Question about Jackson 28 in. TempStar 300X-ST Free-standing Dishwasher
Water temp I need to make the water temp hotter
Why does Temperature gauge reads hotter then normal but engine temp. is ok
some times after market senders read hotter if there not quiet the same value
Aug 15, 2014 | 2002 Audi TT
1998 Honda oddessy runs for twenty minutes then stops
Watch your water temp when it dies, if your temp is hotter than it should be some vehicles come equipped with a water temp kill switch and if this is the case its most likely either your thermostat has gone bad and needs replacing 15 bucks for both it and the gasket or your radiator cap is not retaining the pressure in the system 10 dollars to replace, if this is not the problem let us know.
Jan 29, 2013 | Cars & Trucks
Whie driving on the freeway the 1993 jeep gets hotter and hotter
I think you need a cylinder leakage test done. Possible blown head gasket. No leaks but are you useing coolant?
Jul 05, 2012 | Jeep Cars & Trucks
I have a pentair minimax nt and the heater works fine but it turns of automatically around 92 deg. Any ideas , is it the hi 115deg. or hi 150 deg sensor?
I would most likely suspect the temp sensor rather than a Hi-Limit switch. In other words the temp sensor is thinking the water is hotter than it is and sending the wrong signal. Actually it sends nothing, the resistance changes as the water gets hotter and the main control board turns the heater on and off based on this resistance reading.
Aug 31, 2011 | Pentair Minimax NT Heater
I have a bosch aq125 ding? the hot water is not sufficient to the temperature for a health dept to pass the restaurant to stay open. how do i get a hotter temp? is there something that is clogged or not...
That is a residential unit and at maximum will raise water temp 90 deg at 2 gallons per min.. You need at least one commercial unit with a thermostat that will allow high enough water temp. to pass health dept. requirements, and a self heating dishwasher at a minimum.
Jan 21, 2011 | Bosch & Tankless Water Heater
Can driving my buick without the thermostat hurt
Yes it can. The car will not get up to operating temperature as fast. It's never good to modify a car from its original factory specifications.
Jul 31, 2010 | 1992 Buick Century
& Single Handle Shower Faucet : how to adjust to get hotter water...
First step remove handle and behind it there is a dial that looks like a gear. Mark where it is and remove it and put back in about a 1/4 to 1/8 turn counter clockwise to increase to hotter temp.
These faucets are equiped with anti scald setting's to protect the public and preset for this reason.
May 17, 2010 | Delta & Single Handle Shower Faucet
How can I adjust the shower knob to produce hotter water then it does now. It used to be hotter. Taking the knob off reveals a white piece of plastic with a colder to hotter temp. gauge. How can I adjust...
Should be able to adjust clockwise or counter clockwise to adjust the temp. You said that the temp used to be hotter. Check the temp setting on your water heater. Did you replace your old water heater? Hope this helps.
Mar 07, 2010 | Home
Jackson 28 in. TempStar 300X-ST Free-standing Dishwasher Logo
14 people viewed this question
Top Jackson Dishwashers Experts
jhnolson
Are you a Jackson Dishwasher Expert? Answer questions, earn points and help others
