Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
My DKE is acting up and now opens 2 of my doors with one code
I have 3 doors with LiftMaster belt drive openers and one DKE. For 7 years everything worked fine but all of a sudden one of my doors is opening when I punch in another door's code. Obviously I've always had 3 different codes for each door. Today I punched in the code for door 3 and door 3 opened but so did door 1. The correct code for door 1 still works for door 1, but it now also opens to the code for door 3. So to summarize, code 1 now opens door 1, code 2 now opens door 2 but code 3 now opens doors 1 and 3. How do I reprogram/fix? Thanks, Carlos
    President:
  • 3,197 Answers
If you press and hold the smart/learn button for 6 seconds on opener number 1 it will erase the memory and neither code will open it. Now just program it for button number one and you should be set. If you have remotes for door number 1 you will have to reprogram them also.
Posted on Jun 15, 2009
Put up the opener but when we plugged it in we have nothing?
[PDF]GARAGE DOOR OPENER Model 3265 1/2 HP ... - LiftMaster
www.liftmaster.com/.../en.../tucmanuals/114A3044.pdf Chamberlain GroupThe Chamberlain Group, Inc. 845 Larch Avenue. Elmhurst ... Please read this manualand the enclosed safety materials carefully! ? Fasten the manual near the ...
Sep 03, 2015 | Craftsman 3/4 Hp Garage Door Opener System...
41a4315 7a parts
The gears are all the same with the exception of the belt drive units that have a different top sprocket , you can find the part # on the internet simply by putting in the model # of your opener and identifying whether you have a belt drive or chain drive machine , you can also find the part on Ebay by putting sears/liftmaster or chamberlain sprocket gear assembly in the description ....All 3 of those models are made by Liftmaster being the main Brand ! Liftmaster manufactures the sears craftsmen for Sears and also goes under the chamberlain brand name that k mart and Home depot and Lowes sells ! Liftmaster is the worlds largest manufacturer of garage door openers and all 3 machines are interchangeable with their parts ! Hope this helps you Sincerely Glenn
Sep 01, 2014 | Sears Craftsman LiftMaster Chamberlain...
I have a Liftmaster Elite Series garage door opener. The house is pretty new- about 2 years old. I recently purchased a BMW with an option that includes buttons that can learn to work with any garage door...
You may need to clear the memory/old codes from your auto transmitter. On my auto located on the overhead console there are 3 small buttons side by side. Press the 2 outer buttons simultaneously for 3 or 4 seconds and release. This action will clear the memory then follow your auto instructions to program. Worked for me.
Oct 04, 2017 | liftmaster Chamberlain Garage Door Opener...
I have 2 liftmaster door openers and 1 387lm Wireless keypad.can I program it to open either door?
To program that thing you need to locate the smart/learn button on the back of the opener near where all those white wires go. Press and immediately release this and then walk over and key in any 4 digit code you like and then press 0. The zero acts as the enter button on other keypads.
May 19, 2010 | Sears Craftsman LiftMaster Chamberlain...
The door on my read write drive won't open but I was just using it earlier and all was fine
Try opening the drive with the emergency exit, there is a small hole next to the eject button, insert a pin or needle to open the tray with that, in most cases the drive tends to act like this after 2-3 years of use. not an error with the drive but the belt on the motor that opens the tray gets loose.
Nov 14, 2009 | Dell Dimension 4100 (-JM0TB01) PC Desktop
Installed Chamberlain Whisper Drive but door slides backwards
It sounds like you may have a spring problem. Release the door from the opener and see how it acts manually. Open it as far as the opener does and then see what happens when you release it. Also the weight of the door should give you a clue.
Aug 24, 2009 | Liftmaster, Chamberlain, Sears Door...
Chamberline 1/2 hp belt drive opener that stops opening
It sure sounds like a broken spring. Sometimes the break can be difficult to see. How heavy is the door to lift manually. This will give you a good idea.
Jun 15, 2009 | Sears Craftsman LiftMaster Chamberlain...
Door opens about 18" and stops
Check the drive belt for tightness. Check for a bent or obstructed track. Overhead door openers have a safety clutch built in in case something or someone gets into the path.
Jan 31, 2009 | Sears Craftsman LiftMaster Chamberlain...
Liftmaster security + model 1265 NOT CLOSING PROPERLY
wbuero, I had same problem two weeks. The door springs weaken over time and may need to be tightened - check opening force manually. Manufacturer also recommended reviewing install guide to be sure opener arm is attached at proper angle. The opener on my professionally installed door was not connected properly. It that doesn't work, the opener drive train or door track/wheels may need maintenence.
Jul 05, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
218 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
