Question about Enlight Computers & Internet
Intel 450pa10091 fan not working
What is the ciruit diagram of 450PA10091
Circuit digram of smps odyssey model no 450pa
Sep 08, 2012 | Computers & Internet
I cant remove my fan its an intel D34223-001
Intel D34223-001 is fan and Heatsink assembly for Intel Socket 775. Following are the videos about removing and installing this fan
REMOVING FANINSTALLING FAN
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jun 29, 2011 | Intel (D34223001) CPU Heatsink Fan
My old heat sink and fan have screw in attatchments and the new on has the plastic pop in and 1/4 turns. Help?
Your old heat sink and fan probably works just as as good or better than that stock Intel fan and heat sink. If your computer case does not allow access to the rear of the motherboard you are going to have to remove the motherboard to pull the back plate that was used to attach your old heat sink and fan. To install the Intel fan turn the pins until the screwdriver slot is perpendicular to the fan shroud (the tip of the arrow is furthest out), then push in any 2 opposite sides at the same time into the motherboard. You will here them click in. Repeat for the other 2 pins.
Dec 22, 2010 | Intel Socket 775 Heat Sink and Fan up to...
My pc is getting automatically switched off i checked my smps and its working fine.i got intel i3 processor and mother board DT55C
Intel makes so many claims that their processors won't overheat, but they do overheat. If yours is fan cooled, then check the fan, you may just need to replace it. if it's liquid cooled, check that. I don't know much about liquid cooled. I hope this helps.
Nov 28, 2010 | Intel Motherboard
I brought a new Intel H55Tc Mother board, Core i3 Processor, 2GB DDR3 Ram. Now my system fan and smps fans spindling is not continue. But My SMPS is working well with other mother board.
Dear vijay, Please check your power ic of mother board there is problem. When you change it then your cpu and processor fan will be working.
Thanks. Rakesh.
Nov 26, 2010 | Intel H55TC Motherboard Core i5 650...
I have intel dg41 rq mother board and i am facing a problem , when system heat too much it disconnected the network. when i restart or shut down the system it work properly but after some time internet...
Check the fans on the motherboard, are they all working?
Have you cleaned out the fans and heatsinks ?
Using compressed air, or even the blower end of a vacuum cleaner blow out the dust in the fans and the cooling fins of any large heat sinks, like the one over the processor.
It sounds like the machine is overheating, the dust is probably preventing air from circulating around the heat sink fins,
Nov 04, 2017 | Intel DG41RQ Motherboard & Core 2 Duo...
Noisy fan
You need to replace the fan. Measure the fan you have now and buy one the same diameter. Then remove the old fan and put in the new fan.
May 28, 2009 | Intel (8W501B1M3G) CPU Fan, CPU Cooling...
Intel Cpu Fan ReWiring
Here is the pinout for the wiring:
Pin Name Color 1 GND black 2 +12VDC yellow 3 Sense green 4 Control blue
In case this doesn't show...Black is Ground and Yellow is +12VDC.
Not sure if it will work w/o a Sense (Green) and Control (Blue) line though.
Jan 18, 2009 | Intel (8W501B1M3G) CPU Fan, CPU Cooling...
Intel original motherboard d845gvsr dead
it will be cheaper and more quickly solved if you just replace it go to computergeeks.com very goo site k
Sep 22, 2007 | Intel Motherboard
Computers & Internet Logo
46 people viewed this question
Top Enlight Computers & Internet Experts
gaucherre
Jerry Umali
Raymond Solomon
Level 1 Expert
Are you an Enlight Computer and Internet Expert? Answer questions, earn points and help others
