Question about Peavey Music
Remove 15 inch black widow from cabinet
How to get speakrs out of cabinet
Loaded with 2-10" scorpions(8ohm)each, and a 18" black widow (?ohm)...can i load a 15" black widow(8ohm)using the same crossover Part# 90890170
I would assume that the 18" was a 4 ohm if the two 10" were 8 each. Though it might work in a pinch, the crossover point would be different and the balance between the speakers would probably be different as well. It's suggest calling Peasvey Customer Service to get the best answer. Here is their link-
Peavey com
Apr 19, 2016 | Music
Need a diagram for a Peavey 15 inch black widow
Call Peavey Customer Srervice at 877-732-8391 and they'll email it to you.
Oct 14, 2014 | Music
My jbl prx615m sounds like it has something vibrating inside the cabinet.
Pay attention to the source of rattling, if its just the enclosure or comes out from the speaker and let me know to improve helping you out...
Aug 27, 2013 | JBL PRX615M 15 Inch Two Way Self Powered...
How do you remove the Speakes (HF and LF drivers, Woofer and Tweeter). The cabnit does not open. The woofer is secured from behind, requiring the cabnit to be opened to service any part of the speaker. HOW...
They used what is a called a "Miter Fold Machine" to cut the cabinet from one long piece to something you can fold up that looks like your cabinet.
The short answer is they did not mean them to be serviced. However the two methods you can use to get into it are,
1- locate the corner where the ends came together and try work them apart,
2- get a sber saw (mistakenly called jig saws these days) to cut a window in the back of the cabinet. Save the insert and attach it to larger piece that fits over the hole- you will change the tuning of the speaker slightly, but the larger panel with the cutout attached will bring the volume back close to original and the overlapping edges of the patch cover should be sealed to the cabinet. Paint them flat black like the originals and they will look better when done.
Jun 11, 2012 | ElectroVoice Electro-Voice Zx4 15" Passive...
Will an Eminence Beta 15A speaker (`5", 300w, 8 ohm) fit/work in the k3000fx? If so, will there be a trade-off or consequence of performance? I already own the Beta speaker, and have a chance to...
It ill probably work, however I have had to do body-and-fender work on a speaker cabinet where the new frame would not quite set in the existing hole in the mounting board. The Eminence speakers are supposed to be good... are you sure the Behringer amp is OK? The K1800FX uses a conventional linear amp... not sure about the K3000fx... The only possible problem I could see is that the original speaker (Bugera 15 inch)may have a different response and the tweeter may not match too well. You can probably adapt using th EQ should this be the case.
Sep 01, 2011 | Behringer Ultratone K3000FX Keyboard...
Would putting an EVM10DLX into a set of Yamaha BR-10s be a recommended upgrade? Worth the cost?
It is VERY RARE for such a change to be beneficial. The cabinets and speakers are finely tuned to work together and the originals are usually just as good performers as anything you can replace them with. If you want a subwoofer you need to get a larger cabinet and preferably a larger speaker. A ten inch speaker for subwoofer use would require a closely engineered cabinet. Best to go to a single powered 15 inch subwoofer (one designed as subwoofer) to run alongside your BR-10's.
Dec 14, 2010 | ElectroVoice EVM10DLX 10" Subwoofer for...
How can i get more bass out of my frontman 65, it sounds good but it has very bright thin sound. i was wondering if an eminence swamp thang speaker would fix that problem.
Changing the speaker MAY turn out disappointing results. There is a limit what you can get from a 12 inch speaker in the bass range. USUALLY the amp manufacturers match the speaker/cabinet/and amp for about the best performance that can be expected. Want more bass? Step up to a 15 inch speaker.
Nov 01, 2010 | Fender Frontman 65R 65W 1x12 Guitar Combo...
Wiring diagram
Blue should be positive
Aug 05, 2008 | Yamaha Music
Music Logo
14 people viewed this question
Top Peavey Music Experts
Michial Gueffroy
Ben Armstrong
Vito Vacirca Jr.
Are you a Peavey Music Expert? Answer questions, earn points and help others
