Question about Husqvarna 125bvx Hand Held Blower Vac
Will not run
Will start with starting fluid but won't continue to run
2002 grand am won't start
2002 car needs maintenance;tune up,fuel filter,coils,module,battery and connection.
Apr 11, 2013 | 2002 Pontiac Grand Am
2000 explorer won't start cranks OK, drove it to the store with no problems got back in won't turn over to start.
Try some starting fluid, if it wants to run then you need to check the Inertia switch. The location of this switch is behind the passengers foot kickpanel.
There is a Reset button that you push and it will reconnect the fuelpump. Please rate my info. You can try the Reset without testing with starting fluid but the fluid verifies fuel starvation as the problem.
Nov 19, 2012 | 2000 Ford Explorer
I ran over a big rock in the road. It went under car and hit undercarriage. The car engine stopped and would not restart like it was't getting gas.
trace your fuel line from your carb back to fuel tank, sounds like you have a severed fuel line. in either primary or return. it will start on starting fluid but won't continue to run without fuel.
Nov 14, 2012 | 1996 Lincoln Continental
96 chevy blazer won't start.
your gas pump is maybe your problem
Jun 29, 2012 | Cars & Trucks
My 98 gmc 1500 V8 5.0l won't start. Has good spark
Spray starting fluid into the air intake of the engine, if it starts and you have fuel pressure you have no injection or injector pulse as we call it. Check ECM fuse one and two for continuity if it starts with fluid..
May 25, 2012 | 1998 GMC Sierra
Coming to stop sign by putting break gear slips then return to park move to drive runs. second as i drive in curves slips but as give gas enough continues running.
Just to make sure I got this right. If you come to a stop, the car won't pull again unless you put it in park? Then, if you start into a curve, the transmission starts to slip unless you give it more gas? This could be signs of a bad torque converter, failing fluid pump (not as likely), or burnt/low transmission fluid level. Check the transmission fluid after the vehicle has been driven (warm engine), leave it running, and on a level surface. Check the level twice and take the lowest reading.
Dec 29, 2011 | 1993 Pontiac Bonneville
Won't start. New battery. Turns over but won't start.
These trucks are known for fuelpump problems. the first thing to check is to see if its got fuel pressure, try sparying starting fluid into throtlbody and see if it starts and runs for a few seconds, if it starts then you will know its a fuel problem, it will die out once the starting fluid is burnt up but at least it will tell you its a fuel problem and if it does start i would bet its the pump. good day.
Jul 30, 2011 | 2004 Chevrolet TrailBlazer
WON`T START COLD, STARTS ON STARTING FLUID 96 TRACKER
96 , TRACKER?
IF IT RUNS AND STAYS running. then that means the car is flooding or is in a sad state of tune.
tune it up and it will start every time.
if not ask me here.
http://www.kick-fix.com/
see my guest book. ask a question.
1; tune up
2: bad ECT sensor.
3: stuck closed IAC.
my page answers all sidekick questions.
Feb 04, 2009 | 1992 Geo Tracker
Husqvarna 125bvx Hand Held Blower Vac Logo
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
