 2012 | 1996 Toyota Avalon
Diagnostic codes on my toyota camery are 24 31 52 please what are they
If any of these are wrong it may be due to the fact that you did not give a specific year Toyota.
Code 24, Intake air temperature signal fault
Code 31, Air flow meter circuit or Vacuum sensor signal fault
Code 52, Knock sensor fault
Aug 30, 2011 | Toyota Camry Cars & Trucks
P1036 Fault Code - 2002 Toyota Tacoma
Sorry! I wish I could help you, but fault code P1036 is not a valid code for a 2002 Toyota Tacoma. Read the code again and repost your question.
May 14, 2011 | Toyota Tacoma Cars & Trucks
Check engine light came on after replacing fuel filter?any ideas as to why?
U need to find out what the fault code is that made the check eng lite come on, here is how you run a fault code test on this system.
please go to the link
http://www.extreme-check-engine-light-codes.com/Toyota%20OBD1%20Decoder.htm
Oct 19, 2010 | 1995 Toyota 4Runner
Can you tell what fault code 12 is on a toyota mr2 mk2 sw20 3s ge engine
12 is not a fault code it is the code that tells the user the computer is in read mode of computer diagnostic's. so if the only thing it flashes is 12 then you have no fault codes stored.
Mar 04, 2010 | 1991 Toyota MR2
Toyota Forklift Carburetorgas 5k 5f61018 Logo
52 people viewed this question
Top Toyota Toys Experts
Thomas Perkins
Thomas Perkins
Rabbit Brains
Rabbit Brains
Stan Ford
Are you a Toyota Toy Expert? Answer questions, earn points and help others
